楼主: dscao
[插件集成] 和风天气完整配置版本2025.8.6
发表于 2024-4-14 20:39:46 | 显示全部楼层
我更新了HA,然后就不能用了,只好又回退。有碰到这种情况的吗?
发表于 2024-4-15 15:30:55 | 显示全部楼层
权利不足居然能购买但是不能下载。。。哇真是醉了
发表于 2024-4-15 20:22:56 | 显示全部楼层
感谢大佬
发表于 2024-4-16 03:07:10 | 显示全部楼层
很奇怪,这个天气插件突然就不兼容群晖dms 7.2版本的容器了,直接报错了
Logger: homeassistant.components.weather
Source: helpers/entity_platform.py:344
Integration: 天气 (documentation, issues)
First occurred: 02:49:23 (5 occurrences)
Last logged: 03:04:31
Error while setting up qweather platform for weather
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 344, in _async_setup_platform
    await asyncio.shield(task)
  File "/config/custom_components/qweather/weather.py", line 137, in async_setup_entry
    await data.async_update(dt_util.now())
  File "/config/custom_components/qweather/weather.py", line 572, in async_update
    hourly_summary = await self._hass.async_add_executor_job(self.get_forecast_minutely, self._fxlink)
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/qweather/weather.py", line 484, in get_forecast_minutely
    response = request('GET', url, headers=header)
  File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 575, in request
    prep = self.prepare_request(req)
  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 486, in prepare_request
    p.prepare(
  File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 368, in prepare
    self.prepare_url(url, params)
  File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 439, in prepare_url
    raise MissingSchema(
requests.exceptions.MissingSchema: Invalid URL 'None': No scheme supplied. Perhaps you meant https://None?
发表于 2024-4-16 09:01:37 | 显示全部楼层
谢谢分享,下来看看效果怎么样
发表于 2024-4-17 09:02:00 | 显示全部楼层
icons 这个文件夹名称不支持,是啥原因?
发表于 2024-4-17 09:04:02 | 显示全部楼层
发表于 2024-4-17 11:43:07 | 显示全部楼层
可以建立个icon目录但是icons就不行了,(((φ(◎ロ◎;)φ)))
3万
 楼主| 发表于 2024-4-17 18:01:05 | 显示全部楼层
Samba share addon配置的问题,需要修改一下设置。https://bbs.hassbian.com/thread-16820-1-1.html
发表于 2024-4-18 10:59:52 | 显示全部楼层
dscao 发表于 2024-4-17 18:01
Samba share addon配置的问题,需要修改一下设置。https://bbs.hassbian.com/thread-16820-1-1.html ...
大佬,现在升级HA后,就不能显示qweather-card卡片了。这个有办法破吗?
GMT+8, 2026-1-12 10:32 , Processed in 1.652377 second(s), 13 queries , MemCached On.
