楼主: XCray
[修仙教程] 【大功告成】23年7月更:M401A/CM311-1a盒子Armbian安装极其简单
发表于 2022-8-4 01:56:24 | 显示全部楼层
有一个问题 盒子重启以后网卡会一直获取不到 ip 要重插网线才可以
你们是不是 怎么办
发表于 2022-8-4 02:44:12 | 显示全部楼层
运行一段时间 一个小时左右 随机的  又GG了  好像每次运行一段时间都会 而且不重启
目前情况还是不可用
[ 2877.045586] Unable to handle kernel paging request at virtual address fffffffffffffff8
[ 2877.049954] Mem abort info:
[ 2877.052730]   ESR = 0x96000045
[ 2877.055740]   EC = 0x25: DABT (current EL), IL = 32 bits
[ 2877.061001]   SET = 0, FnV = 0
[ 2877.064017]   EA = 0, S1PTW = 0
[ 2877.067123] Data abort info:
[ 2877.069968]   ISV = 0, ISS = 0x00000045
[ 2877.073765]   CM = 0, WnR = 1
[ 2877.076697] swapper pgtable: 4k pages, 39-bit VAs, pgdp=00000000095b1000
[ 2877.083339] [fffffffffffffff8] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
[ 2877.091976] Internal error: Oops: 96000045 [#1] PREEMPT SMP
[ 2877.097473] Modules linked in: bnep btusb btrtl btintel btbcm bluetooth xt_nat xt_tcpudp veth xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nft_counter xt_addrtype nft_compat nf_tables nfnetlink br_netfilter bridge rfkill cpufreq_conservative cpufreq_userspace cpufreq_powersave zram panfrost gpu_sched meson_ir meson_vdec(C) meson_gxbb_wdt videobuf2_dma_contig dw_hdmi_cec v4l2_mem2mem tcp_bbr sch_fq nfsd auth_rpcgss nfs_ssc lockd grace sunrpc ip_tables x_tables
[ 2877.143370] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G         C        5.10.134-ophub #1
[ 2877.151301] Hardware name: Amlogic Meson G12A U200 Development Board (DT)
[ 2877.158031] pstate: 20000005 (nzCv daif -PAN -UAO -TCO BTYPE=--)
[ 2877.163989] pc : run_rebalance_domains+0x2c/0x300
[ 2877.168639] lr : efi_header_end+0xf8/0x29c
[ 2877.172690] sp : ffffffc01188be40
[ 2877.175968] x29: 0000000000000000 x28: ffffffc0114f50c0
[ 2877.181229] x27: 0000000000000007 x26: ffffff80000aaa00
[ 2877.186490] x25: 0000000000000007 x24: 0000000000000101
[ 2877.191752] x23: ffffffc0114f50f8 x22: ffffffc0114cc768
[ 2877.197013] x21: ffffffc0112b9faf x20: 0000000000000038
[ 2877.202274] x19: 0000000000000080 x18: 0000000000000000
[ 2877.207535] x17: 00000000000000b9 x16: 0000000000000001
[ 2877.212796] x15: 0000000000000010 x14: 0000000000000010
[ 2877.218058] x13: 00000000001a584c x12: 0000000029aa900b
[ 2877.223319] x11: 0014574fbf9f7080 x10: 0000000000000101
[ 2877.228580] x9 : 000000000004299b x8 : e5ba63e5fe393b00
[ 2877.233842] x7 : 0000000100000016 x6 : ffffffc011c0ba6c
[ 2877.239103] x5 : ffffffc011c0ba6c x4 : 0000000000000000
[ 2877.244364] x3 : 000000000000000f x2 : 0000000000000000
[ 2877.249625] x1 : ffffffc0112b9faf x0 : ffffffc0114f50f8
[ 2877.254887] Call trace:
[ 2877.257306]  run_rebalance_domains+0x2c/0x300
[ 2877.261619] Code: a90657f6 a9074ff4 d5384108 f9424d08 (f81f83a8)
[ 2877.267654] ---[ end trace 080824678dbce78d ]---
[ 2877.272225] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[ 2877.279040] SMP: stopping secondary CPUs
[ 2877.282922] Kernel Offset: disabled
[ 2877.286370] CPU features: 0x0240002,20002004
[ 2877.290594] Memory Limit: none
[ 2877.293617] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-8-4 06:46:39 来自手机 | 显示全部楼层
fallendawn 发表于 2022-8-4 01:31
Armbian_22.08.0_Aml_s905l3a_bullseye_5.4.207 没有找到  实测 5.10 成功确实奇了怪了 我还是以为是别人说 ...
我的是u盘启动也用e900v22c的uboot,u200的也能用,但是要差一些(usb会复位几次才起来)。
网卡能识别但获取不到ip地址需要重插网线的问题比较普遍,多种盒子都有,好像是内核版本的问题。5.4没问题,5.15我自己用也有这个问题,看你的描述5.10也不行。换内核吧。
~~~~~~~~可能e900v22c的uboot也有些问题。我之前用u200的uboot从来没碰到过网卡识别出来但无法获取IP地址的问题,我之前用了好几天的5.18的内核,这两天换e900v22c的uboot也有这毛病了
另外,最好在路由器上为盒子固定ip地址。
kernel panic的问题怀疑也是内核版本的锅,我用5.15.58已经持续运行一天了,没出过这现象,之前用5.4.207也很稳。再之前u盘启动用5.18内核也没这症。
发表于 2022-8-4 11:32:17 | 显示全部楼层
网卡能识别 ...
你的Armbian_22.08.0_Aml_s905l3a_bullseye_5.4.207是自己云编译的?
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-8-4 12:53:59 | 显示全部楼层
是的
发表于 2022-8-5 07:15:48 | 显示全部楼层
感谢楼主无私奉献,折腾精神永存
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-8-5 10:31:24 | 显示全部楼层
你们是不是 怎么办 ...
你再试试我的新方案,见一楼主贴。我自己用着已经挑不出毛病了
发表于 2022-8-5 13:58:28 | 显示全部楼层
完了 砖了 现在怎么都不能进线刷模式   短接都没用
现在都是一启动就panic 而且不能从usb启动了
唯一能操作的就是开机的时候uboot可以暂停 怎办么
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-8-5 15:32:39 来自手机 | 显示全部楼层
短接多试几下,我也碰到过短接一两下没反应的情况。
走到哪一步报错的?ttl日志贴出来看看?
如果进入了u-boot提示符状态,可以输入help,会列出很多命令出来,start usb也许能从U盘启动。
发表于 2022-8-5 16:30:27 | 显示全部楼层
ha出了新版本,支持蓝牙,这么好的盒子,蓝牙用不了可太可惜了,大佬可以试着折腾蓝牙了。音频输出倒是有解决方案了
GMT+8, 2025-12-16 19:44 , Processed in 0.643805 second(s), 10 queries , MemCached On.
