楼主: 冬瓜HA
填坑:魔百盒CM311-1a、M401a、unt403a刷冬瓜HAOS指南(已停更)
发表于 2024-1-10 23:27:49 | 显示全部楼层
WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'大佬,一直报这个怎么办?
 楼主| 发表于 2024-1-10 23:30:43 | 显示全部楼层
lemon6878 发表于 2024-1-10 23:27
WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'大佬,一直报这个怎么办 ...
截一下图
发表于 2024-1-11 14:03:30 | 显示全部楼层
冬瓜HA 发表于 2024-1-10 20:18
不好说,因为linux是以dtb决定可不可用的。如果是相同的,就可以用。
YST是一个厂商名,易 视 腾 ...
感谢大佬回复。
发表于 2024-1-11 14:16:54 | 显示全部楼层
测试了几天目前还比较稳定,不像Supervisor版本那样会莫名其妙死机,必须重启才行。不过Supervisor服务偶尔会挂掉,日志是这样的,
24-01-11 11:36:33 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 11:42:34 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 11:42:34 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 11:48:35 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 11:48:35 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 11:54:36 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 11:54:37 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:00:37 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:00:38 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:05:55 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-01-11 12:06:39 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:06:39 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:12:40 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:12:40 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:15:53 INFO (MainThread) [supervisor.host.info] Updating local host information
24-01-11 12:15:54 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-11 12:15:54 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-11 12:15:55 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-11 12:15:55 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-01-11 12:18:41 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:18:42 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:24:42 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:24:43 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:30:44 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:30:44 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:33:49 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-01-11 12:33:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-01-11 12:33:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-01-11 12:33:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-01-11 12:35:57 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-01-11 12:36:45 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:36:45 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:42:46 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:42:47 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:48:47 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:48:48 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 12:54:49 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 12:54:49 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:00:50 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:00:50 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:05:58 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-01-11 13:06:51 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:06:51 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:12:52 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:12:53 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:18:53 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:18:54 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:24:55 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:24:55 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:30:56 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:30:57 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-01-11 13:33:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-01-11 13:35:45 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/cm311-release.json
24-01-11 13:35:59 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-01-11 13:36:58 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:36:58 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:42:59 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:42:59 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:49:00 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:49:01 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 13:55:01 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 13:55:02 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 14:01:03 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 14:01:03 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
24-01-11 14:06:00 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-01-11 14:07:04 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
24-01-11 14:07:04 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
 楼主| 发表于 2024-1-11 14:50:59 | 显示全部楼层
lemon6878 发表于 2024-1-11 14:16
测试了几天目前还比较稳定,不像Supervisor版本那样会莫名其妙死机,必须重启才行。不过Supervisor服务偶 ...
supervisor有较好的存活机制,你现在是supervisor与core通讯中,不知道什么原因,失联了。于是它的存活机掉重启,保持联系。
supervisor不会影响使用的。
发表于 2024-1-11 21:50:32 | 显示全部楼层
冬瓜HA 发表于 2024-1-11 14:50
supervisor有较好的存活机制,你现在是supervisor与core通讯中,不知道什么原因,失联了。于是它的存活机 ...
虽然看不懂,但是觉得很厉害辛苦大佬继续优化
发表于 2024-1-12 05:41:03 | 显示全部楼层
11.4直接可以升级吗
发表于 2024-1-12 07:39:20 | 显示全部楼层
请问楼主的www.buymeacoffee.com的id
 楼主| 发表于 2024-1-12 10:39:01 | 显示全部楼层
我只在咱们论坛。想找我,可私信我
发表于 2024-1-12 16:52:16 | 显示全部楼层
wangyi 发表于 2024-1-12 05:41
11.4直接可以升级吗
可以啦!@@  并且 蓝牙也可以使用啦!!当然 我蓝牙来做啥也不清楚!!
GMT+8, 2026-1-11 05:32 , Processed in 1.010475 second(s), 13 queries , MemCached On.
