楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-7-18 12:05:21 | 显示全部楼层
neroxps 发表于 2019-7-18 11:32
* Could not resolve host: raw.githubusercontent.com
这句自己上网搜索下看怎么解决
惆怅啊!我发现我可以上网,但是所有外网都ping不通,只能ping内网,外网访问正常,host没又异常
发表于 2019-7-18 19:32:10 | 显示全部楼层
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.2.0-rc4-aml-s905 (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.89 SMP PREEMPT Thu Jun 20 17:48:52 MSK 2019
Linux aml 5.2.0-rc4-aml-s905 #5.89 SMP PREEMPT Thu Jun 20 17:48:52 MSK 2019 aarch64 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
 楼主| 发表于 2019-7-19 08:52:38 | 显示全部楼层
Descri ...
system version 上面的也要发出来
发表于 2019-7-20 19:09:21 | 显示全部楼层
启动超时是什么原因啊?@neroxps
REPOSITORY                                 TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi3-homeassistant   0.96.2              9b028c76903f        15 hours ago        962MB
homeassistant/raspberrypi3-homeassistant   latest              9b028c76903f        15 hours ago        962MB
homeassistant/armv7-hassio-supervisor      170                 592442c33e9a        25 hours ago        180MB
homeassistant/armv7-hassio-supervisor      latest              592442c33e9a        25 hours ago        180MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                   COMMAND                  CREATED             STATUS              PORTS               NAMES
b204c701b1e1        homeassistant/armv7-hassio-supervisor   "/bin/entry.sh pytho…"   27 seconds ago      Created                                 hassio_supervisor
########################### hassio log ###########################
########################### homeassistant log ###########################
Error: No such container: homeassistant
homeassistant 启动超时,请检查上方日志....
root@raspberrypi:/home/pi#
 楼主| 发表于 2019-7-21 11:14:38 | 显示全部楼层
coyyx· 发表于 2019-7-20 19:09
启动超时是什么原因啊?@neroxps
REPOSITORY                                 TAG                 IMAGE  ...
一般重启设备可以修复
发表于 2019-7-21 12:11:54 | 显示全部楼层
重启还是没启动服务啊,,,,
发表于 2019-7-21 12:15:49 | 显示全部楼层
i@raspberrypi:~ $ hass HomeAssistant
usage: hass [-h] [--version] [-c path_to_config_dir] [--demo-mode] [--debug]
            [--open-ui] [--skip-pip] [-v] [--pid-file path_to_pid_file]
            [--log-rotate-days LOG_ROTATE_DAYS] [--log-file LOG_FILE]
            [--log-no-color] [--runner] [--script ...] [--daemon]
hass: error: unrecognized arguments: HomeAssistant
 楼主| 发表于 2019-7-21 17:12:01 | 显示全部楼层
coyyx· 发表于 2019-7-21 12:11
重启还是没启动服务啊,,,,
docker ps
docker logs hassio-supervisor
docker logs homeassistant
发表于 2019-7-22 02:58:24 | 显示全部楼层
Get:1 http://mirrors.ustc.edu.cn/raspbian/raspbian buster InRelease [15.0 kB]
Get:2 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:3 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf Packages [13.0 MB]
Get:4 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:5 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/contrib armhf Packages [58.7 kB]
Get:6 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/non-free armhf Packages [103 kB]
Get:7 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/rpi armhf Packages [1,360 B]
Get:8 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster/main armhf Packages [205 kB]
Get:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [205 kB]
Fetched 13.6 MB in 17s (794 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
9 packages can be upgraded. Run 'apt list --upgradable' to see them.
[info]: 安装 hassio 必要依赖.....
avahi-daemon is already the newest version (0.7-4+b1).
curl is already the newest version (7.64.0-4).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
The following additional packages will be installed:
  libjq1 libonig5
The following NEW packages will be installed:
  jq libjq1 libonig5 socat
0 upgraded, 4 newly installed, 0 to remove and 9 not upgraded.
Need to get 653 kB of archives.
After this operation, 1,844 kB of additional disk space will be used.
Get:1 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf libonig5 armhf 6.9.1-1 [150 kB]
Get:2 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf libjq1 armhf 1.5+dfsg-2+b1 [119 kB]
Get:3 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf jq armhf 1.5+dfsg-2+b1 [59.3 kB]
Get:4 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf socat armhf 1.7.3.2-2 [324 kB]
Fetched 653 kB in 2s (327 kB/s)
Selecting previously unselected package libonig5:armhf.
(Reading database ... 91789 files and directories currently installed.)
Preparing to unpack .../libonig5_6.9.1-1_armhf.deb ...
Unpacking libonig5:armhf (6.9.1-1) ...
Selecting previously unselected package libjq1:armhf.
Preparing to unpack .../libjq1_1.5+dfsg-2+b1_armhf.deb ...
Unpacking libjq1:armhf (1.5+dfsg-2+b1) ...
Selecting previously unselected package jq.
Preparing to unpack .../jq_1.5+dfsg-2+b1_armhf.deb ...
Unpacking jq (1.5+dfsg-2+b1) ...
Selecting previously unselected package socat.
Preparing to unpack .../socat_1.7.3.2-2_armhf.deb ...
Unpacking socat (1.7.3.2-2) ...
Setting up socat (1.7.3.2-2) ...
Setting up libonig5:armhf (6.9.1-1) ...
Setting up libjq1:armhf (1.5+dfsg-2+b1) ...
Setting up jq (1.5+dfsg-2+b1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit:
+ sh -c apt-get update -qq >/dev/null
+ sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://mirrors.aliyun.com/docker-ce/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=armhf] https://mirrors.aliyun.com/docker-ce/linux/raspbian buster stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
E: Package 'docker-ce' has no installation candidate
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
发表于 2019-7-22 03:02:16 | 显示全部楼层
大神你好,我小萌新,试了几次都是这一个问题,用了很多种选择,也重新烧了一次,还是不行, 麻烦帮吗看看哈谢谢
GMT+8, 2025-12-18 23:36 , Processed in 0.614122 second(s), 11 queries , MemCached On.
