楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
发表于 2018-3-19 20:35:59 | 显示全部楼层
polofun 发表于 2018-3-19 20:15
  File "/srv/homeassistant/bin/hass", line 11, in
    sys.exit( ...
貌似你的HA安装有问题。
你在HA安装过程中出错了吗? (有无 Error 或 Failed 之类的提示信息)
试试重装HA:
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip3 install --trusted-host mirrors.ustc.edu.cn -U homeassistant==0.64.3
pip3 install --trusted-host mirrors.ustc.edu.cn aiohttp_cors==0.6.0
发表于 2018-3-19 20:45:36 | 显示全部楼层
MAPGPS 发表于 2018-3-19 20:35
貌似你的HA安装有问题。
(homeassistant) homeassistant@localhost:/home/1$ pip3 install --trusted-host mirrors.ustc.edu.cn -U homeassistant==0.64.3
Requirement already up-to-date: homeassistant==0.64.3 in /srv/homeassistant/lib/python3.5/site-packages
Requirement already up-to-date: pytz>=2017.02 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: certifi>=2017.4.17 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: astral==1.5 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: attrs==17.4.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: pip>=8.0.3 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: typing<4,>=3 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: jinja2>=2.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: pyyaml<4,>=3.11 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: requests==2.18.4 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: async-timeout==2.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: chardet==3.0.4 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: voluptuous==0.11.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: yarl==1.1.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: aiohttp==2.3.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.64.3)
Requirement already up-to-date: MarkupSafe>=0.23 in /srv/homeassistant/lib/python3.5/site-packages (from jinja2>=2.10->homeassistant==0.64.3)
Requirement already up-to-date: urllib3<1.23,>=1.21.1 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.18.4->homeassistant==0.64.3)
Requirement already up-to-date: idna<2.7,>=2.5 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.18.4->homeassistant==0.64.3)
Requirement already up-to-date: multidict>=4.0 in /srv/homeassistant/lib/python3.5/site-packages (from yarl==1.1.0->homeassistant==0.64.3)
Requirement already up-to-date: idna-ssl>=1.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==2.3.10->homeassistant==0.64.3)
(homeassistant) homeassistant@localhost:/home/1$ pip3 install --trusted-host mirrors.ustc.edu.cn aiohttp_cors==0.6.0
Requirement already satisfied: aiohttp_cors==0.6.0 in /srv/homeassistant/lib/python3.5/site-packages
Requirement already satisfied: aiohttp>=1.1 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp_cors==0.6.0)
Requirement already satisfied: async-timeout>=1.2.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp>=1.1->aiohttp_cors==0.6.0)
Requirement already satisfied: yarl>=1.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp>=1.1->aiohttp_cors==0.6.0)
Requirement already satisfied: chardet in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp>=1.1->aiohttp_cors==0.6.0)
Requirement already satisfied: idna-ssl>=1.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp>=1.1->aiohttp_cors==0.6.0)
Requirement already satisfied: multidict>=4.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp>=1.1->aiohttp_cors==0.6.0)
Requirement already satisfied: idna>=2.0 in /srv/homeassistant/lib/python3.5/site-packages (from yarl>=1.0.0->aiohttp>=1.1->aiohttp_cors==0.6.0)
没有显示错误,但是以输入HASS就出现刚刚的错误
发表于 2018-3-19 21:05:03 | 显示全部楼层
polofun 发表于 2018-3-19 20:45
(homeassistant) homeassistant@localhost:/home/1$ pip3 install --trusted-host mirrors.ustc.edu.cn -U ...
你先卸载HA:
pip3 uninstall homeassistant
再重新装HA。
如果还不行的话,请直接用网友做好的HA镜像img:
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=1489
发表于 2018-3-21 09:53:35 来自手机 | 显示全部楼层
这个可以有
发表于 2018-3-21 11:27:46 | 显示全部楼层
学习!!!!!
v2cd
发表于 2018-3-21 22:05:06 | 显示全部楼层
fdgsdgdsgdsfhsjsjsk
发表于 2018-3-22 11:16:01 来自手机 | 显示全部楼层
学习学习
发表于 2018-3-23 10:22:48 | 显示全部楼层
niubility老铁你牛
发表于 2018-3-23 11:16:47 | 显示全部楼层
我曾经这么玩过一段时间,但是因为手机的WIFI受制于节能影响,关屏幕的时候wifi延时会非常高。所以后来我又换回虚拟机跑了。如果能接受控制开关的时候将近1秒钟的延时,倒也是无所谓的。可能是我刷的ROM的问题。BMPS的修改对我没有起多大作用。
发表于 2018-3-23 13:34:04 | 显示全部楼层
eastwoodnet 发表于 2018-3-23 11:16
我曾经这么玩过一段时间,但是因为手机的WIFI受制于节能影响,关屏幕的时候wifi延时会非常高。所以后来我又 ...
是跟手机ROM有关。我是把WiFi配置参数全研究了一遍,才找到BMPS参数对我的手机起作用。
其实有个万能的方法:
就是始终激活WiFi的数据传输。你在手机的终端里PING外头时,会发现延迟很小,而从外头PING手机则延迟很大。
在我发现BMPS参数之前, 就是用的这个原理,写了个Java小程序在手机后台跑,每隔100ms往外发个UDP包。
这样WiFi延迟就很小了,才几十ms。
虽然方法不太完美,但确实有效。
GMT+8, 2025-12-20 11:52 , Processed in 1.305620 second(s), 10 queries , MemCached On.
