楼主: roiff
[插件集成] (1123更新)支持百分比的射频窗帘(同步HK),谁用谁...
 火.. [复制链接]
发表于 2018-6-19 10:06:49 | 显示全部楼层
elvisl 发表于 2018-6-2 19:20
我在\\HASSIO\config\custom_components\cover以及\\HASSIO\config\components\cover
还有/home/homeassis ...
朋友你的问题解决了吗 我也是报这个错
发表于 2018-6-20 14:36:41 | 显示全部楼层
直接通过switch 曲线救国成功:
参考代码,沿用switch扫到的射频码,可以cover实现
发表于 2018-6-20 23:15:42 | 显示全部楼层
zjhzjh0521 发表于 2018-6-19 10:06
朋友你的问题解决了吗 我也是报这个错
还没有解决。。。
发表于 2018-6-22 10:00:35 | 显示全部楼层
大神我在群晖里部署正确,但是在树莓派里缺不成功怎么回事啊?日志错误018-06-22 08:33:25 ERROR (SyncWorker_11) [homeassistant.util.package] Unable to install package broadlink==0.8: Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0fx9_06o/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-scfe9qvi-record/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-0fx9_06o/pycryptodome/
2018-06-22 08:33:25 ERROR (MainThread) [homeassistant.requirements] Not initializing cover.rm_cover because could not install requirement broadlink==0.8
2018-06-22 08:33:25 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform cover.rm_cover: Could not install all requirements.
发表于 2018-7-17 10:02:02 | 显示全部楼层
谢谢菲神!!
发表于 2018-7-28 13:43:18 来自手机 | 显示全部楼层
ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform rm_cover Traceback (most recent call last):   File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform     SLOW_SETUP_MAX_WAIT, loop=hass.loop)   File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for     return fut.result()   File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result     raise self._exception   File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step     result = coro.send(None)   File "/usr/lib/python3.5/asyncio/coroutines.py", line 210, in coro     res = func(*args, **kw)   File "/home/homeassistant/.homeassistant/custom_components/cover/rm_cover.py", line 77, in async_setup_platform     device_config.get(CONF_POS_SENSOR),   File "/home/homeassistant/.homeassistant/custom_components/cover/rm_cover.py", line 113, in __init__     self._cmd_open = b64decode(cmd_open) if cmd_open else None   File "/usr/lib/python3.5/base64.py", line 88, in b64decode     return binascii.a2b_base64(s) binascii.Error: Incorrect padding 2018-07-28 05:28:45 WARNING (Thread-7) [netdisco.ssdp] Error fetching description at http://192.168.123.1:53681/rootDesc.xml
发表于 2018-7-28 13:45:17 来自手机 | 显示全部楼层
报错哦 这个是什么原因呢
发表于 2018-7-28 16:23:01 | 显示全部楼层
谢谢楼主分享
发表于 2018-8-11 10:11:34 | 显示全部楼层
非常感谢
发表于 2018-8-11 10:54:51 | 显示全部楼层
楼主,第300行开始应该由BUG _travel=0; _travel-=1; _travel==0,马上就-1了
if 判断改成 _travel <=0 合适?
GMT+8, 2026-1-16 12:22 , Processed in 1.492529 second(s), 12 queries , MemCached On.
