楼主: roiff
[插件集成] (1123更新)支持百分比的射频窗帘(同步HK),谁用谁...
 火.. [复制链接]
发表于 2018-6-1 15:05:52 | 显示全部楼层
难道还是因为配置文件放置的位置不对?
发表于 2018-6-1 15:07:02 | 显示全部楼层
roiff 发表于 2018-5-31 23:49
你肯定安装了好多次HA?
然后你用的群辉?搞不清楚文件了?
大概是这样吧,文件放好了,配置文件呢? ...
哈哈哈,被你说中了,基本是这样,不过我是用的树莓派3B,配置文件按照你的方法单独设置
switch:
  - platform: broadlink
    host: 192.168.1.5
    mac: 'B4:43:0D:AA:30:F7'
    timeout: 15
    switches:
      live_chandelier:
        friendly_name: "客厅灯"
        command_on: '6QpCAN8JCRYJFhYJCRYWCQkWFgkWCRYJFgkJFhYJCRYWCRYJCRYJFgkWFgkWCRYJCRYWCQkWFgkWCQkWFgkWCQkWCRYWCQ=='
        command_off: '6QpCAN8JCRYWCRYJCRYWCQkWFgkWCQkWCRYJFgkWCRYWCQkWFgkWCRYJFgkJFgkWFgkWCQkWFgkJFhYJFgkWCQkWFgkWCQ=='
      dinner_chandelier:
        friendly_name: "餐厅灯"
        command_on: '6QpCAN8JCRYWCQkWCRYWCRYJCRYWCRYJCRYWCRYJCRYWCQkWCRYWCRYJFgkJFhYJFgkWCRYJCRYWCRYJCRYWCQkWFgkWCQ=='
        command_off: '6QpCAN8JCRYJFhYJCRYWCQkWFgkWCRYJFgkWCQkWCRYJFgkWFgkWCQkWCRYJFhYJCRYWCRYJCRYJFhYJFgkJFhYJCRYJFg=='
      ambient_light:
        friendly_name: "氛围灯"
        command_on: '6QpCAN8JFgkWCRYJFgkWCRYJFgkJFhYJCRYJFgkWFgkWCRYJFgkWCRYJFgkJFhYJCRYWCRYJFgkWCRYJCRYJFgkWFgkJFg=='
        command_off: '6QpCAN8JFgkJFhYJFgkWCRYJFgkWCQkWCRYWCQkWCRYJFhYJFgkJFhYJCRYJFhYJCRYJFhYJFgkWCQkWCRYWCQkWFgkJFg=='
      kitchen_light:
        friendly_name: "厨房灯"
        command_on: '6QpCAN8JCRYWCQkWCRYJFgkWCRYWCRYJFgkJFgkWCRYWCQkWCRYJFhYJCRYWCRYJCRYJFhYJFgkWCRYJFgkWCRYJCRYJFg=='
        command_off: '6QpCAN8JFgkJFgkWCRYWCQkWCRYWCQkWFgkWCRYJCRYJFgkWCRYJFhYJFgkJFgkWFgkJFhYJFgkJFhYJCRYJFgkWFgkJFg=='
      downlight_light:
        friendly_name: "筒灯"
        command_on: '6QpCAN8JCRYWCRYJFgkWCRYJFgkJFhYJCRYJFgkWFgkWCQkWCRYJFhYJCRYJFhYJFgkWCQkWFgkJFgkWCRYJFhYJCRYJFg=='
        command_off: '6QpCAN8JFgkJFgkWCRYWCQkWFgkJFhYJFgkJFgkWFgkJFgkWCRYJFgkWCRYWCQkWFgkJFgkWCRYJFhYJFgkJFgkWCRYWCQ=='
cover:
  - platform: rm_cover
    host: 192.168.1.5
    covers:
        bedroom_cover:        travel_time: 8
        friendly_name: "客厅窗帘"
        command_open: '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'
        command_close: '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'
        command_stop: '6QDeAgQaBwUEKAQZBBgEGAQXBBgEFxIKBBgEFwUXBBgEFgUXBRYFFwUYBBcFFhMJBhUFFgcVEwgTCRMIBhYTChEKBBYGFwUVEwgTCqQWEwkFFhMJBRYGFgUWEwkTCAYWBRYTCBQIBhUUCAYXEQoSCBMJBRYTCQUWFAgFFxIJEwgGFQYWBhUGFgYVFAcHFQYVBxUGFQcVBhUHFRQHBhYGFQcUBxUHFAcVBxQHFgUVBxUHFBUHBhUHFAcVFQYVBxQHBxUWBRUHBxQHFQcUFQcUCKYVFAcHFRUGBhYGFQcVFAcUCAYVBxQVBxUHBhYTBwcVFAcUCBQHBxUUBwcVFAcGFxMIEwgGFQcUCBQGFQcVFAcHFQcUBxQHFQgTBxUHFBUHBxQHFQcUBxUHFAcVBxQHFQgTBxQIFBUGCBQHFAgVFAYVBxUGBxUUBxUHBxQHFgYUFQYVCqQVFAcHFRQHBxQHFQcUFQcUBwcVBxQVBxQHBxUUBwcUFQcWBhQHBxYTBwcUFQcGFRQIFAcIFAYVBxUGFQcUFQcHFAcVBxQHFQgTBxUHFBUHBxQHFQcUBxUHFAcUCBQHFAgUCBMIFBUGBxUHFAgUFAcVBxQHBxQVCBQHBxQHFAgUFQYVCKYUFgYGFRQIBhUIEwcVFAgUBwcUBxUUBxUHBhUVBwYVFAgUBxQIBhUUBwcWEwcHFRQHFQcGFQcVBxQHFQcUFAcHFQcUCBQIEwcVBxQHFRQHBxUHFAcVBxQHFAgUCBMIFAcUCBQHFBUIBhQHFQcUFQcUBxUHBxQVBxQHBxQIFAcUFQcUCaYUFAgGFRQIBhUHFAgUFAcUCAcUBxUVBhQIBhUUCAYVFAgUBxQHBxUUBwcWEwgHFBQHFQcGFgYVBxQHFQYVFAcHFQcUBxUHFAcVBxQHFRQHBxUHFAcUCBQHFAgVBhQIFAcUCBQHFBUHBxQIFAcUFQcUBxUHBxUUBxYFBxQIFAcVFAcUAAXcBxQVCAYUBxUHFA=='
检查配置后会显示配置无效
Invalid config for [cover.rm_cover]: [friendly_name] is an invalid option for [cover.rm_cover]. Check: cover.rm_cover->covers->bedroom_cover->friendly_name. (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.rm_cover/
如果像下面这样放在switch里面,虽然不报错,但是HA,HB,HK里都完全没显示。
switch:
    host: 192.168.1.5
    timeout: 15
    switches:
      live_chandelier:
      dinner_chandelier:
      ambient_light:
      kitchen_light:
      downlight_light:
        friendly_name: "筒灯"
    covers:
        bedroom_cover:
          travel_time: 8
教程狂人卓越贡献突出贡献
 楼主| 发表于 2018-6-2 01:00:34 | 显示全部楼层
switch:
  - pla ...
兄弟,我说你不是眼神有问题把。。。。。
教程狂人卓越贡献突出贡献
 楼主| 发表于 2018-6-2 01:01:56 | 显示全部楼层
switch:
  - pla ...
第一个配置,bedroom和下面的所有内容有一个缩进,不是和下面的平级的
第二个配置,cover和swich是平级的
cover:
    host: 192.168.10.XXX
你把cover写到swich下面了,当然什么都没有了
发表于 2018-6-2 01:54:15 | 显示全部楼层
第二个配置,cover和swich是平级的 ...
这次配置没问题了,但是HASS主页显示
“Invalid Config
The following components and platforms could not be set up:
· cover.rm_cover
Please chenk your config”
是因为没有找到rm_cover这个文件吗?
教程狂人卓越贡献突出贡献
 楼主| 发表于 2018-6-2 04:48:03 | 显示全部楼层
elvisl 发表于 2018-6-2 01:54
这次配置没问题了,但是HASS主页显示
“Invalid Config
The following components and platforms could n ...
文件没有拷贝进去
发表于 2018-6-2 19:20:45 | 显示全部楼层
roiff 发表于 2018-6-2 04:48
文件没有拷贝进去
我在\\HASSIO\config\custom_components\cover以及\\HASSIO\config\components\cover
还有/home/homeassistant/.homeassistant/custom_components/cover
这三个文件夹下面都放了你的rm_cover.py文件。
难道路径还不对?
发表于 2018-6-6 08:44:20 | 显示全部楼层
拜膜大神
发表于 2018-6-18 18:59:36 | 显示全部楼层
令狐鸣 发表于 2018-1-10 14:39
不知道我的杜亚什么问题,自带的射频遥控也只能1米内距离控制,超过就没用.rm_pro大概三米直接学遥控码也是 ...
杜亚电机433遥控器到底能有多少米有效距离阿?
发表于 2018-6-18 23:22:50 | 显示全部楼层
射频的?最后发现有根天线,拉出来射频距离就大了.
GMT+8, 2026-1-16 12:24 , Processed in 1.662547 second(s), 11 queries , MemCached On.
