楼主: jjcs
[技术探讨] 请问各位大佬,目前esp32c3能接入esphome吗
发表于 2022-8-15 20:36:38 | 显示全部楼层
sorrypqa 发表于 2022-8-15 20:31
一般是刷完后,通过手机WIFI连接到这个设备,配置好联网,电脑登录路由器并在DHCP里静态分配好IP地址,通 ...
20:32:33        [D]        [modbus_controller:032]
Modbus command to device=1 register=0x4000 countdown=0 no response received - removed from send queue
20:32:41        [D]        [modbus_controller:032]
Modbus command to device=1 register=0x2000 countdown=0 no response received - removed from send queue
20:32:42        [D]        [modbus_controller:032]
Modbus command to device=1 register=0x200E countdown=0 no response received - removed from send queue
20:32:43        [D]        [modbus_controller:032]
20:32:51        [D]        [modbus_controller:032]
20:32:52        [D]        [modbus_controller:032]
20:32:53        [D]        [modbus_controller:032]
登录esp后一直是提示这个
发表于 2022-8-15 21:28:17 | 显示全部楼层
adamjensen 发表于 2022-8-15 20:32
不一样,modbus_controller下的地址是电表的485地址,switch下面的地址是寄存器地址,DDSU666的清零寄存 ...
原来如此,多谢指教!
发表于 2022-8-15 22:11:30 | 显示全部楼层
Modbus command to device=1 register=0x4000 countdown=0 no re ...
线没接反的话,看看是不是电表没改成Modbus协议,长按按钮就可以改
发表于 2022-9-11 17:25:47 | 显示全部楼层
不错,用按键改实在是太方便了,谢谢!
发表于 2022-10-4 20:01:48 | 显示全部楼层
esphome:
  platformio_options:
    board_build.flash_mode: dio
    board_build.mcu: esp32c3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
    version: '2.0.2'
    platform_version: '4.2.0'
目前arduino 只有2.02可以编译通过,最新版2.0.5生成BIN文件命令变了,编译通过但是生成不了BIN文件
发表于 2022-10-28 10:16:05 | 显示全部楼层
sorrypqa 发表于 2022-6-12 12:25
1、一开始也怀疑买的ESP32_C3_13U是有问题,还特地跑去立创商城买了几个,刷了还是老样子,但刷tasmota固 ...
是用这个Upgrade by file upload的吗?
发表于 2023-3-17 08:10:41 | 显示全部楼层
我跟你一样,一直看不出什么问题,后面你解决了吗?
GMT+8, 2026-1-17 11:52 , Processed in 0.945708 second(s), 10 queries , MemCached On.
