楼主: XCray
[修仙教程] YeeLight蓝牙调光开关——最新最完美的用法,纯HA内置组件!
 火.. [复制链接]
发表于 2022-6-29 14:17:57 | 显示全部楼层
ble_monitor 也很灵敏。
发表于 2022-6-30 00:09:14 | 显示全部楼层
什么时候才有楼主这么优秀
发表于 2022-6-30 09:52:44 | 显示全部楼层
大佬牛逼啊
发表于 2022-7-10 00:39:00 | 显示全部楼层
Connection in progress...
Successful connection!
Authentication in progress...
  File "/root/esp/get_beacon_key.py", line 159, in <module>
    main(sys.argv)
  File "/root/esp/get_beacon_key.py", line 155, in main
    get_beacon_key(mac, product_id)
  File "/root/esp/get_beacon_key.py", line 113, in get_beacon_key
    peripheral.writeCharacteristic(HANDLE_AUTH_INIT, MI_KEY1, "true")
  File "/usr/local/lib/python3.10/dist-packages/bluepy/btle.py", line 543, in writeCharacteristic
    return self._getResp('wr')
  File "/usr/local/lib/python3.10/dist-packages/bluepy/btle.py", line 407, in _getResp
    resp = self._waitResp(wantType + ['ntfy', 'ind'], timeout)
  File "/usr/local/lib/python3.10/dist-packages/bluepy/btle.py", line 368, in _waitResp
    raise BTLEGattError("Bluetooth command failed", resp)
bluepy.btle.BTLEGattError: Bluetooth command failed (code: 3, error: Attribute can't be written)
! Press the "Pair" button at the dimmer...
Connecting... done
Authenticating...Traceback (most recent call last):
  File "/root/esp/yeelight-dimmer-python/demo.py", line 93, in <module>
    main()
  File "/root/esp/yeelight-dimmer-python/demo.py", line 82, in main
    if not dimmer.auth():
  File "/root/esp/yeelight-dimmer-python/YeelightDimmer.py", line 124, in auth
    self.peripheral.writeCharacteristic(self.HANDLE_AUTH_INIT, self.XIAOMI_KEY1, True)
了解下无法获取密钥无头绪
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-7-10 06:07:13 | 显示全部楼层
前几天刚说过这个问题,看56-58楼
发表于 2022-7-10 10:51:54 | 显示全部楼层
XCray 发表于 2022-7-10 06:07
前几天刚说过这个问题,看56-58楼
好的谢谢
发表于 2022-9-12 12:11:45 | 显示全部楼层
请教下怎么写按下旋转来无极调节灯泡色温的自动化呢?HA自动化灯光服务里面貌似没有色温的递增递减服务
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-9-12 15:27:17 | 显示全部楼层
iamhyde 发表于 2022-9-12 12:11
请教下怎么写按下旋转来无极调节灯泡色温的自动化呢?HA自动化灯光服务里面貌似没有色温的递增递减服务 ...
这不是自动化的问题呀!就好比我想弄个自动化,把别人户头上的钱自动转到我的账号里一样。
你在ha里是怎么调整色温的?能调就可以用自动化实现,不能调就是接入方式的问题。
发表于 2022-10-12 16:01:29 | 显示全部楼层
这篇帖子让人收益非浅特别是13#楼楼主详细介绍了过程,非常感谢,核心思路就是获取24的key然后拼接成32位,最后用楼主给的ESPhome配置文件加蓝牙MAC地址和KEY生成传感器,ESPHOMe接入HA。非常实用,试想下找个方便的位置贴一个旋钮开关,家里接入HA的调光灯秒操作就问爽不爽。
发表于 2022-10-12 16:50:50 | 显示全部楼层
楼主试过易来的ble按键遥控吗,方法是不是类似的。
GMT+8, 2026-1-14 19:14 , Processed in 0.514259 second(s), 12 queries , MemCached On.
