楼主: neroxps
HASSIO 切换HA版本脚本
 楼主| 发表于 2019-5-18 08:10:43 | 显示全部楼层
neil尼尔 发表于 2019-5-18 02:06
补充bug,最新版0.93.1 降级后出现404: Not Found
感谢你的补充,请问是从0.93.1降级到什么版本,什么出现了404.
发表于 2019-5-18 11:15:58 | 显示全部楼层
092.2版本和091.1,没办法,只有用最新版了
 楼主| 发表于 2019-5-18 13:16:53 | 显示全部楼层
应该是hassio又改了
发表于 2019-5-19 09:32:05 | 显示全部楼层
显示404  就是代表着切换失败了吗
发表于 2019-5-19 09:44:12 | 显示全部楼层
随便弄了个老版本 0.77后的,结果显示404: Not Found
获取 HASSIO_TOKEN
正在执行版本切换到 0.86.1 请稍等片刻......
19-05-19 01:16:17 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding        for host add-ons
19-05-19 01:16:17 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-05-19 01:16:17 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 a        dd-ons
19-05-19 01:16:17 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-o        ns
19-05-19 01:16:17 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add        -ons
19-05-19 01:16:17 INFO (SyncWorker_3) [hassio.docker.interface] Restart homeassi        stant/qemuarm-64-homeassistant
19-05-19 01:16:38 INFO (MainThread) [hassio.homeassistant] Detect a running Home        Assistant instance
19-05-19 01:16:38 INFO (MainThread) [hassio.addons] Phase 'application' start 0        add-ons
19-05-19 01:16:38 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-05-19 01:16:38 INFO (MainThread) [hassio.core] Hass.io is up and running
19-05-19 01:30:40 INFO (MainThread) [hassio.homeassistant] Update Home Assistant        to version 0.86.1
19-05-19 01:30:40 INFO (SyncWorker_17) [hassio.docker.interface] Update image ho        meassistant/qemuarm-64-homeassistant:0.93.1 to homeassistant/qemuarm-64-homeassi        stant:0.86.1
19-05-19 01:30:40 INFO (SyncWorker_17) [hassio.docker.interface] Pull image home        assistant/qemuarm-64-homeassistant tag 0.86.1.
19-05-19 01:33:58 INFO (SyncWorker_17) [hassio.docker.interface] Tag image homea        ssistant/qemuarm-64-homeassistant with version 0.86.1 as latest
19-05-19 01:33:58 INFO (SyncWorker_17) [hassio.docker.interface] Stop homeassist        ant application
19-05-19 01:34:02 INFO (SyncWorker_17) [hassio.docker.interface] Clean homeassis        tant application
19-05-19 01:34:02 INFO (SyncWorker_17) [hassio.docker.interface] Cleanup images:        ['homeassistant/qemuarm-64-homeassistant:0.93.1']
19-05-19 01:34:11 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homea        ssistant homeassistant/qemuarm-64-homeassistant with version 0.86.1
19-05-19 01:34:46 INFO (MainThread) [hassio.homeassistant] Detect a running Home        Assistant instance
19-05-19 01:34:46 INFO (MainThread) [hassio.homeassistant] Successful run Home A        ssistant 0.86.1
{"result": "ok", "data": {}}
还原配置目录后重启 homeassistant....
homeassistant
等待 homeassistant 启动..................done
homeassistant 启动完成,版本切换成功
查看 homeassistant 日志命令: docker logs -f homeassistant
查看 hassio_supervisor 日志命令: docker logs -f hassio_supervisor
重启 homeassistant 命令:docker restart homeassistant
不看日志或者不把日志发出来的,请不要在论坛上发帖求助。
 楼主| 发表于 2019-5-19 12:53:54 | 显示全部楼层
[code]获取 HASSIO_TOKEN
是的 22楼兄弟已经说了。
发表于 2019-5-19 13:49:27 | 显示全部楼层
neroxps 发表于 2019-5-19 12:53
是的 22楼兄弟已经说了。
一键脚本能指定安装的版本就好了哈
 楼主| 发表于 2019-5-20 08:34:17 | 显示全部楼层
pigcais 发表于 2019-5-19 13:49
一键脚本能指定安装的版本就好了哈
没用,你没法指定 hassio_supervisor 的版本,即使指定了它依然会自动升级到最新。
而且hassio最近改动挺大,包括addons也根据他内置的反代进行适配(为了单点登录-所有系统只用 homeassistant的用户名密码登陆),所以还是别指望降级了。
发表于 2019-5-31 01:43:24 | 显示全部楼层
19-05-30 16:32:39 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-o        ns
19-05-30 16:32:39 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add        -ons
19-05-30 16:32:39 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassist        ant/qemuarm-64-homeassistant
19-05-30 16:33:05 INFO (MainThread) [hassio.homeassistant] Detect a running Home        Assistant instance
19-05-30 16:33:05 INFO (MainThread) [hassio.addons] Phase 'application' start 0        add-ons
19-05-30 16:33:05 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-05-30 16:33:05 INFO (MainThread) [hassio.core] Hass.io is up and running
19-05-30 16:58:59 INFO (MainThread) [hassio.homeassistant] Update Home Assistant        to version 0.80.3
19-05-30 16:58:59 INFO (SyncWorker_1) [hassio.docker.interface] Update image hom        eassistant/qemuarm-64-homeassistant:0.93.2 to homeassistant/qemuarm-64-homeassis        tant:0.80.3
19-05-30 16:58:59 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homea        ssistant/qemuarm-64-homeassistant tag 0.80.3.
19-05-30 17:37:58 ERROR (MainThread) [hassio.utils] Can't execute update while a        task is in progress
大神看看我的
发表于 2019-5-31 14:39:22 | 显示全部楼层
弱弱的问一句,带日志发帖会不会被加分啊?
GMT+8, 2026-1-14 04:27 , Processed in 0.199134 second(s), 12 queries , MemCached On.
