楼主: alei643
Sonoff开关刷Tasmota基础教程(环境配置篇)
 楼主| 发表于 2018-1-23 07:55:33 | 显示全部楼层
bluezym 发表于 2018-1-22 23:08
请教一下,我的usb编辑器(CH341A 24\25编程器 集USB转TTL 单片机 编程 液晶 中九 刷机  )ttl 只有三接口 ...
不可以,绝不能在模块带强电的情况下连接USB编程器,还是重新买个USB编程器,淘宝8元钱包邮,型号推荐CH340
 楼主| 发表于 2018-1-23 07:56:54 | 显示全部楼层
superjsf 发表于 2018-1-23 00:26
請問版大,USB编程,有無什麼特殊要求? 不知道該淘寶買甚麼型號建議下?
推荐CH340,淘宝8元包邮
发表于 2018-1-23 22:59:58 | 显示全部楼层
唷! 非常感謝版大的回覆,太棒了!
发表于 2018-1-31 18:02:20 来自手机 | 显示全部楼层
3.配置com参数,这一步不太懂,请问图片上内容怎么出来的?
发表于 2018-1-31 22:59:41 | 显示全部楼层
Arduino:1.8.4 (Windows 7), 开发板:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 1M (no SPIFFS), ck, Disabled, None"
F:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware F:\Arduino\hardware -hardware F:\Arduino\portable\packages -tools F:\Arduino\tools-builder -tools F:\Arduino\hardware\tools\avr -tools F:\Arduino\portable\packages -built-in-libraries F:\Arduino\libraries -libraries F:\Arduino\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10804 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_183570 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_767915 -prefs=build.warn_data_percentage=75 -verbose F:\Sonoff-Tasmota-master\sonoff\sonoff.ino
F:\Arduino\arduino-builder -compile -logger=machine -hardware F:\Arduino\hardware -hardware F:\Arduino\portable\packages -tools F:\Arduino\tools-builder -tools F:\Arduino\hardware\tools\avr -tools F:\Arduino\portable\packages -built-in-libraries F:\Arduino\libraries -libraries F:\Arduino\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10804 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_183570 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_767915 -prefs=build.warn_data_percentage=75 -verbose F:\Sonoff-Tasmota-master\sonoff\sonoff.ino
Using board 'generic' from platform in folder: F:\Arduino\portable\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: F:\Arduino\portable\packages\esp8266\hardware\esp8266\2.3.0
构建选项已变更,全部重新构建
Detecting libraries used...
缺少 recipe.preproc.macros 模式
为开发板 Generic ESP8266 Module 编译时出错。
想请问 这是什么原因
发表于 2018-3-5 19:50:02 | 显示全部楼层
学习,谢谢分享
发表于 2018-3-6 16:54:35 | 显示全部楼层
谢谢分享对正在装修的我帮助很大
发表于 2018-3-11 18:47:20 来自手机 | 显示全部楼层
感謝大大,近期入手開關,準備來試試
aaa
34
发表于 2018-3-13 21:34:42 来自手机 | 显示全部楼层
发表于 2018-3-22 23:09:21 来自手机 | 显示全部楼层
需要用编程器吗?我只有TTL可以吗…
GMT+8, 2026-1-16 03:36 , Processed in 0.445460 second(s), 18 queries , MemCached On.
