发表于 2024-10-11 22:15:19
显示全部楼层
又装了一遍,还是报错了,好像是连接到服务器失败的原因?
hassio-supervisor
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_uri.py:51: SyntaxWarning: invalid escape sequence '\w'
_UNRESERVED = "[\w\-\.]"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3.py:265: SyntaxWarning: invalid escape sequence '\{'
part_pattern = "^(\{0}|\{1})$".format(self.WILDCARD_ONE,
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:48: SyntaxWarning: invalid escape sequence '\w'
_ALPHANUM_PATTERN = "\w"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:51: SyntaxWarning: invalid escape sequence '\d'
_LANGTAG_PATTERN = "^([a-z]{2,3}(-([a-z]{2}|[\d]{3}))?)$"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:49: SyntaxWarning: invalid escape sequence '\!'
_PUNC_NO_DASH = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\.|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:77: SyntaxWarning: invalid escape sequence '\{'
_spec1 = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:78: SyntaxWarning: invalid escape sequence '\{'
_spec2 = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:86: SyntaxWarning: invalid escape sequence '\w'
_body1 = "\w|{0}".format(_quoted1)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:87: SyntaxWarning: invalid escape sequence '\w'
_body2 = "\w|{0}".format(_quoted2)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:50: SyntaxWarning: invalid escape sequence '\w'
_UNRESERVED = "\w|\.|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:51: SyntaxWarning: invalid escape sequence '\!'
_PUNC = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:77: SyntaxWarning: invalid escape sequence '\{'
_logical = "(\{0}|{1})".format(VALUE_ANY, VALUE_NA)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:78: SyntaxWarning: invalid escape sequence '\{'
_quest = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:79: SyntaxWarning: invalid escape sequence '\{'
_asterisk = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_anyvalue.py:35: SyntaxWarning: invalid escape sequence '\*'
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Setting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor m.fashgh.com/home-assistant/amd64-hassio-supervisor with version 2024.08.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.wghaos.com/x86-6 ... 2024.08.0&arch=
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-cli with version 2024.07.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI m.fashgh.com/home-assistant/amd64-hassio-cli with version 2024.07.0 - 172.30.32.5
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS m.fashgh.com/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio m.fashgh.com/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer m.fashgh.com/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast m.fashgh.com/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for m.fashgh.com/home-assistant/qemux86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant found.
[supervisor.homeassistant.core] Setting up Home Assistant landingpage
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant with tag landingpage.
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant m.fashgh.com/home-assistant/qemux86-64-homeassistant with version landingpage
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp1_1.py:57: SyntaxWarning: invalid escape sequence '\w'
_STRING = "\w\.\-,\(\)@\#"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_2.py:52: SyntaxWarning: invalid escape sequence '\d'
_VALUE_PATTERN = "^([\d\w\._\-~%]+)$"
/usr/local/lib/python3.12/site-packages/cpe/cpe2_3_fs.py:97: SyntaxWarning: invalid escape sequence '\:'
_parts_pattern = "^cpe:2.3:{0}\:{1}\:{2}\:{3}\:{4}\:{5}\:{6}\:{7}\:{8}\:{9}\:{10}$".format(
[supervisor.os.manager] Detect Home Assistant Operating System 13.1.1 / BootSlot A
[supervisor.resolution.module] Create new issue free_space - system / None
[supervisor.jobs] 'GitRepo.clone' blocked from execution, not enough free space (0.4GB) left on the device
[supervisor.store] Can't add repository https://gitcode.com/waxgourd/ha-git-addons due to 'GitRepo.clone' blocked from execution, not enough free space (0.4GB) left on the device
[supervisor.resolution.module] Create new suggestion execute_reload - store / fb59d657
[supervisor.resolution.module] Create new issue fatal_error - store / fb59d657
[supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, not enough free space (0.4GB) left on the device
[supervisor.resolution.module] Create new suggestion execute_reload - store / core
[supervisor.resolution.module] Create new issue fatal_error - store / core
[supervisor.store] Can't add repository https://gitcode.com/waxgourd/ha-esphome-addons due to 'GitRepo.clone' blocked from execution, not enough free space (0.4GB) left on the device
[supervisor.resolution.module] Create new suggestion execute_reload - store / b9a594eb
[supervisor.resolution.module] Create new issue fatal_error - store / b9a594eb
[supervisor.store] Can't add repository https://gitcode.com/waxgourd/ha-music-addons due to 'GitRepo.clone' blocked from execution, not enough free space (0.4GB) left on the device
[supervisor.resolution.module] Create new suggestion execute_reload - store / d6faf732
[supervisor.resolution.module] Create new issue fatal_error - store / d6faf732
[supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.wghaos.com/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2024.10.0
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/amd64-hassio-supervisor with tag 2024.10.0.
[aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 189, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 205, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 272, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 280, in core_proxy
if request[REQUEST_FROM] != self.sys_homeassistant or version_is_new_enough(
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 152, in version_is_new_enough
return version >= want_version
File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 185, in __ge__
return self.__eq__(compareto) or self.__gt__(compareto)
File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 172, in __gt__
raise AwesomeVersionCompareException(
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare and
[supervisor.misc.scheduler] Shutting down scheduled tasks
[supervisor.docker.monitor] Stopped docker events monitor
[supervisor.api] Stopping API on 172.30.32.2
[supervisor.hardware.monitor] Stopped Supervisor hardware monitor
[supervisor.dbus.manager] Closed conection to system D-Bus.
[supervisor.core] Supervisor is down - 0
[__main__] Closing Supervisor
WARNING: Halt Supervisor
INFO: Supervisor restart after closing
s6-rc: info: service legacy-services: stopping
INFO: Watchdog restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
