查看: 6510|回复: 42
[硬件DIY] 8块钱的空调伴侣接入Homeassistant
发表于 2025-1-1 09:50:17 | 显示全部楼层 |阅读模式
垃圾佬的快乐啊!黄鱼上捡了几个便宜的空调伴侣,本来想改到插座里做个智能插座,看这16A的插座体积有点大,塞进插排比较麻烦就没折腾。这插座的APP不想用,估计也不能用了,拆开看了下是esp8266的芯片本着不浪费的原则就改了个能接入Homeassistant的空调伴侣。
外观
外观
做工用料还行
功率监测芯片
电压电流监测芯片
电压电流监测芯片
烧录点位图
esphome:
  platform: ESP8266
  board: esp01_1m
  friendly_name: BedRoomAC
time:
  - platform: sntp
web_server:
  port: 80
ota:
  platform: esphome
  password: ""
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 0s
  on_connect:
    - light.turn_on: id_led_api_link
  on_disconnect:
    - light.turn_on:
        brightness: 100%
        effect: "fast"
  ap:
    ssid: "BedRoomAC"
    password: ""
logger:
api:
substitutions:  #指定各IO口功能便于记忆
  ir_receiver_pin: GPIO5
  ir_transmitter_pin: GPIO14
  led_status_pin: GPIO13
  relay_pin: GPIO15
  power_senser_pin: GPIO12
output:
  - platform: esp8266_pwm
    pin: ${led_status_pin}
    inverted: false
switch:  # 继电器
  - platform: gpio
    pin: ${relay_pin}
    inverted: true
    restore_mode: ALWAYS_ON
button:
  - platform: template
    name: "Reset Energy Consumption"
    on_press:
      then:
        - lambda: |-
            id(total_kwh) = 0.0;  // 重置总用电量
light:  #连接状态灯
  - platform: status_led
    name: "API Link Led"
    output: id_pin_led_status
    internal: true  #不在HA中显示
  - platform: monochromatic
    default_transition_length: 0s
    internal: true
    effects:
      - pulse:
          transition_length: 500ms
          update_interval: 1s
globals:
  - id: total_kwh
    type: float
    initial_value: "0.0"
sensor: #功率传感器配置
  - platform: pulse_counter
    pin: ${power_senser_pin}
    unit_of_measurement: "W"
    icon: "mdi:flash"
    filters:
      - lambda: |-
          const float frequency_to_power_factor = 0.4115; // 校准因子
          return x * frequency_to_power_factor;
    update_interval: 10s
    name: "Energy Consumption"
    unit_of_measurement: "kWh"
    icon: "mdi:counter"
    accuracy_decimals: 3
    lambda: |-
      return id(total_kwh);
    # 累加功率值
    on_value:
      then:
        - lambda: |-
            id(total_kwh) += (id(power).state * 10 / 3600.0);  // 每10秒累加到总能耗
            id(total_kwh) = fmax(0.0, id(total_kwh));          // 防止出现负值
    filters:
        - multiply: 0.001
  - platform: template #虚拟室温,空调遥控需要
    name: "BedRoom Temperature"
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    lambda: |-
      return 25.0;  // 固定值调试
remote_receiver: #红外接收
  pin:
    number: ${ir_receiver_pin}
    inverted: true
    mode:
      input: true
      pullup: true
  dump: nec
  tolerance: 55%  #信号强度
remote_transmitter: #红外发射
  pin:
    number: ${ir_transmitter_pin}
  carrier_duty_percent: 50%
climate: #下面为格力空调,别的空调更改platform,参考esphome标准文档https://esphome.io/components/climate/climate_ir.html 或者弄个按钮切换各品牌。
  - platform: gree
    sensor: room_temperature
    model: yan
    receiver_id: ir_receiver
试了下能控制客厅的3匹风管机和房间的分体机,懒得再折腾了,留着备用
参与人数 3金钱 +40 HASS币 +10 收起 理由
book123 + 10 高手,这是高手!
admin + 20 + 10 高手,这是高手!
tianzhuang55 + 10 感谢楼主分享!
发表于 2025-1-1 11:18:22 | 显示全部楼层
发表于 2025-1-1 14:39:26 | 显示全部楼层
可惜动手能力不行,不然高低整几个
发表于 2025-1-3 09:10:21 | 显示全部楼层
超值啊,8266都要几元
大佬发的教程往往让新人卡在第一步
发表于 2025-1-7 21:26:36 | 显示全部楼层
大佬,有没有视频教程,我有好几个这种插座
发表于 2025-1-7 21:31:58 | 显示全部楼层
大佬求商品链接,出门经常忘记关空调,急需这个玩意儿
发表于 2025-1-8 01:42:33 | 显示全部楼层
找到了,打扰了
发表于 2025-1-8 10:18:27 | 显示全部楼层
求关键词
发表于 2025-1-8 10:24:56 | 显示全部楼层
找到了,关键词是爱德家
发表于 2025-1-8 17:30:30 | 显示全部楼层
我也去捡垃圾了。
GMT+8, 2025-9-21 04:44 , Processed in 1.369507 second(s), 18 queries , MemCached On.
