楼主: dscao
[插件集成] 和风天气完整配置版本2025.8.6
发表于 2024-3-22 13:07:44 | 显示全部楼层
谢谢分享
发表于 2024-3-22 15:26:43 | 显示全部楼层
mark, 学习一下
发表于 2024-3-24 23:04:14 | 显示全部楼层
萌新学习了
发表于 2024-3-26 00:03:06 | 显示全部楼层
谢谢分享,下来看看效果怎么样
发表于 2024-4-6 00:00:35 | 显示全部楼层
dscao 发表于 2024-3-19 15:40
这个版本有修改吗?或者下载不是最新版?
我看原来这处代码是 566行,你这里报错的是577行。原代码使用了t ...
实体又不可用了,插件版本2023.10.6
Core2024.3.3
Supervisor2024.03.1
日志:
[backcolor=var(--mdc-theme-surface,#fff)][color=var(--mdc-dialog-content-ink-color,rgba(0,0,0,.6))]日志: homeassistant.components.weather
来源: helpers/entity_platform.py:350
集成: 天气 ([color=var(--primary-color)]文档
, [color=var(--primary-color)]问题
首次发生: 2024年4月5日 12:50:35 (1 全部发生)
上次记录: 2024年4月5日 12:50:35
Error while setting up qweather platform for weatherTraceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 174, in _new_conn    conn = connection.create_connection(           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 72, in create_connection    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/socket.py", line 963, in getaddrinfo    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^socket.gaierror: [Errno -3] Try againDuring handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen    httplib_response = self._make_request(                       ^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 404, in _make_request    self._validate_conn(conn)  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1058, in _validate_conn    conn.connect()  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 363, in connect    self.sock = conn = self._new_conn()                       ^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 186, in _new_conn    raise NewConnectionError(urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f5577ecf4d0>: Failed to establish a new connection: [Errno -3] Try againDuring handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 486, in send    resp = conn.urlopen(           ^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen    retries = retries.increment(              ^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 592, in increment    raise MaxRetryError(_pool, url, error or ResponseError(cause))urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.qweather.com', port=443): Max retries exceeded with url: /weather/maonan-101282007.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f5577ecf4d0>: Failed to establish a new connection: [Errno -3] Try again'))During handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 350, in _async_setup_platform    await asyncio.shield(awaitable)  File "/config/custom_components/qweather/weather.py", line 137, in async_setup_entry    await data.async_update(dt_util.now())  File "/config/custom_components/qweather/weather.py", line 572, in async_update    hourly_summary = await self._hass.async_add_executor_job(self.get_forecast_minutely, self._fxlink)                     ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run    result = self.fn(*self.args, **self.kwargs)             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/config/custom_components/qweather/weather.py", line 484, in get_forecast_minutely    response = request('GET', url, headers=header)               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in request    return session.request(method=method, url=url, **kwargs)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request    resp = self.send(prep, **send_kwargs)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send    r = adapter.send(request, **kwargs)        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 519, in send    raise ConnectionError(e, request=request)requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.qweather.com', port=443): Max retries exceeded with url: /weather/maonan-101282007.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f5577ecf4d0>: Failed to establish a new connection: [Errno -3] Try again'))
发表于 2024-4-6 15:00:09 | 显示全部楼层
感谢大佬分享
发表于 2024-4-6 16:52:39 | 显示全部楼层
谢谢分享
3万
 楼主| 发表于 2024-4-7 08:52:39 | 显示全部楼层
Core2024.3.3
Supervisor2024.03.1
2024.1.4 Latest
Replace deprecated constants to fix warnings in HA 2024.1
论坛忘记更新了
发表于 2024-4-12 21:33:07 | 显示全部楼层
谢谢楼主的更新。
发表于 2024-4-14 13:31:50 | 显示全部楼层
感谢楼主的教程!
GMT+8, 2026-1-12 10:34 , Processed in 1.577365 second(s), 11 queries , MemCached On.
