楼主: 冬瓜HA
冬瓜HAOS:X86版大陆优化home assistant os16.3.1固件
发表于 2024-9-8 19:43:44 | 显示全部楼层
hassio-supervisor
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_uri.py:51: SyntaxWarning: invalid escape sequence '\w'
_UNRESERVED = "[\w\-\.]"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3.py:265: SyntaxWarning: invalid escape sequence '\{'
part_pattern = "^(\{0}|\{1})$".format(self.WILDCARD_ONE,
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:48: SyntaxWarning: invalid escape sequence '\w'
_ALPHANUM_PATTERN = "\w"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:51: SyntaxWarning: invalid escape sequence '\d'
_LANGTAG_PATTERN = "^([a-z]{2,3}(-([a-z]{2}|[\d]{3}))?)$"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:49: SyntaxWarning: invalid escape sequence '\!'
_PUNC_NO_DASH = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\.|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:77: SyntaxWarning: invalid escape sequence '\{'
_spec1 = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:78: SyntaxWarning: invalid escape sequence '\{'
_spec2 = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:86: SyntaxWarning: invalid escape sequence '\w'
_body1 = "\w|{0}".format(_quoted1)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:87: SyntaxWarning: invalid escape sequence '\w'
_body2 = "\w|{0}".format(_quoted2)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:50: SyntaxWarning: invalid escape sequence '\w'
_UNRESERVED = "\w|\.|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:51: SyntaxWarning: invalid escape sequence '\!'
_PUNC = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:77: SyntaxWarning: invalid escape sequence '\{'
_logical = "(\{0}|{1})".format(VALUE_ANY, VALUE_NA)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:78: SyntaxWarning: invalid escape sequence '\{'
_quest = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:79: SyntaxWarning: invalid escape sequence '\{'
_asterisk = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_anyvalue.py:35: SyntaxWarning: invalid escape sequence '\*'
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Setting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor m.fashgh.com/home-assistant/amd64-hassio-supervisor with version 2024.08.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.wghaos.com/x86-64-vm-release-cn.json
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-cli with version 2024.07.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI m.fashgh.com/home-assistant/amd64-hassio-cli with version 2024.07.0 - 172.30.32.5
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS m.fashgh.com/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio m.fashgh.com/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer m.fashgh.com/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found m.fashgh.com/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/amd64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast m.fashgh.com/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for m.fashgh.com/home-assistant/qemux86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant found.
[supervisor.homeassistant.core] Setting up Home Assistant landingpage
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant with tag landingpage.
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant m.fashgh.com/home-assistant/qemux86-64-homeassistant with version landingpage
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp1_1.py:57: SyntaxWarning: invalid escape sequence '\w'
_STRING = "\w\.\-,\(\)@\#"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_2.py:52: SyntaxWarning: invalid escape sequence '\d'
_VALUE_PATTERN = "^([\d\w\._\-~%]+)$"
/usr/local/lib/python3.12/site-packages/cpe/cpe2_3_fs.py:97: SyntaxWarning: invalid escape sequence '\:'
_parts_pattern = "^cpe:2.3:{0}\:{1}\:{2}\:{3}\:{4}\:{5}\:{6}\:{7}\:{8}\:{9}\:{10}$".format(
[supervisor.os.manager] Detect Home Assistant Operating System 13.1 / BootSlot A
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-git-addons repository
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-music-addons repository
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-esphome-addons repository
[supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-core-addons repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image m.fashgh.com/home-assistant/qemux86-64-homeassistant:landingpage to m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.9.1
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant with tag 2024.9.1.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.module] Create new issue dns_server_ipv6_error - dns_server / dns://192.168.8.1
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.module] Create new issue dns_server_failed - dns_server / dns://192.168.8.1
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.docker.interface] Can't install m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.9.1: 404 Client Error for http+docker://localhost/v1.45/images/m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.9.1/json: Not Found ("No such image: m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.9.1")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
一直卡着
 楼主| 发表于 2024-9-8 22:29:27 | 显示全部楼层
a271493703 发表于 2024-9-8 19:43
hassio-supervisor
s6-rc: info: service s6rc-onesh ...
你的网的问题,联系我,我告诉你解决方法。
发表于 2024-9-9 14:28:10 | 显示全部楼层
我也是卡在这里了,请问怎么处理
发表于 2024-9-11 12:19:32 | 显示全部楼层
大佬,我下载了vmdx 13.1版用vmware安装上去了,但是我卡在准备页面好几个小时,使用了梯子也不动求助。
 楼主| 发表于 2024-9-12 16:19:37 | 显示全部楼层
EVILIMP 发表于 2024-9-11 12:19
大佬,我下载了vmdx 13.1版用vmware安装上去了,但是我卡在准备页面好几个小时,使用了梯子也不动求助。 ...
要扩容。把它扩成32G
发表于 2024-9-12 20:42:00 | 显示全部楼层
冬瓜HA 发表于 2024-9-12 16:19
要扩容。把它扩成32G
大佬我现在登录进去了,大部分的问题我估计都是网络造成的,我一步步按照你的指导安装的,就是那些预加载的插件和集成要等很久都不一定能安装上,我想问下,我如果申请一个公网ip会让我的网络变好点吗?
发表于 2024-9-16 23:48:45 | 显示全部楼层
准备下载安装在pve上看看,多谢了。
发表于 2024-9-20 09:04:44 | 显示全部楼层
我用vm虚拟机 感觉老是除问题呢,,一点不好用,
 楼主| 发表于 2024-9-21 12:32:44 | 显示全部楼层
出问题?哪方面?
发表于 2024-9-25 15:17:11 | 显示全部楼层
原生版是不是就是像操作系统一样安装,但是整个img的文件,究竟如何安装到X86的电脑上啊?
GMT+8, 2025-12-21 22:15 , Processed in 1.495302 second(s), 11 queries , MemCached On.
