楼主: dscao
[插件集成] ikuai多功能集成[2026.1.20] 和 openwrt[2025.12.31]简单控制集成
发表于 2023-6-2 20:31:49 | 显示全部楼层
dscao 发表于 2023-6-1 22:23
哪个版本?哪个集成? 能否提供一下日志?
我一直是正式版的最新版,没有发现问题。 ...
就是最新测试版才出问题。正式版正常。
发表于 2023-6-3 12:09:18 | 显示全部楼层
这是高手
发表于 2023-6-3 23:24:21 | 显示全部楼层
更新到ha 6.0的测试版后开始报错了
此错误来自自定义集成。
Logger: custom_components.ikuai
Source: helpers/update_coordinator.py:262
Integration: ikuai (documentation, issues)
First occurred: 22:08:27 (60 occurrences)
Last logged: 23:23:18
Error fetching ikuai data: Passing coroutines is forbidden, use tasks explicitly.
3万
 楼主| 发表于 2023-6-5 16:20:35 | 显示全部楼层
baobaobuku 发表于 2023-6-3 23:24
更新到ha 6.0的测试版后开始报错了
此错误来自自定义集成。
感谢反馈,已修复,等下一正式版发布我才能测试。
有时间请重新下载附件帮测试一下。
发表于 2023-6-5 16:51:40 | 显示全部楼层
有时间请重新下载附件帮测试一下。 ...
已正常!感谢大佬
发表于 2023-6-5 23:35:05 | 显示全部楼层
大佬,我是istoreos的openwrt,ha装在二级路由的群晖,安装之后也是一直显示:正在重试设置:none。
日志提示如下:
此错误来自自定义集成。
Logger: custom_components.openwrt
Source: custom_components/openwrt/data_fetcher.py:76
Integration: openwrt (documentation, issues)
First occurred: 23:24:22 (4 occurrences)
Last logged: 23:25:15
Unexpected error fetching openwrt data: "name='sysauth', domain=None, path=None"
  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/homeassistant/helpers/update_coordinator.py", line 258, in _async_refresh
    self.data = await self._async_update_data()
  File "/var/packages/HomeAssistant/home/.homeassistant/custom_components/openwrt/__init__.py", line 123, in _async_update_data
    sysauth = await self.get_access_token()
  File "/var/packages/HomeAssistant/home/.homeassistant/custom_components/openwrt/__init__.py", line 112, in get_access_token
    self._token = await self._fetcher._login_openwrt()
  File "/var/packages/HomeAssistant/home/.homeassistant/custom_components/openwrt/data_fetcher.py", line 93, in _login_openwrt
    resdata = await self._hass.async_add_executor_job(self.requestpost_cookies, url, header, body)
  File "/var/packages/python311/target/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/var/packages/HomeAssistant/home/.homeassistant/custom_components/openwrt/data_fetcher.py", line 76, in requestpost_cookies
    resdata = responsedata.cookies["sysauth"]
  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/requests/cookies.py", line 334, in __getitem__
    return self._find_no_duplicates(name)
  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/requests/cookies.py", line 413, in _find_no_duplicates
    raise KeyError(f"name={name!r}, domain={domain!r}, path={path!r}")
KeyError: "name='sysauth', domain=None, path=None"
3万
 楼主| 发表于 2023-6-6 11:02:55 | 显示全部楼层
openwrt版本较多,其它openwrt的数据参数与我用的 https://github.com/coolsnowwolf/lede 编译的openwrt 有些差异,只能自己按数据内容格式修改一下代码才能用。
发表于 2023-6-7 11:29:36 | 显示全部楼层
大佬有开源计划吗, 想基于此代码实现ikuai更多逻辑功能
3万
 楼主| 发表于 2023-6-7 13:03:01 | 显示全部楼层
ha的集成本来就是源代码形式的,开不开都是开源的。
发表于 2023-6-7 15:14:52 | 显示全部楼层
明白 只是觉得有代码版本管理方便一些
GMT+8, 2026-2-1 02:33 , Processed in 1.495303 second(s), 9 queries , MemCached On.
