楼主: muxiachuixue
[学习笔记] 手把手教你解决HACS无法访问github问题:无需科学上网
发表于 2021-12-27 12:49:17 | 显示全部楼层
好的 谢谢
发表于 2021-12-27 19:31:26 | 显示全部楼层
这个实用,厉害了我的哥
发表于 2022-1-1 22:32:47 | 显示全部楼层
感谢分享 mark一下
发表于 2022-1-4 23:51:03 | 显示全部楼层
收藏!!!!
发表于 2022-1-5 07:30:43 | 显示全部楼层
感觉是一个好方法,试一下
发表于 2022-1-8 02:34:41 | 显示全部楼层
MAKEYIXIAchageyan
发表于 2022-1-10 17:01:26 | 显示全部楼层
感谢分享,今天失效了过来看看果然更新了
发表于 2022-1-11 00:24:23 | 显示全部楼层
emmm…发现hacs里面的helper 几个文件夹直接没了…
 楼主| 发表于 2022-1-11 08:25:45 | 显示全部楼层
更新最新的脚本,然后重启两次HA 即可
发表于 2022-1-14 13:28:00 | 显示全部楼层
新的脚本还是会报错
2022-01-14 13:26:48 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.v1_cloud_911052 does not support any media_player features
2022-01-14 13:26:57 ERROR (MainThread) [custom_components.hacs] 'str' object has no attribute 'items'
  File "/config/custom_components/hacs/base.py", line 462, in async_github_api_method
    return await method(*args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/namespaces/contents.py", line 62, in get
    response.data = GitHubContentsModel(response.data)
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/models/base.py", line 35, in __init__
    for key, value in self._raw_data.items():
AttributeError: 'str' object has no attribute 'items'
2022-01-14 13:26:57 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/config/custom_components/hacs/base.py", line 562, in startup_tasks
    await self.async_load_default_repositories()
  File "/config/custom_components/hacs/base.py", line 706, in async_load_default_repositories
    for item in await self.async_github_get_hacs_default_file(HacsCategory.REMOVED):
  File "/config/custom_components/hacs/base.py", line 441, in async_github_get_hacs_default_file
    response = await self.async_github_api_method(
  File "/config/custom_components/hacs/base.py", line 478, in async_github_api_method
    raise HacsException(_exception)
custom_components.hacs.exceptions.HacsException: 'str' object has no attribute 'items'
GMT+8, 2026-2-15 00:01 , Processed in 0.011573 second(s), 3 queries , Redis On.
