楼主: 冬瓜HA
冬瓜HAOS:X86版大陆优化home assistant os16.3.1固件
f@me 手机认证
发表于 2024-8-26 18:04:38 | 显示全部楼层
下载已修改,请在试试
发表于 2024-8-27 09:39:56 | 显示全部楼层
f@me 发表于 2024-8-26 18:04
下载已修改,请在试试
容量大小完全不对啊
发表于 2024-8-27 20:34:52 | 显示全部楼层
冬瓜HA 发表于 2024-8-26 11:30
因为hyper-v的,不支持usb挂载,所以就没传了。
你好, 那hyper-v 的虚拟机用哪个? 我这边都是hyper-v的虚拟机。。。
 楼主| 发表于 2024-8-28 00:07:51 | 显示全部楼层
哎,这两天发13.1.我再发吧,坚持一下。13.0与13.1太近了。就同时发了
发表于 2024-8-28 08:51:17 | 显示全部楼层
好的,3q
 楼主| 发表于 2024-8-29 14:42:13 | 显示全部楼层
13.1刷机包已更新
发表于 2024-8-29 18:57:12 | 显示全部楼层
Use `ha` to access the Home Assistant CLI.
root@homeassistant:/ # ha-install -t
  core image pulling : @layer [total]:30 [processed]:8 [waiting]:18 [processing]:4 | @data [total]:472MB [processing]:50MB [processed]:445MB [rate]:11.1%
  core image pulling : @layer [total]:30 [processed]:8 [waiting]:19 [processing]:3 | @data [total]:472MB [processing]:61MB [processed]:423MB [rate]:14.3%
  core image pulling : @layer [total]:30 [processed]:8 [waiting]:18 [processing]:4 | @data [total]:491MB [processing]:83MB [processed]:442MB [rate]:18.7%
  core image pulling : @layer [total]:30 [processed]:8 [waiting]:20 [processing]:2 | @data [total]:491MB [processing]:96MB [processed]:390MB [rate]:24.4%
  core image pulling : @layer [total]:30 [processed]:8 [waiting]:20 [processing]:2 | @data [total]:491MB [processing]:196MB [processed]:390MB [rate]:50.3%
  core image pulled  : @layer [total]:30 [processed]:30 [waiting]:0 [processing]:0 | @data [total]:491MB
  core image pull end   : ghcr.linkos.org/home-assistant/qemux86-64-homeassistant:2024.8.3
check core pull end.
报错进不去啊
发表于 2024-8-29 19:15:46 | 显示全部楼层
  core image pulling ...
[supervisor.host.services] Updating service information
[supervisor.host.network] Updating local network information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.evaluate] System evaluation complete
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.docker.interface] Can't install m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.8.3: 404 Client Error for http+docker://localhost/v1.45/images/m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.8.3/json: Not Found ("No such image: m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.8.3")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[supervisor.docker.interface] Updating image m.fashgh.com/home-assistant/qemux86-64-homeassistant:landingpage to m.fashgh.com/home-assistant/qemux86-64-homeassistant:2024.8.3
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/qemux86-64-homeassistant with tag 2024.8.3.
 楼主| 发表于 2024-8-29 20:44:31 | 显示全部楼层
[supervisor.host.network] Updating local n ...
联系我
发表于 2024-8-29 21:30:21 | 显示全部楼层
大神救命,,,从昨天晚上到现在一直没弄好
GMT+8, 2025-12-21 23:58 , Processed in 0.346756 second(s), 11 queries , MemCached On.
