- 积分
- 757
- 金钱
- 683
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 757
- 金钱
- 683
- HASS币
- 0
发表于 2024-8-8 21:33:25
显示全部楼层
zigbee2mqtt运行不起来,不知道是啥原因,以下是log,请解惑。
[21:26:33] INFO: Preparing to start...
[21:26:34] INFO: Socat not enabled
[21:26:34] INFO: Enabled Zigbee2MQTT watchdog with value 'default'
[21:26:36] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT with watchdog (60000,300000,900000,1800000,3600000).
[2024-08-08 21:26:40] info: z2m: Logging to console, file (filename: log.log)
[2024-08-08 21:26:40] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-08 21:26:40] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-08 21:26:40] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-08-08 21:26:40] info: zh:zstack:znp: Serialport opened
[2024-08-08 21:26:41] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-08-08 21:26:42] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-08-08 21:27:54] error: z2m: Error while starting zigbee-herdsman
[2024-08-08 21:27:54] error: z2m: Failed to start zigbee
[2024-08-08 21:27:54] error: z2m: Check https://www.zigbee2mqtt.io/guide ... fails-to-start.html for possible solutions
[2024-08-08 21:27:54] error: z2m: Exiting...
[2024-08-08 21:27:54] error: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:365:23)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:86:21)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5) |
