楼主: yanwuyue
[插件集成] 美的GA014控制中央空调(2020-04-01更新)
发表于 2024-4-6 16:49:35 | 显示全部楼层
每个内机都需要一个网络模块, 但是GA014S只需要一个
发表于 2024-4-13 13:53:56 | 显示全部楼层
楼主,现在用不了了
The ga014 custom integration is using deprecated climate auxiliary heater
此项在版本 2024.10.0 中无法工作。请在升级之前解决。
The custom integration ga014 implements the is_aux_heat property or uses the auxiliary heater methods in a subclass of ClimateEntity.
Please report it to the author of the ga014 integration.
Once an updated version of ga014 is available, install it and restart Home Assistant to fix this issue.
GMT+8, 2026-1-15 03:11 , Processed in 0.755681 second(s), 9 queries , MemCached On.
