楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-7-13 16:06:50 | 显示全部楼层
neroxps 发表于 2020-7-13 15:22
Read-only file system
你的OMV 有问题。
那是不是需要重做一遍系统呢
 楼主| 发表于 2020-7-13 16:29:35 | 显示全部楼层
hlqhome 发表于 2020-7-13 16:06
那是不是需要重做一遍系统呢
如果你不懂怎么解决那么可以试试重做。
发表于 2020-7-13 16:59:45 | 显示全部楼层
neroxps 发表于 2020-7-13 16:29
如果你不懂怎么解决那么可以试试重做。
我目前是armbian 需要更换成其他系统吗?
发表于 2020-7-14 09:26:32 | 显示全部楼层
之前安装使用都是正常的,前两周发现 supervisor 面板突然访问不了了,错误提示:
Unable to load the panel source: /api/hassio/app/entrypoint.js.
后面重新运行 install.sh 脚本安装了一次,依然没法使用,homeassistant 和 supervisor 的 Log 中均未见错误。
supervisor Log:
20-07-13 12:27:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 12:27:00 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 12:27:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 12:27:01 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-13 13:19:29 INFO (SyncWorker_8) [supervisor.docker] Run command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi4-homeassistant
20-07-13 13:19:41 INFO (MainThread) [supervisor.homeassistant] Home Assistant config is valid
20-07-13 13:21:12 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 13:21:40 INFO (MainThread) [supervisor.core] Start repairing of Supervisor Environment
20-07-13 13:21:40 INFO (SyncWorker_12) [supervisor.docker] Prune stale containers
20-07-13 13:21:40 INFO (SyncWorker_12) [supervisor.docker] Prune stale images
20-07-13 13:21:47 INFO (SyncWorker_12) [supervisor.docker] Prune stale builds
20-07-13 13:21:47 INFO (SyncWorker_12) [supervisor.docker] Prune stale volumes
20-07-13 13:21:47 INFO (SyncWorker_12) [supervisor.docker] Prune stale networks
20-07-13 13:21:47 INFO (MainThread) [supervisor.plugins.cli] Repair HA cli 25
20-07-13 13:21:47 INFO (SyncWorker_14) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-cli tag 25.
20-07-13 13:22:15 INFO (SyncWorker_14) [supervisor.docker.interface] Tag image homeassistant/armv7-hassio-cli with version 25 as latest
20-07-13 13:22:15 INFO (MainThread) [supervisor.addons] Found 1 add-ons to repair
20-07-13 13:22:15 INFO (MainThread) [supervisor.addons] Start repair for add-on: core_check_config
20-07-13 13:22:15 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image homeassistant/armv7-addon-check_config tag 3.3.0.
20-07-13 13:22:31 INFO (MainThread) [supervisor.supervisor] Repair Supervisor 228
20-07-13 13:22:31 INFO (MainThread) [supervisor.core] Finished repairing of Supervisor Environment
20-07-13 13:23:31 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.112.4
20-07-13 13:23:31 INFO (SyncWorker_18) [supervisor.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.111.2 to homeassistant/raspberrypi4-homeassistant:0.112.4
20-07-13 13:23:31 INFO (SyncWorker_18) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.112.4.
20-07-13 13:25:33 INFO (SyncWorker_18) [supervisor.docker.interface] Stop homeassistant application
20-07-13 13:25:43 INFO (SyncWorker_18) [supervisor.docker.interface] Clean homeassistant application
20-07-13 13:25:43 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-07-13 13:25:44 INFO (SyncWorker_5) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.112.4
20-07-13 13:25:49 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-07-13 13:25:49 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-07-13 13:25:49 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.112.4
20-07-13 13:25:50 INFO (SyncWorker_14) [supervisor.docker.interface] Cleanup images: ['homeassistant/raspberrypi4-homeassistant:0.111.2']
20-07-13 14:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 14:33:40 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-13 14:33:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-13 14:33:40 INFO (MainThread) [supervisor.host.services] Update service information
20-07-13 14:33:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 14:33:40 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 14:33:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 14:33:40 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-13 15:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-07-13 15:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-07-13 15:27:06 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove
20-07-13 16:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 16:40:20 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-13 16:40:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-13 16:40:20 INFO (MainThread) [supervisor.host.services] Update service information
20-07-13 16:40:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 16:40:20 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 16:40:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 16:40:20 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-13 18:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-07-13 18:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-07-13 18:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 18:27:04 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove
20-07-13 18:47:00 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-13 18:47:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-13 18:47:00 INFO (MainThread) [supervisor.host.services] Update service information
20-07-13 18:47:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 18:47:00 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 18:47:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 18:47:00 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-13 20:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 20:50:20 INFO (MainThread) [supervisor.misc.tasks] Found new PulseAudio plugin version
20-07-13 20:50:20 INFO (SyncWorker_16) [supervisor.docker.interface] Update image homeassistant/armv7-hassio-audio:14 to homeassistant/armv7-hassio-audio:16
20-07-13 20:50:20 INFO (SyncWorker_16) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-audio tag 16.
20-07-13 20:50:29 INFO (SyncWorker_16) [supervisor.docker.interface] Stop hassio_audio application
20-07-13 20:50:34 INFO (SyncWorker_16) [supervisor.docker.interface] Clean hassio_audio application
20-07-13 20:50:34 INFO (SyncWorker_5) [supervisor.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-audio:14']
20-07-13 20:50:35 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-07-13 20:50:36 INFO (SyncWorker_10) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 16 - 172.30.32.4
20-07-13 20:53:40 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-13 20:53:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-13 20:53:40 INFO (MainThread) [supervisor.host.services] Update service information
20-07-13 20:53:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 20:53:40 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 20:53:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 20:53:40 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-13 21:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-07-13 21:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-07-13 21:27:04 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove
20-07-13 22:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-13 23:00:20 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-13 23:00:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-13 23:00:20 INFO (MainThread) [supervisor.host.services] Update service information
20-07-13 23:00:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-13 23:00:20 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-13 23:00:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-13 23:00:20 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-14 00:27:00 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-14 00:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-07-14 00:27:00 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-07-14 00:27:04 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove
20-07-14 01:07:00 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-14 01:07:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-14 01:07:00 INFO (MainThread) [supervisor.host.services] Update service information
20-07-14 01:07:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-14 01:07:00 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-14 01:07:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-14 01:07:00 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
ha info:
arch: armv7
channel: stable
docker: 19.03.8
hassos: null
homeassistant: 0.112.4
hostname: raspberrypi
logging: info
machine: raspberrypi4
supervisor: "228"
supported_arch:
- armv7
- armhf
timezone: Asia/Shanghai
不知道是不是和 supervisor 版本升级有关,请问有什么好的解决排查方法吗?
 楼主| 发表于 2020-7-14 10:06:24 | 显示全部楼层
Unable to load the pan ...
请提供 homeassistant  log
发表于 2020-7-14 13:04:38 | 显示全部楼层
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] udev.sh: executing... ,
[21:25:45] INFO: Update udev information,
[cont-init.d] udev.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
2020-07-13 21:25:52 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2020-07-13 21:25:53 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 7,
2020-07-13 21:25:53 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns context_parent_id to table events. Note: this can take several minutes on large databases and slow computers. Please be patient!,
2020-07-13 21:26:03 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.,
2020-07-13 21:26:41 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (MySQLdb._exceptions.OperationalError) (1296, "Got error 64 'Temp file write failure' from InnoDB"),
[SQL: ALTER TABLE events ADD context_parent_id CHARACTER(36)],
(Background on this error at: http://sqlalche.me/e/e3q8),
2020-07-13 21:26:41 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1296, "Got error 64 'Temp file write failure' from InnoDB"),
(Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds),
..........重复
2020-07-13 21:34:26 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.,
2020-07-13 21:34:29 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for chineseholiday which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2020-07-13 21:34:30 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for xiaomi_miio_airpurifier which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2020-07-13 21:34:30 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for xiaomi_miio_airconditioningcompanion which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.,
2020-07-13 21:34:31 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder,
2020-07-13 21:34:31 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.,
2020-07-13 21:34:31 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: recorder,
2020-07-13 21:34:31 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.,
2020-07-13 21:34:31 WARNING (MainThread) [homeassistant.components.climate] ClimateDevice is deprecated, modify XiaomiAirConditioningCompanion to extend ClimateEntity,
2020-07-13 21:34:31 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address in use,
2020-07-13 21:36:58 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: history, logbook,
2020-07-13 21:36:58 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.,
2020-07-13 21:37:06 ERROR (SyncWorker_8) [homeassistant.components.zeroconf] Home Assistant instance with identical name present in the local network,
2020-07-13 21:37:06 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Unable to update from sensor: could not convert string to float: 'unavailable',
2020-07-13 22:31:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds,
2020-07-13 22:31:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aqara_air_conditioning_companion is taking over 10 seconds,
2020-07-13 22:31:14 ERROR (SyncWorker_1) [miio.miioprotocol] Unable to discover a device at address 10.42.113.10,
2020-07-13 22:31:14 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Got exception while fetching the state: Unable to discover the device 10.42.113.10,
2020-07-13 23:15:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.xiaomi_philips_smart_led_ball is taking over 10 seconds,
2020-07-13 23:15:56 ERROR (SyncWorker_9) [miio.miioprotocol] Unable to discover a device at address 10.42.110.10,
2020-07-13 23:15:56 ERROR (MainThread) [homeassistant.components.xiaomi_miio.light] Got exception while fetching the state: Unable to discover the device 10.42.110.10,
2020-07-13 23:16:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds,
2020-07-13 23:16:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aqara_air_conditioning_companion is taking over 10 seconds,
2020-07-13 23:16:20 WARNING (MainThread) [homeassistant.components.climate] Updating xiaomi_miio_airconditioningcompanion climate took longer than the scheduled update interval 0:00:10,
2020-07-13 23:16:20 ERROR (SyncWorker_10) [miio.miioprotocol] Unable to discover a device at address 10.42.113.10,
2020-07-13 23:16:20 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Got exception while fetching the state: Unable to discover the device 10.42.113.10,
2020-07-13 23:16:22 ERROR (SyncWorker_3) [miio.miioprotocol] Unable to discover a device at address 10.42.110.10,
2020-07-13 23:16:22 ERROR (MainThread) [homeassistant.components.xiaomi_miio.light] Got exception while fetching the state: Unable to discover the device 10.42.110.10,
2020-07-13 23:16:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of alarm_control_panel.xiaomi_gateway_alarm is taking over 10 seconds,
2020-07-14 12:54:12 ERROR (SyncWorker_17) [miio.miioprotocol] Unable to discover a device at address 10.42.110.10,
2020-07-14 12:54:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio.light] Got exception while fetching the state: Unable to discover the device 10.42.110.10,
..........重复
MySQL 似乎有些问题,导致 Recorder 初始化失败,这个的原因我再检查下,难说是部署 MySQL 的机子硬盘满了。不过这个对访问 supervisor 面板感觉应该不会有影响。
后面大量重复 Log 是无法连上某个智能灯泡,这个应该也没什么影响。
 楼主| 发表于 2020-7-14 13:40:52 | 显示全部楼层
[s6-init] ensuring  ...
你没用 mysql 把 用的是sqlite 你df 看看是不是空间不足。或者 mount 看看是不是只读了
发表于 2020-7-14 14:06:56 | 显示全部楼层
neroxps 发表于 2020-7-14 13:40
你没用 mysql 把 用的是sqlite 你df 看看是不是空间不足。或者 mount 看看是不是只读了 ...
配置的是 MySQL,放在另一台主机上,我不想去用树莓派那个 TF 卡当存储。空间是不多了,就剩 700M 左右了,这个等周末看看怎么迁移扩容下。不过现在 HomeAssistant 已经是运行起来了的,基本控制都是可用的,就 supervisor 和 add-on 部分不可用。
发表于 2020-7-14 14:17:36 | 显示全部楼层
感觉和 supervisor 的版本有关,之前的 Log 看好像是在自己升级然后就挂了。
 楼主| 发表于 2020-7-15 08:34:25 | 显示全部楼层
112 版本 的ha 官方更新说明说更新需要等待一段时间,因为数据库改动很大,如果数据库大的话,需要等待十分钟以上。
GMT+8, 2025-12-16 20:57 , Processed in 0.142884 second(s), 10 queries , MemCached On.
