楼主: alei643
Sonoff开关刷Tasmota基础教程(环境配置篇)
发表于 2017-12-13 16:11:06 | 显示全部楼层
好,挺管用的
bryt
发表于 2017-12-18 00:45:50 | 显示全部楼层
非常感谢分享
发表于 2017-12-24 10:37:00 | 显示全部楼层
发表于 2018-1-2 23:08:50 | 显示全部楼层
感谢分析 收藏一下
发表于 2018-1-5 13:32:02 | 显示全部楼层
ESP8266开发板 有2.4的是不是不装 还是用2.3的?
发表于 2018-1-5 14:06:46 | 显示全部楼层
Flash Mode 是不是更新成DOUT了?Wiki和Readme里都有提到,转引Readme里的话“Only Flash Mode DOUT is supported. Do not use Flash Mode DIO / QIO / QOUT as it might seem to brick your device.”
发表于 2018-1-6 16:48:50 | 显示全部楼层
刷成功,感謝分享資訊
 楼主| 发表于 2018-1-6 19:44:55 | 显示全部楼层
用2.3就可以,2.4版本的没试过,不知道行不行。另外Flash Mode的模式最近我没注意过,两周前我还刷过5.10版本的固件,刷机参数没变动,DIO模式仍然可以刷机成功
发表于 2018-1-8 06:13:23 | 显示全部楼层
Arduino:1.8.5 (Windows 7), 开发板:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 1M (no SPIFFS), ck, Disabled, None"
D:\arduino-1.8.5-windows\arduino-1.8.5\arduino-builder -dump-prefs -logger=machine -hardware D:\arduino-1.8.5-windows\arduino-1.8.5\hardware -hardware D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages -tools D:\arduino-1.8.5-windows\arduino-1.8.5\tools-builder -tools D:\arduino-1.8.5-windows\arduino-1.8.5\hardware\tools\avr -tools D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages -built-in-libraries D:\arduino-1.8.5-windows\arduino-1.8.5\libraries -libraries D:\arduino-1.8.5-windows\arduino-1.8.5\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_711057 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\ADMINI~1\AppData\Local\Temp\untitled458419899.tmp\sketch_jan08a\sketch_jan08a.ino
D:\arduino-1.8.5-windows\arduino-1.8.5\arduino-builder -compile -logger=machine -hardware D:\arduino-1.8.5-windows\arduino-1.8.5\hardware -hardware D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages -tools D:\arduino-1.8.5-windows\arduino-1.8.5\tools-builder -tools D:\arduino-1.8.5-windows\arduino-1.8.5\hardware\tools\avr -tools D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages -built-in-libraries D:\arduino-1.8.5-windows\arduino-1.8.5\libraries -libraries D:\arduino-1.8.5-windows\arduino-1.8.5\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_711057 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\ADMINI~1\AppData\Local\Temp\untitled458419899.tmp\sketch_jan08a\sketch_jan08a.ino
Using board 'generic' from platform in folder: D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10805 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01"  -DESP8266 "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\sketch\sketch_jan08a.ino.cpp" -o "nul"
Generating function prototypes...
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10805 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01"  -DESP8266 "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\sketch\sketch_jan08a.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\preproc\ctags_target_for_gcc_minus_e.cpp"
"D:\arduino-1.8.5-windows\arduino-1.8.5\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\preproc\ctags_target_for_gcc_minus_e.cpp"
正在编译项目...
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10805 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01"  -DESP8266 "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-ID:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\sketch\sketch_jan08a.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\sketch\sketch_jan08a.ino.cpp.o"
Compiling libraries...
Compiling core...
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cont.S.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cont_util.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_eboot_command.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_flash_utils.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_i2s.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_noniso.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_phy.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_postmortem.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_si2c.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_timer.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_analog.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_digital.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_pulse.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_pwm.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_shift.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\heap.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libc_replacements.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\time.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\uart.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libb64\cdecode.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libb64\cencode.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_cache.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_check.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_gc.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_hydrogen.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_nucleus.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\umm_malloc\umm_malloc.c.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Esp.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\FS.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\HardwareSerial.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\IPAddress.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\MD5Builder.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Print.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Schedule.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Stream.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\StreamString.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Tone.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Updater.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\WMath.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\WString.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\abi.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\base64.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cbuf.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_main.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\debug.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\pgmspace.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs_api.cpp.o
使用已经编译的文件:C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs_hal.cpp.o
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cont.S.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cont_util.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_eboot_command.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_flash_utils.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_i2s.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_noniso.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_phy.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_postmortem.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_si2c.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_timer.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_analog.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_digital.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_pulse.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_pwm.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_wiring_shift.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\heap.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libc_replacements.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\time.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\uart.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libb64\cdecode.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\libb64\cencode.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_cache.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_check.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_gc.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_hydrogen.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs\spiffs_nucleus.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\umm_malloc\umm_malloc.c.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Esp.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\FS.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\HardwareSerial.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\IPAddress.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\MD5Builder.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Print.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Schedule.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Stream.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\StreamString.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Tone.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\Updater.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\WMath.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\WString.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\abi.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\base64.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\cbuf.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\core_esp8266_main.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\debug.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\pgmspace.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs_api.cpp.o"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru  "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\core\spiffs_hal.cpp.o"
Archiving built core (caching) in: C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_711057\core\core_esp8266_esp8266_generic_UploadTool_esptool,CpuFrequency_80,FlashFreq_40,FlashMode_dio,UploadSpeed_115200,FlashSize_1M0,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____64a6a3b2420706f87f48f9d0109b02ab.a
Linking everything together...
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -g -w -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static "-LD:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lib" "-LD:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/ld" "-Teagle.flash.1m0.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy  -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/sketch_jan08a.ino.elf" -Wl,--start-group "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006\sketch\sketch_jan08a.ino.cpp.o" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/arduino.ar" -lm -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lcrypto -lmain -lwps -laxtls -lsmartconfig -lmesh -lwpa2 -llwip_gcc -lstdc++ -Wl,--end-group  "-LC:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006"
"D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\esptool\0.4.9/esptool.exe" -eo "D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\hardware\esp8266\2.3.0/bootloaders/eboot/eboot.elf" -bo "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/sketch_jan08a.ino.bin" -bm dio -bf 40 -bz 1M -bs .text -bp 4096 -ec -eo "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/sketch_jan08a.ino.elf" -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
项目使用了 222015 字节,占用了 (21%) 程序存储空间。最大为 1023984 字节。
全局变量使用了31580字节,(38%)的动态内存,余留50340字节局部变量。最大为81920字节。
D:\arduino-1.8.5-windows\arduino-1.8.5\portable\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd ck -cb 115200 -cp COM8 -ca 0x00000 -cf C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_106006/sketch_jan08a.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <[email protected]>
        setting board to ck
        setting baudrate from 115200 to 115200
        setting port from COM1 to COM8
        setting address from 0x00000000 to 0x00000000
        espcomm_upload_file
        espcomm_upload_mem
        setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
        flush start
        setting serial port timeouts to 1 ms
        flush complete
        espcomm_send_command: sending command header
        espcomm_send_command: sending command payload
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
resetting board
trying to connect
        flush start
        flush complete
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
resetting board
trying to connect
        flush start
        flush complete
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
trying to connect
        flush start
        flush complete
        read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
 楼主| 发表于 2018-1-8 10:45:54 | 显示全部楼层
24021438 发表于 2018-1-8 06:13
Arduino:1.8.5 (Windows 7), 开发板:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 1M ( ...
可能的原因有:串口没有选对,sonoff没有打开刷机模式,都排除问题,更换个USBTTL模块试试
GMT+8, 2026-1-16 03:15 , Processed in 0.814482 second(s), 18 queries , MemCached On.
