楼主: bernard3378
[插件集成] Aqara Bridge - 用官方API把Aqara设备接入HA,支持复杂设备[V2.1.2]
发表于 2025-2-27 20:32:20 | 显示全部楼层
bernard3378 发表于 2025-2-9 19:39
实测开关灯控传感器等没什么延迟,空调是有的,跟官方Homekit延迟差不多
AttributeError: 'AiotACPartnerP3Entity' object has no attribute '__attr_hvac_mode'. Did you mean: '__attr_hvac_modes'?
2025-02-27 20:03:34.257 ERROR (MainThread) [homeassistant.components.climate] Error adding entity climate.aqara_4885e9_ac_partner_p3 for domain climate with platform aqara_bridge
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 928, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1384, in add_to_platform_finish
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1148, in _async_write_ha_state
    self.__async_calculate_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1085, in __async_calculate_state
    state = self._stringify_state(available)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1029, in _stringify_state
    if (state := self.state) is None:
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 353, in state
    hvac_mode = self.hvac_mode
  File "src/propcache/_helpers_c.pyx", line 80, in propcache._helpers_c.cached_property.__get__
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 485, in hvac_mode
    return self._attr_hvac_mode
pwy 手机认证
发表于 2025-2-27 22:13:14 | 显示全部楼层
这个错误是什么原因
发表于 2025-2-27 22:56:34 | 显示全部楼层
pwy 发表于 2025-2-27 22:13
这个错误是什么原因
我也是这样的。
HACS版本是:
Integration version:        2.0.5
Frontend version:        20250128065759
发表于 2025-3-1 12:48:05 | 显示全部楼层
想请教一下楼主, 这个和Aqara Gateway 有什么不同呢?
发表于 2025-3-2 23:12:13 | 显示全部楼层
这个不用破解
发表于 2025-3-3 00:50:01 | 显示全部楼层
大佬  请教一下  在G3摄像头中  所有的事件都显示未知  这个怎么办  其他设备 我这看都暂时正常的  我就为了手势接入联动其他家设备折腾的
发表于 2025-3-3 11:02:31 | 显示全部楼层
大佬,这三个可以接入吗?
lumi.switch.acn034
lumi.camera.acn005
aqara.airrtc.ecn001
发表于 2025-3-3 20:51:15 | 显示全部楼层
明白了, 那是不是这个是需要联网,不能局域网,但是Gateway是走局域网?
发表于 2025-3-5 08:50:25 | 显示全部楼层
我发现有设备模型但是没有设备资源的是可以正常调用的  只是要自己写调用代码 不会整下面的
这个需要大佬解决了
发表于 2025-3-5 13:30:00 | 显示全部楼层
我家的地暖面板不知道能不能用
GMT+8, 2026-1-31 16:42 , Processed in 0.256568 second(s), 13 queries , MemCached On.
