楼主: skyzhishui
[插件集成] [1206更新]lifesmart设备接入hass整合插件
发表于 2022-3-27 18:04:58 | 显示全部楼层
Logger: homeassistant
Source: components/dhcp/__init__.py:154
First occurred: 17:40:52 (1 occurrences)
Last logged: 17:40:52
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 117, in _initialize
    await watcher.async_start()
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 275, in async_start
    self._async_process_device_state(state)
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 300, in _async_process_device_state
    self.async_process_client(ip_address, hostname, _format_mac(mac_address))
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 154, in async_process_client
    made_ip_address = make_ip_address(ip_address)
  File "/usr/local/lib/python3.9/ipaddress.py", line 53, in ip_address
    raise ValueError('%r does not appear to be an IPv4 or IPv6 address' %
ValueError: '--' does not appear to be an IPv4 or IPv6 address
请问这是什么问题?盼回复
发表于 2022-4-1 15:02:31 | 显示全部楼层
hub记录器:homeassistant.setup
来源:setup.py :298 第一次出现: 14:30: 22 (13次出现) 最后记录: 14:30: 22
无法为平台 lifesmart.binary_sensor 准备设置:找不到平台(无法从“homeassistant.components.binary_sensor”(/usr/src/homeassistant/homeassistant/components/binary_sensor/__init__.py)导入名称“BinarySensorDevice”)。
无法为平台 lifesmart.light 准备设置:找不到平台(无法从“homeassistant.components.light”(/usr/src/homeassistant/homeassistant/components/light/__init__.py)导入名称“Light”)。
无法为平台 lifesmart.climate 准备设置:找不到平台(无法从“homeassistant.components.climate”(/usr/src/homeassistant/homeassistant/components/climate/__init__.py)导入名称“ClimateDevice”)。
无法为平台 lifesmart.switch 准备设置:找不到平台(无法从“homeassistant.components.switch”(/usr/src/homeassistant/homeassistant/components/switch/__init__.py)导入名称“SwitchDevice”)。
想请问一下我在git上看到有人说需要将xxxDEVICE改成XXXEntity,是需要整个项目都改吗?还是单改binary_sensor.py中的即可?另外想问问这些问题是不是就是DEVICE名称造成的?light是否需要加上entity?
根据github上大佬修改后的代码指引,我更新了本地代码,报错不在了,然而还是没有办法正确在集成里搜索添加到lifesmart,已检查\custom_components\lifesmart下的"domain": "lifesmart",和"version": "20.12.16"都有添加,但联想到上面的报错地址为“/usr/src/homeassistant/homeassistant/components/binary_sensor/__init__.py”,在components后面并没有显示出lifesmart,不知道是否和这个有关,还是我换的新网关不支持ha。 lifesmart -可用.zip (12.35 KB, 下载次数: 21)
又看了几遍帖子,才发现是我的太粗心,所有开关需要手动添加,我再去好好看是添加在哪里的
又过了一天,发现开发者模式中可以找到对应的设备,但是是只读模式,应该在customize.yaml中添加配置,但是需要特定格式,查找ing
已经搞定了,原来只需要直接添加到homekit就可以了
紧急提醒,homeassistant千万别升级到2022.4.2及以上,因为fan不支持speed_low,speed_high模式,改为百分比数值模式了。
暂时只能回滚版本,我在升级前做了备份,但是我还在寻找版本回滚的方式
发表于 2022-4-3 17:14:16 | 显示全部楼层
厉害啊大佬,加油
发表于 2022-4-21 00:35:13 | 显示全部楼层
看看怎么用
发表于 2022-4-21 13:44:10 | 显示全部楼层
发表于 2022-4-22 00:31:17 | 显示全部楼层
发表于 2022-4-22 11:49:30 | 显示全部楼层
谢谢分享,学习一下。
发表于 2022-4-23 16:04:33 | 显示全部楼层
aprking 发表于 2022-1-5 18:50
原源代码没添加COSS插座支持,这个压缩包增加进去了,并整合进去了贝小怪大佬的灯光修正。再次修正了流光开 ...
实体里面没有超级碗,只有两个感应器,是要自己添加吗?我把屏蔽的值0011也改了的
发表于 2022-4-23 19:34:43 | 显示全部楼层
超级碗遥控调用服务无效。。。为啥没日志呢
发表于 2022-4-23 20:05:44 | 显示全部楼层
fzbxb 发表于 2021-12-19 11:43
我改好了,新的homeassistant要求异步,我把light的请求改写成了aiohttp就可以用了。看下请求aiohttp方式 ...
遥控调用服务有效么
GMT+8, 2026-1-16 04:49 , Processed in 1.673333 second(s), 14 queries , MemCached On.
