楼主: bernard3378
[插件集成] Aqara Bridge - 用官方API把Aqara设备接入HA,支持复杂设备[V2.1.2]
发表于 2025-2-24 10:47:57 | 显示全部楼层
    #################################浴霸####################################
                "lumi.bhf_light.acn001": ["Aqara", "Smart Yuba T1", "ZNYB01LM"],
                "params": [
                        # Light实体(照明功能)
                                "light": {
                                        MK_INIT_PARAMS: {
                                                MK_HASS_NAME: "light",
                                                "supported_features": LightEntityFeature.EFFECT,
                                                "supported_color_modes": {ColorMode.BRIGHTNESS, ColorMode.COLOR_TEMP},
                                                "color_mode": ColorMode.COLOR_TEMP,
                                                "min_color_temp_kelvin": 2700,
                                                "max_color_temp_kelvin": 6500
                                        MK_RESOURCES: {
                                                "toggle": ("4.1.85", "_attr_is_on"),
                                                "brightness": ("1.7.85", "_attr_brightness"),
                                                "color_temp_kelvin": ("1.9.85", "_attr_color_temp_kelvin")
                        # 电源开关
                                "switch": {
                                        MK_INIT_PARAMS: {
                                                MK_HASS_NAME: "power",
                                                "entity_name": "Power Switch"
                                        MK_RESOURCES: {
                                                "toggle": ("4.21.85", "_attr_is_on")
                        # 温度传感器
                                "sensor": {
                                        MK_INIT_PARAMS: {
                                                MK_HASS_NAME: "current_temperature",
                                                "device_class": SensorDeviceClass.TEMPERATURE,
                                                "state_class": SensorStateClass.MEASUREMENT,
                                                "unit_of_measurement": UnitOfTemperature.CELSIUS
                                        MK_RESOURCES: {
                                                "temperature": ("0.1.85", "_attr_native_value")
                        # 目标温度传感器
                                "sensor": {
                                        MK_INIT_PARAMS: {
                                                MK_HASS_NAME: "target_temperature",
                                        MK_RESOURCES: {
                                                "temperature": ("1.8.85", "_attr_native_value")
                        # Climate实体(浴霸主控)
                                "climate": {
                                        MK_INIT_PARAMS: {
                                                MK_HASS_NAME: "yuba",
                                                "supported_features": ClimateEntityFeature.TARGET_TEMPERATURE
                                                        | ClimateEntityFeature.FAN_MODE
                                                        | ClimateEntityFeature.SWING_MODE
                                                        | ClimateEntityFeature.PRESET_MODE,
                                                "hvac_modes": [HVACMode.HEAT, HVACMode.DRY, HVACMode.FAN_ONLY, HVACMode.OFF],
                                                "fan_modes": [FAN_LOW, FAN_MEDIUM, FAN_HIGH, FAN_AUTO],
                                                "swing_modes": [SWING_ON, SWING_OFF],
                                                "preset_modes": ["Normal", "Boost"],
                                                "min_temp": 20,
                                                "max_temp": 40,
                                                "temperature_unit": UnitOfTemperature.CELSIUS
                                        MK_RESOURCES: {
                                                "current_temperature": ("0.1.85", "_attr_current_temperature"),
                                                "target_temperature": ("1.8.85", "_attr_target_temperature"),
                                                "fan_mode": ("14.35.85", "_attr_fan_mode"),
                                                "swing_mode": ("14.47.85", "_attr_swing_mode"),
                                                "preset_mode": ("14.51.85", "_attr_preset_mode"),
                                                "hvac_mode": ("14.51.85", "_attr_hvac_mode")
        },###尝试自己添加了以上浴霸的代码后好像还是识别不到 请求楼主帮忙看看 这样对吗
发表于 2025-2-24 10:55:07 | 显示全部楼层
我自己在使用FP2 时发现一个状况,当reload 整合之后,原来人在状态是有人的话(Detected),reload 之后人在状态会显示unknown;反而在reload 前是无人(Cleared),reload 之后还会是无人
发表于 2025-2-25 09:58:07 | 显示全部楼层
马可波罗 发表于 2025-2-14 13:06
auth_code_error
我也被它卡了半天,是被(手机号)误导了,用邮箱注册的号,填写邮箱接收验证码。 ...
我是填了邮箱 正常有验证,auth_code_error,手机号也能验证,提示错误,最后发现已经有账号了!登录之后再邮箱验证就通过了
发表于 2025-2-25 09:59:39 | 显示全部楼层
dzzzzzz 发表于 2025-2-15 20:43
我已经接入了,控制是可以控制,就是通过aqaraAPP控制了开关,状态不会同步到ha里面。我手机或者开关关掉灯 ...
这个怎么解决,我也发现了 昨天空调开了,今天ha里面空调还是开的
发表于 2025-2-25 19:28:32 | 显示全部楼层
大佬 这个报错怎么整?是网络问题吗?如果是的话 有没有离线安装方式~~~跪等
发表于 2025-2-25 19:44:25 | 显示全部楼层
a9376668 发表于 2025-2-25 19:28
大佬 这个报错怎么整?是网络问题吗?如果是的话 有没有离线安装方式~~~跪等 ...
无法加载配置向导: {"message":"Invalid handler specified"}
下载离线包到集成  安装的时候显示上述代码
有大佬知道什么问题吗
发表于 2025-2-25 20:59:35 来自手机 | 显示全部楼层
这个要加自定义集成看作者说明;再不行改hosts 或者镜像加速下载都行 自己百度下
发表于 2025-2-25 21:01:38 | 显示全部楼层
下载离线包到集成  安装的时候显示上述代 ...
当前支持通过hacs商店进行配置,自定义存储库URL: bernard3378/AqaraBridge
发表于 2025-2-26 09:15:47 | 显示全部楼层
把项目消息推送打开 然后再开关下设备,状态就会更新了
发表于 2025-2-27 20:22:57 | 显示全部楼层
bernard3378 发表于 2025-2-9 19:39
实测开关灯控传感器等没什么延迟,空调是有的,跟官方Homekit延迟差不多
我在aqara home 中 p3工作模式为空调,然后调试空调型号的时候变化了一下,发现ha里面的空调面板就不可用了,插座开关是可以用的!删除了,重新配置 还是那样!这个怎么解决
GMT+8, 2025-9-17 02:59 , Processed in 0.521837 second(s), 14 queries , MemCached On.
