楼主: tianqiraf
[硬件DIY] 惠桔和家亲X1S智能插座“免拆”烧录esphome接入HA
发表于 2024-10-19 13:50:16 | 显示全部楼层
walkingsky 发表于 2024-10-16 13:08
和家亲 的MC010-W 刷机摸不到门道。没有任何反应
bk7231flasher_1.3.3 和ltchiptool-v4.11.2 尝试读取fl ...
也许是esp8285的芯片
发表于 2024-10-28 11:58:04 | 显示全部楼层
OTA后插座会断电重启,有没有人研究下怎么避免???
发表于 2024-10-28 17:19:32 | 显示全部楼层
W: Unknown bootloader CRC - 0xBD944C61 - please report this on GitHub issues!
W: Erasing failure @ 0x0 (Erase failed - flash protected; found non-0xFF bytes @ 0x0), retrying (attempt 0)
W: Erasing failure @ 0x0 (Erase failed - flash protected; found non-0xFF bytes @ 0x0), retrying (attempt 1)
W: Erasing failure @ 0x0 (Erase failed - flash protected; found non-0xFF bytes @ 0x0), retrying (attempt 2)
W: Erasing failure @ 0x0 (Erase failed - flash protected; found non-0xFF bytes @ 0x0), retrying (attempt 3)
怎送怎么回事???
发表于 2024-12-30 00:44:09 | 显示全部楼层
Switch传感器是起什么作用,按下实体按钮后瞬间显示开启,松开后立刻变为关闭了,不管插座是不是开启状态
发表于 2025-2-7 14:43:31 | 显示全部楼层
请教!换了路由器改了wifi名,要怎么样改成现在的wifi名,谢谢
发表于 2025-3-5 16:11:29 | 显示全部楼层
大佬们,是不是刷完之后,正常使用了,也无法通过esphome来更新配置文件(因为固件需要魔改)?
发表于 2025-3-10 05:12:33 | 显示全部楼层
能接涂鸦嘛,请问截取MQTT消息怎么做,ha用的不多
发表于 2025-10-31 04:04:49 | 显示全部楼层
请教楼主及各位大神:为什么我的弄完后,电压电流功率极不准确,而且乱跳?
GMT+8, 2026-1-16 10:43 , Processed in 1.258221 second(s), 11 queries , MemCached On.
