楼主: dscao
[插件集成] ikuai多功能集成[2026.1.20] 和 openwrt[2025.12.31]简单控制集成
发表于 2023-9-20 13:47:51 | 显示全部楼层
dscao 发表于 2023-9-19 18:22
Home Assistant 2023.9.2
Supervisor 2023.09.2
Operating System 10.5
环境 docker HA2023.9.2
HACS下载最新的ikuai
之后重启HA,会卡在某个集成启动久久过不去
HA的集成界面下有很多集成显示“未加载”
删除ikuai后重启就变正常了
日志里没看到什么异常,就是慢
你卸载ikuai重启,再HACS安装 重启试试看能否复现
我昨天折腾了一晚上,大概是这样的情况
cmos
发表于 2023-9-27 14:56:49 | 显示全部楼层
感谢大佬,已经成功接入
发表于 2023-9-27 15:06:28 | 显示全部楼层
感谢楼主分享,我试试
发表于 2023-10-12 09:38:02 | 显示全部楼层
不行,安装失败,是不是还有什么地方要设置?docker ha,docker openwrt。
hhh. 手机认证
发表于 2023-10-31 16:48:23 | 显示全部楼层
大佬,集成提示未加载,再次添加提示:“无法加载配置向导: {"message":"Invalid handler specified"}”
Home Assistant 2023.10.5
Supervisor 2023.10.1
Operating System 11.1
前端版本: 20231005.0 - latest
ikuai  3.7.6 x64 Build202309081651
日志:
Home Assistant Core
2023-10-31 16:29:29.294 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration ikuai which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-31 16:29:36.917 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration ikuai: Unable to import component: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
File "/config/custom_components/ikuai/__init__.py", line 8, in <module>
File "/config/custom_components/ikuai/data_fetcher.py", line 17, in <module>
ImportError: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
2023-10-31 16:35:18.775 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration ikuai: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
2023-10-31 16:35:22.481 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration ikuai: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
2023-10-31 16:35:24.888 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration ikuai: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
2023-10-31 16:46:36.092 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration ikuai: cannot import name 'LOGIN_URL' from 'custom_components.ikuai.const' (/config/custom_components/ikuai/const.py)
3万
 楼主| 发表于 2023-10-31 18:59:40 | 显示全部楼层
Ho ...
你是下载附件的吗?
hhh. 手机认证
发表于 2023-11-1 13:19:07 | 显示全部楼层
dscao 发表于 2023-10-31 18:59
你是下载附件的吗?
我是在hacs中安装的,在home assistant 2023.10.1这个版本中是可以使用的,随后更新版本到2023.10.3,开始无法使用。
我在你github.com/dscao/ikuai中看到的版本信息就是1.3.1所以就在hacs中安装了。
论坛附件和hacs中的不一样的吗?我下载试试。
更新:在论坛下载的附件,是没问题的。
大佬有一个问题请教一下,仪表盘开始的时候我把卡片都删除了,现在无法自动添加实体,该怎么办?  感谢
发表于 2023-11-3 22:53:34 | 显示全部楼层
新手 学习学习
发表于 2023-11-8 17:26:18 | 显示全部楼层
3万
 楼主| 发表于 2023-11-8 19:52:49 | 显示全部楼层
WuY-X 发表于 2023-11-8 17:26
大佬,这几条状态更新频率高,怎么能不让他在日志里面显示啊
可以在集成的配置选项中设置设备请求刷新时间长一点。 如果只是想不占用太多的日志记录,可以试一下这个配置:https://www.home-assistant.io/in ... r/#configure-filter
GMT+8, 2026-2-1 03:58 , Processed in 1.595478 second(s), 13 queries , MemCached On.
