楼主: czde
斐讯N1 安装docker.hassio
 火.. [复制链接]
发表于 2018-6-18 14:46:11 | 显示全部楼层
关于sudo出错命令的另外一个解决方法: 第一次按官方教程制作u盘, adb shell reboot update启动,
然后重新把镜像刷入u盘,  不用再复制gxl_p230_2g.dtb了,直接拔下电源, 插上u盘,  插上电源启动, 正常登录就好了
我估计是在N1的原版系统下插入U盘, 某些文件的owner会被改变
R_X
发表于 2018-6-20 10:10:46 | 显示全部楼层
感谢楼主  学习了
czde
 楼主| 发表于 2018-6-21 10:22:54 | 显示全部楼层
然后重新把 ...
但是运行一下命令更快解决呢
发表于 2018-6-21 16:27:44 | 显示全部楼层
谢谢大神分享,成功实现
发表于 2018-6-28 22:53:07 | 显示全部楼层
18-06-28 14:40:39 INFO (MainThread) [__main__] Initialize Hassio setup,
18-06-28 14:40:39 INFO (MainThread) [__main__] Setup HassIO,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
18-06-28 14:40:41 INFO (MainThread) [hassio.host.info] Update local host information,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
18-06-28 14:40:41 INFO (MainThread) [hassio.host.services] Update service information,
18-06-28 14:40:41 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
18-06-28 14:40:42 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'},
18-06-28 14:40:42 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
18-06-28 14:40:42 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
18-06-28 14:40:42 INFO (MainThread) [hassio.hassos] Can't detect HassOS,
18-06-28 14:40:42 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/aarch64-hassio-supervisor:latest with version 109,
18-06-28 14:40:42 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/aarch64-homeassistant:0.71.0 with version 0.71.0,
18-06-28 14:40:42 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/home-assistant/hassio-addons repository,
18-06-28 14:40:42 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/hassio-addons/repository repository,
18-06-28 14:40:57 INFO (MainThread) [__main__] Initialize Hassio setup,
18-06-28 14:40:57 INFO (MainThread) [__main__] Setup HassIO,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
18-06-28 14:40:59 INFO (MainThread) [hassio.host.info] Update local host information,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
18-06-28 14:40:59 INFO (MainThread) [hassio.host.services] Update service information,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
18-06-28 14:40:59 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'},
18-06-28 14:40:59 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
18-06-28 14:40:59 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
18-06-28 14:40:59 INFO (MainThread) [hassio.hassos] Can't detect HassOS,
18-06-28 14:40:59 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/aarch64-hassio-supervisor:latest with version 109,
18-06-28 14:40:59 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/aarch64-homeassistant:0.71.0 with version 0.71.0,
18-06-28 14:40:59 WARNING (MainThread) [hassio.addons.data] Can't read repository information from /data/addons/git/a0d7b954/repository.json,
18-06-28 14:40:59 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository,
18-06-28 14:40:59 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository,
18-06-28 14:40:59 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove,
18-06-28 14:41:00 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json,
18-06-28 14:41:10 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: ,
18-06-28 14:41:10 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
18-06-28 14:41:10 INFO (MainThread) [__main__] Run HassIO,
18-06-28 14:41:10 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons,
18-06-28 14:41:10 INFO (MainThread) [hassio.supervisor] Update supervisor to version None,
18-06-28 14:41:10 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/aarch64-hassio-supervisor:latest tag None.,
18-06-28 14:41:15 ERROR (SyncWorker_1) [hassio.docker.interface] Can't install homeassistant/aarch64-hassio-supervisor:latest:None -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-hassio-supervisor:None not found").,
18-06-28 14:41:15 ERROR (MainThread) [hassio.supervisor] Update of hass.io fails!,
18-06-28 14:41:15 INFO (MainThread) [hassio.core] Start API on 172.30.32.2,
18-06-28 14:41:15 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons,
18-06-28 14:41:15 INFO (MainThread) [hassio.addons] Startup system run 0 addons,
18-06-28 14:41:15 INFO (MainThread) [hassio.addons] Startup services run 0 addons,
18-06-28 14:41:16 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/aarch64-homeassistant:0.71.0 with version 0.71.0,
18-06-28 14:42:16 INFO (MainThread) [hassio.homeassistant] Detect a running Home-Assistant instance,
18-06-28 14:42:16 INFO (MainThread) [hassio.addons] Startup application run 0 addons,
18-06-28 14:42:21 INFO (MainThread) [hassio.tasks] All core tasks are scheduled,
18-06-28 14:42:21 INFO (MainThread) [hassio.core] Hass.io is up and running,
18-06-28 14:47:14 INFO (MainThread) [__main__] Stopping HassIO,
18-06-28 14:47:14 INFO (MainThread) [hassio.misc.dns] Stop DNS forwarding,
18-06-28 14:47:14 INFO (MainThread) [__main__] Close Hassio,
18-06-28 14:47:20 INFO (MainThread) [__main__] Initialize Hassio setup,
18-06-28 14:47:20 INFO (MainThread) [__main__] Setup HassIO,
18-06-28 14:47:20 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
18-06-28 14:47:21 INFO (MainThread) [hassio.host.info] Update local host information,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
18-06-28 14:47:21 INFO (MainThread) [hassio.host.services] Update service information,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
18-06-28 14:47:21 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'},
18-06-28 14:47:21 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
18-06-28 14:47:21 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
18-06-28 14:47:21 INFO (MainThread) [hassio.hassos] Can't detect HassOS,
18-06-28 14:47:21 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/aarch64-hassio-supervisor:latest with version 109,
18-06-28 14:47:22 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/aarch64-homeassistant:0.71.0 with version 0.71.0,
18-06-28 14:47:22 WARNING (MainThread) [hassio.addons.data] Can't read repository information from /data/addons/git/a0d7b954/repository.json,
18-06-28 14:47:22 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository,
18-06-28 14:47:22 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository,
18-06-28 14:47:22 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove,
18-06-28 14:47:22 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json,
18-06-28 14:47:24 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
18-06-28 14:47:24 INFO (MainThread) [__main__] Run HassIO,
18-06-28 14:47:24 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons,
18-06-28 14:47:24 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel,
18-06-28 14:47:24 INFO (MainThread) [hassio.core] Start API on 172.30.32.2,
18-06-28 14:47:24 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons,
18-06-28 14:47:24 INFO (MainThread) [hassio.core] Hass.io reboot detected,
18-06-28 14:47:24 INFO (MainThread) [hassio.tasks] All core tasks are scheduled,
18-06-28 14:47:24 INFO (MainThread) [hassio.core] Hass.io is up and running,
18-06-28 14:47:39 INFO (MainThread) [__main__] Initialize Hassio setup,
18-06-28 14:47:40 INFO (MainThread) [__main__] Setup HassIO,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
18-06-28 14:47:40 INFO (MainThread) [hassio.host.info] Update local host information,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
18-06-28 14:47:40 INFO (MainThread) [hassio.host.services] Update service information,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
18-06-28 14:47:40 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'},
18-06-28 14:47:40 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
18-06-28 14:47:40 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
18-06-28 14:47:40 INFO (MainThread) [hassio.hassos] Can't detect HassOS,
18-06-28 14:47:40 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/aarch64-hassio-supervisor:latest with version 109,
18-06-28 14:47:40 INFO (SyncWorker_2) [hassio.docker.interface] Attach to image homeassistant/aarch64-homeassistant:0.71.0 with version 0.71.0,
18-06-28 14:47:40 WARNING (MainThread) [hassio.addons.data] Can't read repository information from /data/addons/git/a0d7b954/repository.json,
18-06-28 14:47:40 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository,
18-06-28 14:47:40 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository,
18-06-28 14:47:40 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove,
18-06-28 14:47:40 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json,
18-06-28 14:47:44 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
18-06-28 14:47:44 INFO (MainThread) [__main__] Run HassIO,
18-06-28 14:47:44 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons,
18-06-28 14:47:44 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel,
18-06-28 14:47:44 INFO (MainThread) [hassio.core] Start API on 172.30.32.2,
18-06-28 14:47:44 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons,
18-06-28 14:47:44 INFO (MainThread) [hassio.core] Hass.io reboot detected,
18-06-28 14:47:44 INFO (MainThread) [hassio.tasks] All core tasks are scheduled,
18-06-28 14:47:44 INFO (MainThread) [hassio.core] Hass.io is up and running,
czde
 楼主| 发表于 2018-6-29 23:00:39 | 显示全部楼层
18-06-28 14:40:39 INFO (Main ...
网络问题。重启一下hassio再看看
发表于 2018-7-7 07:41:22 | 显示全部楼层
学习理解中。。。
发表于 2018-7-11 09:36:43 | 显示全部楼层
2018-6-11 更新
视频教程
https://www.bilibili.com/video/av24673092/
我分享了来自腾讯文档"N1安装hassio过程",点击查看:
https://docs.qq.com/doc/BGKGUl0b ... 0rX2pw0mc49G1gpRtn1
请问这个视频和文档教程还有用吗?
发表于 2018-7-11 12:05:53 | 显示全部楼层
这个教程是不能用了,大家别进坑了,都移步吧
czde
 楼主| 发表于 2018-7-12 21:44:20 | 显示全部楼层
恩。步骤是没问题的。有些地方要小改,自己折腾吧
GMT+8, 2025-11-19 22:25 , Processed in 1.321976 second(s), 12 queries , MemCached On.
