楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-8-18 13:38:44 | 显示全部楼层
这个是换了个系统测试的
从 hub.docker.com 下载 homeassistant/raspberrypi3-homeassistant:0.114.2......
0.114.2: Pulling from homeassistant/raspberrypi3-homeassistant
52278dd8e579: Pulling fs layer
6102c003b6e3: Pulling fs layer
4236e4e90551: Pull complete
5719cec5a6fc: Downloading
36f4cf542ed0: Download complete
ddd36a9eea3f: Downloading
3334b13728a0: Downloading
2f621c3f2074: Download complete
b56d8d7a3a75: Download complete
f46b26f86660: Download complete
a19fc7dc3a86: Download complete
45cb95c98046: Download complete
c054bf499a1c: Download complete
6e3b070253c7: Download complete
3bc401c99e00: Download complete
f5e2791863d5: Download complete
d0cbcd862a76: Download complete
57af46067e67: Download complete
6cce3a9e5922: Download complete
adcdbf3c79e1: Download complete
6d12a50adc8d: Download complete
5acb4dd0d188: Download complete
ea652a1182f5: Download complete
6e349dbe1f8b: Download complete
1f964b2a5bb9: Download complete
5719cec5a6fc: Pull complete
36f4cf542ed0: Pull complete
ddd36a9eea3f: Pull complete
3334b13728a0: Pull complete
2f621c3f2074: Pull complete
b56d8d7a3a75: Pull complete
f46b26f86660: Pull complete
a19fc7dc3a86: Pull complete
45cb95c98046: Pull complete
c054bf499a1c: Pull complete
6e3b070253c7: Pull complete
3bc401c99e00: Pull complete
f5e2791863d5: Pull complete
d0cbcd862a76: Pull complete
57af46067e67: Pull complete
6cce3a9e5922: Pull complete
adcdbf3c79e1: Pull complete
6d12a50adc8d: Pull complete
5acb4dd0d188: Pull complete
ea652a1182f5: Pull complete
6e349dbe1f8b: Pull complete
1f964b2a5bb9: Pull complete
Digest: sha256:84b18740623ccb316eae2cc9f00050817742e642abb96e3f17b98f61d428d4a0
Status: Downloaded newer image for homeassistant/raspberrypi3-homeassistant:0.114.2
docker.io/homeassistant/raspberrypi3-homeassistant:0.114.2
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning]
[Warning] If you want more control over your own system, run
[Warning] Home Assistant as a VM or run Home Assistant Core
[Warning] via a Docker container.
[Warning]
[Error] No AppArmor support on host.
Unit hassio-supervisor.service could not be found.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.118-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:21:24 BST 2020
Linux raspberrypi 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
 楼主| 发表于 2020-8-18 14:58:35 | 显示全部楼层
aya4dw 发表于 2020-8-18 11:23
root@arm-64:~# curl -i https://cdn.jsdelivr.net/gh/home ... -supervisor.service
HTTP/2 200
date: T ...
那太奇怪了,脚本里面也是 wget 下载的 service 文件。我这边广东中山下载都没问题。装了好多遍了都没问题。
发表于 2020-8-19 14:26:58 | 显示全部楼层
[info]: 发现系统已安装 docker,跳过 docker 安装
[info]: 跳过切换 Docker 源....
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/qemuarm-64-homeassistant:0.114.2......
0.114.2: Pulling from homeassistant/qemuarm-64-homeassistant
Digest: sha256:0c85cd6df7980302a9e697ff2ca8d4f1eea7b3cf6adf5e891eea90313cdcdad0
Status: Image is up to date for homeassistant/qemuarm-64-homeassistant:0.114.2
docker.io/homeassistant/qemuarm-64-homeassistant:0.114.2
./hassio_install.sh: line 1: $'\r': command not found
./hassio_install.sh: line 2: syntax error near unexpected token `newline'
./hassio_install.sh: line 2: `<!DOCTYPE html>'
Distributor ID:        Debian
Description:        Debian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 5.4.0-rc3-aml-g12 (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.98 SMP PREEMPT Mon Oct 14 16:55:33 MSK 2019
Linux armbian-gjh 5.4.0-rc3-aml-g12 #5.98 SMP PREEMPT Mon Oct 14 16:55:33 MSK 2019 aarch64 GNU/Linux
大佬,试了好几次都是这个报错!
发表于 2020-8-19 15:33:55 | 显示全部楼层
: 跳过切换 Docker 源....
: 安装 hassio......
看上去,阿里的code项目gg了呀大佬!
 楼主| 发表于 2020-8-20 08:51:17 | 显示全部楼层
can0can 发表于 2020-8-18 13:38
这个是换了个系统测试的
debian 10 开始默认启用 AppArmor  的吧?我没树莓派,没法知道当前环境。
https://wiki.debian.org/AppArmor/HowToUse 参考 wiki 自行开启 AppArmor
发表于 2020-8-20 11:22:29 | 显示全部楼层
https://wiki.debian.org/App ...
多谢
If you are using Debian 10 "Buster" or newer, AppArmor is enabled by default.
apt-get install apparmor apparmor-utils auditd
然后都解决了。
发表于 2020-8-21 17:52:12 | 显示全部楼层
x86 小主机,ubuntu1604   选6,选1我都测试过,还一样的问题,最近安装一直出问题,求大神帮忙,
1 09:39:49 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-08-21 09:41:01 INFO (SyncWorker_0) [supervisor.docker.interface] Stop homeassistant application
20-08-21 09:41:05 INFO (SyncWorker_0) [supervisor.docker.interface] Clean homeassistant application
20-08-21 09:41:05 INFO (MainThread) [supervisor.homeassistant] Home Assistant docker now installed
20-08-21 09:41:05 INFO (MainThread) [supervisor.homeassistant] Start Home Assistant
20-08-21 09:41:05 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-08-21 09:41:05 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.114.3
20-08-21 09:41:05 INFO (MainThread) [supervisor.homeassistant] Wait until Home Assistant is ready
20-08-21 09:41:15 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-08-21 09:41:15 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-08-21 09:41:15 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:landingpage']
20-08-21 09:41:48 INFO (MainThread) [__main__] Stopping Supervisor
20-08-21 09:41:48 INFO (MainThread) [supervisor.api] Stop API on 172.30.32.2
20-08-21 09:41:48 INFO (MainThread) [supervisor.misc.forwarder] Stop DNS forwarding
20-08-21 09:41:48 INFO (MainThread) [supervisor.core] Supervisor is down
20-08-21 09:41:48 INFO (MainThread) [__main__] Close Supervisor
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[09:41:59] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-08-21 09:42:01 INFO (MainThread) [__main__] Initialize Supervisor setup
20-08-21 09:42:01 INFO (MainThread) [supervisor.bootstrap] Initialize Supervisor Sentry
20-08-21 09:42:01 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: qemux86-64
20-08-21 09:42:02 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 235
20-08-21 09:42:02 ERROR (MainThread) [supervisor.docker] Docker logging driver json-file is not supported!
20-08-21 09:42:02 INFO (MainThread) [__main__] Setup Supervisor
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-08-21 09:42:02 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.services] Update service information
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-08-21 09:42:02 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Errorrg.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.DBus.Properties' on object at path /org/freedesktop/NetworkManager/DnsManager
20-08-21 09:42:02 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-08-21 09:42:02 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-08-21 09:42:02 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-08-21 09:42:02 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 9
20-08-21 09:42:02 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-08-21 09:42:02 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-08-21 09:42:02 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_dns application
20-08-21 09:42:03 INFO (SyncWorker_0) [supervisor.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 9 - 172.30.32.3
20-08-21 09:42:03 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-08-21 09:42:03 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 17
20-08-21 09:42:03 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-08-21 09:42:03 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-08-21 09:42:04 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32.4
20-08-21 09:42:04 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-cli with version 25
20-08-21 09:42:04 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-08-21 09:42:04 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_cli application
20-08-21 09:42:05 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/amd64-hassio-cli with version 25 - 172.30.32.5
20-08-21 09:42:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-multicast with version 3
20-08-21 09:42:05 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-08-21 09:42:05 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_multicast application
20-08-21 09:42:06 INFO (SyncWorker_0) [supervisor.docker.multicast] Start Multicast homeassistant/amd64-hassio-multicast with version 3 - Host
20-08-21 09:42:06 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-21 09:42:06 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.114.3
20-08-21 09:42:06 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found
20-08-21 09:42:06 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-08-21 09:42:06 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-08-21 09:42:06 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 66 new - 0 remove
20-08-21 09:42:06 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-08-21 09:42:07 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-08-21 09:42:07 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-08-21 09:42:07 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-08-21 09:42:07 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 1
20-08-21 09:42:07 ERROR (MainThread) [supervisor.core] Detected unsupported OS: Ubuntu 16.04.4 LTS
20-08-21 09:42:07 INFO (MainThread) [__main__] Run Supervisor
20-08-21 09:42:07 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-08-21 09:42:07 CRITICAL (MainThread) [supervisor.core] System running in a unsupported environment!
20-08-21 09:42:07 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-08-21 09:42:07 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-08-21 09:42:07 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-08-21 09:42:07 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-08-21 09:42:07 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-08-21 09:42:07 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-21 09:42:07 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-21 09:42:07 INFO (MainThread) [supervisor.host.services] Update service information
 楼主| 发表于 2020-8-22 08:26:54 | 显示全部楼层
1 09:39:4 ...
已经启动了啊,docker logs -f homeassistant  看日志
发表于 2020-8-23 09:23:13 | 显示全部楼层
neroxps 发表于 2020-4-6 13:22
https://community.home-assistant ... l-services/171199/3
[md]
The following network interfaces were found in /etc/network/interfaces
which means they are currently configured by ifupdown:
- eth0
If you want to manage those interfaces with NetworkManager instead
remove their configuration from /etc/network/interfaces.
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service -> /lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service -> /lib/systemd/system/NetworkManager-wait-online.service.
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service -> /lib/systemd/system/NetworkManager.service.
Setting up modemmanager (1.10.0-1) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service -> /lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service -> /lib/systemd/system/ModemManager.service.
Processing triggers for systemd (241-5) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.16-1) ...
Processing triggers for libc-bin (2.28-10) ...
Errors were encountered while processing:
auditd
E: Sub-process /usr/bin/dpkg returned an error code (1)
Linux version 5.4.55-1-pve (root@nora) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP PVE 5.4.55-1 (Mon, 10 Aug 2020 10:26:27 +0200)
Linux debian 5.4.55-1-pve #1 SMP PVE 5.4.55-1 (Mon, 10 Aug 2020 10:26:27 +0200) x86_64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
应该不是脚本问题,我自己手动安装curl也出错Job for auditd.service failed because the control process exited with error code.
See "systemctl status auditd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript auditd, action "start" failed.
* auditd.service - Security Auditing Service
   Loaded: loaded (/lib/systemd/system/auditd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2020-08-23 01:34:55 UTC; 9ms ago
     Docs: man:auditd(8)
           https://github.com/linux-audit/audit-documentation
  Process: 5078 ExecStart=/sbin/auditd (code=exited, status=1/FAILURE)
Aug 23 01:34:55 ubuntu systemd[1]: Starting Security Auditing Service...
Aug 23 01:34:55 ubuntu auditd[5078]: Cannot change priority (Operation not permitted)
Aug 23 01:34:55 ubuntu auditd[5078]: The audit daemon is exiting.
Aug 23 01:34:55 ubuntu systemd[1]: auditd.service: Control process exited, code=exited status=1
Aug 23 01:34:55 ubuntu systemd[1]: auditd.service: Failed with result 'exit-code'.
Aug 23 01:34:55 ubuntu systemd[1]: Failed to start Security Auditing Service.
dpkg: error processing package auditd (--configure):
installed auditd package post-installation script subprocess returned error exit status 1
auditd
查了半天也没解决
发表于 2020-8-23 09:25:41 | 显示全部楼层
which means they are currentl ...
我自己手动安装curl也报错...
GMT+8, 2025-12-16 17:38 , Processed in 0.460126 second(s), 11 queries , MemCached On.
