楼主: neroxps
HASSIO 切换HA版本脚本
 楼主| 发表于 2019-5-31 21:28:08 | 显示全部楼层
xu791041421 发表于 2019-5-31 01:43
19-05-30 16:32:39 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-o                     ...
耐心等待,正在pull 镜像 网速慢要等等。
 楼主| 发表于 2019-5-31 21:28:25 | 显示全部楼层
plutosherry 发表于 2019-5-31 14:39
弱弱的问一句,带日志发帖会不会被加分啊?
可能会被扣分喔~
发表于 2019-5-31 22:25:03 | 显示全部楼层
neroxps 发表于 2019-5-31 21:28
可能会被扣分喔~
发表于 2019-6-7 13:37:57 | 显示全部楼层
非常感谢  学习了  之前试了其他方法都没成功
发表于 2019-6-8 18:33:27 | 显示全部楼层
0.94.0切0.91.0报错误404,无奈
 楼主| 发表于 2019-6-10 09:03:30 | 显示全部楼层
是的,92.0应该是改了前端的代码,所以无法降级到91以后。
发表于 2019-6-25 11:11:44 | 显示全部楼层
6666666666666
发表于 2019-7-11 07:50:53 | 显示全部楼层
楼主降级失败
19-07-10 23:42:47 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-10 23:42:47 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-10 23:42:47 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-10 23:42:47 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-10 23:42:47 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
19-07-10 23:43:02 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-10 23:43:02 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-10 23:43:02 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-10 23:43:02 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-10 23:44:41 WARNING (MainThread) [hassio.api.security] No API token provided for /homeassistant/updat
19-07-10 23:50:12 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93
19-07-10 23:50:12 INFO (SyncWorker_2) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.95.4 to homeassistant/qemux86-64-homeassistant:0.93
19-07-10 23:50:12 INFO (SyncWorker_2) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.93.
19-07-10 23:50:20 ERROR (SyncWorker_2) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.93 -> 404 Client Error: Not Found ("manifest for homeassistant/qemux86-64-homeassistant:0.93 not found").
19-07-10 23:50:20 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
{"result": "error", "message": "Unknown Error, see logs"}
 楼主| 发表于 2019-7-11 09:54:46 | 显示全部楼层
Wavelet 发表于 2019-7-11 07:50
楼主降级失败
19-07-10 23:4 ...
homeassistant 没有一个版本号叫 homeassistant/qemux86-64-homeassistant tag 0.93 都叫 0.93.0 0.93.1
发表于 2019-7-11 12:43:59 | 显示全部楼层
neroxps 发表于 2019-7-11 09:54
homeassistant 没有一个版本号叫 homeassistant/qemux86-64-homeassistant tag 0.93 都叫 0.93.0 0.93.1 ...
谢谢!楼主。已成功降级
现在无法进入
Home Assistant 控制台
已解决》》》
GMT+8, 2026-1-14 04:27 , Processed in 0.054715 second(s), 12 queries , MemCached On.
