楼主: kellan
ha打不开了求助
 楼主| 发表于 2024-12-22 20:15:28 | 显示全部楼层
执行容器 hassio_supervisor 服务命令: logs
hassio-supervisor
[11:47:43] INFO: Using udev information from host
[11:47:43] INFO: Starting local supervisor watchdog...
2024-12-22 11:47:53.239 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-12-22 11:47:53.447 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/jobs.json: unexpected character: line 1 column 1 (char 0)
2024-12-22 11:47:53.503 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentry
2024-12-22 19:47:53.523 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: odroid-c4
2024-12-22 19:47:53.540 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor r.hassbus.com/home-assistant/aarch64-hassio-supervisor with version 2024.12.0
2024-12-22 19:47:53.540 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-12-22 19:47:53.804 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-12-22 19:47:53.813 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:47:53.816 INFO (MainThread) [__main__] Setting up Supervisor
2024-12-22 19:47:54.101 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-12-22 19:47:54.269 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-12-22 19:47:54.278 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-12-22 19:47:54.280 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-12-22 19:47:54.282 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-12-22 19:47:54.284 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-12-22 19:47:54.286 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-12-22 19:47:54.290 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-12-22 19:47:54.294 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-12-22 19:47:54.296 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-12-22 19:47:54.298 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-12-22 19:47:54.918 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-22 19:47:54.950 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-22 19:47:54.962 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2024-12-22 19:47:55.179 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-22 19:47:55.350 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-12-22 19:47:55.391 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-12-22 19:47:55.393 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.12.0&arch=
2024-12-22 19:47:55.472 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-cli with version 2024.09.0
2024-12-22 19:47:55.511 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2024-12-22 19:47:55.530 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
2024-12-22 19:47:56.439 INFO (MainThread) [supervisor.docker.cli] Starting CLI r.hassbus.com/home-assistant/aarch64-hassio-cli with version 2024.09.0 - 172.30.32.5
2024-12-22 19:47:56.483 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-dns with version 2024.12.0
2024-12-22 19:47:56.566 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-12-22 19:47:56.591 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
2024-12-22 19:47:57.766 INFO (MainThread) [supervisor.docker.dns] Starting DNS r.hassbus.com/home-assistant/aarch64-hassio-dns with version 2024.12.0 - 172.30.32.3
2024-12-22 19:47:57.770 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-12-22 19:47:57.812 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
2024-12-22 19:47:57.849 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2024-12-22 19:47:57.880 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
2024-12-22 19:47:59.005 INFO (MainThread) [supervisor.docker.audio] Starting Audio r.hassbus.com/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
2024-12-22 19:47:59.023 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-12-22 19:47:59.068 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2024-12-22 19:47:59.109 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-12-22 19:47:59.131 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
2024-12-22 19:47:59.789 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast r.hassbus.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
2024-12-22 19:47:59.803 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2024-12-22 19:47:59.833 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/odroid-c4-homeassistant with version 2024.12.5
2024-12-22 19:48:00.237 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.0 / BootSlot B
2024-12-22 19:48:02.020 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-12-22 19:48:02.022 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
2024-12-22 19:48:02.024 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
2024-12-22 19:48:02.029 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d6faf732 repository
2024-12-22 19:48:02.032 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7eca76cc repository
2024-12-22 19:48:03.455 INFO (MainThread) [supervisor.store] Loading add-ons from store: 132 all - 132 new - 0 remove
2024-12-22 19:48:03.707 INFO (MainThread) [supervisor.addons.manager] Found 6 installed add-ons
2024-12-22 19:48:03.904 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 12.3.2
2024-12-22 19:48:03.907 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2024-12-22 19:48:03.910 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/node-red/aarch64 with version 18.1.1
2024-12-22 19:48:03.915 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.4.1
2024-12-22 19:48:03.917 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/wghaos/addons-get-hacs with version 1.3.1
2024-12-22 19:48:03.919 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/ssh/aarch64 with version 19.0.0
2024-12-22 19:48:05.431 INFO (MainThread) [supervisor.backups.manager] Found 2 backup files
2024-12-22 19:48:05.445 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2024-12-22 19:48:05.446 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-12-22 19:48:05.446 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-12-22 19:48:05.447 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-22 19:48:05.448 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2024-12-22 19:48:05.448 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-22 19:48:05.449 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2024-12-22 19:48:05.451 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-22 19:48:05.452 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-22 19:48:05.453 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:48:05.454 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-12-22 19:48:05.460 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-22 19:48:05.461 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:48:05.464 INFO (MainThread) [__main__] Running Supervisor
2024-12-22 19:48:05.508 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as good
2024-12-22 19:48:05.544 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-12-22 19:48:05.553 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 1 add-ons
2024-12-22 19:48:05.625 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_mosquitto application
2024-12-22 19:48:06.755 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.4.1
2024-12-22 19:48:11.766 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 1 add-ons
2024-12-22 19:48:11.866 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_fb59d657_ssh application
2024-12-22 19:48:12.673 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on r.hassbus.com/hassio-addons/ssh/aarch64 with version 19.0.0
2024-12-22 19:48:17.692 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2024-12-22 19:48:17.750 INFO (SyncWorker_4) [supervisor.docker.manager] Starting homeassistant
2024-12-22 19:48:18.209 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-12-22 19:48:21.859 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
2024-12-22 19:48:34.313 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2024-12-22 19:48:34.314 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:48:38.292 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-22 19:48:38.334 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-12-22 19:49:08.663 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed ('172.30.32.1', 8123)]
2024-12-22 19:49:13.710 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
2024-12-22 19:49:13.712 ERROR (MainThread) [supervisor.core] Can't start Home Assistant Core - rebuiling
2024-12-22 19:49:13.848 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning homeassistant application
2024-12-22 19:49:14.345 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-12-22 19:49:14.971 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant r.hassbus.com/home-assistant/odroid-c4-homeassistant with version 2024.12.5
2024-12-22 19:49:14.972 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-12-22 19:49:41.776 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2024-12-22 19:49:41.779 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:49:45.113 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-12-22 19:50:20.351 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed ('172.30.32.1', 8123)]
2024-12-22 19:50:25.400 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
2024-12-22 19:50:25.408 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - core / None
2024-12-22 19:50:25.414 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - core / None
2024-12-22 19:50:25.421 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 2 add-ons
2024-12-22 19:50:25.597 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_configurator application
2024-12-22 19:50:26.850 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.8.0
2024-12-22 19:50:26.952 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_fb59d657_nodered application
2024-12-22 19:50:27.688 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on r.hassbus.com/hassio-addons/node-red/aarch64 with version 18.1.1
2024-12-22 19:50:57.040 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-12-22 19:50:57.045 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-12-22 19:50:57.046 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-12-22 19:50:57.053 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.12.0&arch=
2024-12-22 19:50:57.068 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-22 19:50:57.069 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-12-22 19:50:57.071 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-22 19:50:57.074 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-12-22 19:50:57.079 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-12-22 19:50:57.080 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-12-22 19:50:57.081 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-12-22 19:50:57.082 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-12-22 19:50:57.119 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-12-22 19:50:57.135 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-22 19:50:57.212 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-12-22 19:50:57.218 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-22 19:50:57.222 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-12-22 19:50:57.224 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-12-22 19:50:57.226 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-22 19:50:57.227 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-12-22 19:50:58.021 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-22 19:50:58.023 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-12-22 19:50:58.023 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-22 19:50:58.630 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-22 19:50:58.664 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-22 19:50:59.116 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-22 19:50:59.176 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-12-22 19:51:08.890 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-22 19:53:19.956 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-22 19:55:31.031 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-22 19:59:53.174 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
发表于 2024-12-23 13:15:00 | 显示全部楼层
hassio-supervisor
s6-rc: info: service s6rc-oneshot-runne ...
问题不好定位。
需要远程登录查看细节。
 楼主| 发表于 2024-12-23 19:57:53 | 显示全部楼层
达文西 发表于 2024-12-23 13:15
问题不好定位。
需要远程登录查看细节。
冬瓜大佬帮我远程看了,说是emmc有点问题,我重新买一个论坛推荐的x88pro20,现在在用aidlux,在刷旧手机上
GMT+8, 2025-12-29 14:48 , Processed in 0.501487 second(s), 5 queries , MemCached On.
