楼主: dscao
[插件集成] 和风天气完整配置版本2025.8.6
发表于 2024-3-5 14:44:05 | 显示全部楼层
大佬。有没有github的地址?
发表于 2024-3-5 20:40:32 | 显示全部楼层
2023.9.9 适配新版 ha2023.9.0以上版本,新旧版本不兼容。
什么叫新旧版本不兼容
发表于 2024-3-5 21:40:14 | 显示全部楼层
Home Assistant 2021.12.7
的版本不支持啊?
发表于 2024-3-5 21:47:46 | 显示全部楼层
而且app上这里显示不出来数据,作者麻烦看一下
发表于 2024-3-6 22:46:42 | 显示全部楼层
不知道为什么我的ipad 无法显示 和风插件  ,其他都可以显示
cang
发表于 2024-3-9 22:19:08 | 显示全部楼层
又能学习了呵呵
cang
发表于 2024-3-10 21:34:15 | 显示全部楼层
那位大佬能拯救一下,小白一枚,整了一天了才看到插件,可是还是有一些问题,很多都显示不出来。
发表于 2024-3-12 19:13:17 | 显示全部楼层
正是需要的
发表于 2024-3-12 19:29:05 | 显示全部楼层
专门顶大佬
发表于 2024-3-17 01:05:45 | 显示全部楼层
很奇怪,家里的ha正常使用,办公室的ha添加后没有生成实体
日志如下:
Error while setting up qweather platform for weather
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 344, in _async_setup_platform
    await asyncio.shield(task)
  File "/config/custom_components/qweather/weather.py", line 137, in async_setup_entry
    await data.async_update(dt_util.now())
  File "/config/custom_components/qweather/weather.py", line 572, in async_update
    hourly_summary = await self._hass.async_add_executor_job(self.get_forecast_minutely, self._fxlink)
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/qweather/weather.py", line 484, in get_forecast_minutely
    response = request('GET', url, headers=header)
  File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 575, in request
    prep = self.prepare_request(req)
  File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 486, in prepare_request
    p.prepare(
  File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 368, in prepare
    self.prepare_url(url, params)
  File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 439, in prepare_url
    raise MissingSchema(
requests.exceptions.MissingSchema: Invalid URL 'None': No scheme supplied. Perhaps you meant https://None?
GMT+8, 2026-1-12 08:36 , Processed in 1.599243 second(s), 12 queries , MemCached On.
