查看: 2771|回复: 22
ha打不开了求助
发表于 2024-12-21 10:42:09 | 显示全部楼层 |阅读模式
安装小米home,连接中断,然后就一直进不去了,系统崩了吗,把盒子电源断了再重开就能进去界面,但是启动过程中就会连接中断,重新连接,再然后就一直卡死了
大佬帮我看了之后说是盒子有问题,重新买了淘宝上论坛的x88pro20盒子
 楼主| 发表于 2024-12-21 10:42:10 | 显示全部楼层
执行容器 hassio_supervisor 服务命令: logs
hassio-supervisor
[17:47:23] INFO: Using udev information from host
[17:47:23] INFO: Starting local supervisor watchdog...
2024-12-20 17:47:30.980 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-12-20 17:47:31.188 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentry
2024-12-21 01:47:31.207 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: odroid-c4
2024-12-21 01:47:31.224 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor r.hassbus.com/home-assistant/aarch64-hassio-supervisor with version 2024.12.0
2024-12-21 01:47:31.224 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-12-21 01:47:31.461 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-12-21 01:47:31.470 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 01:47:31.472 INFO (MainThread) [__main__] Setting up Supervisor
2024-12-21 01:47:31.759 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-12-21 01:47:31.928 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-12-21 01:47:31.934 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-12-21 01:47:31.943 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-12-21 01:47:31.946 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-12-21 01:47:31.949 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-12-21 01:47:31.952 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-12-21 01:47:31.954 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-12-21 01:47:31.957 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-12-21 01:47:31.959 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-12-21 01:47:31.962 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-12-21 01:47:32.486 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-21 01:47:32.508 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-21 01:47:32.806 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-21 01:47:33.262 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-12-21 01:47:33.306 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-12-21 01:47:33.309 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.12.0&arch=
2024-12-21 01:47:33.382 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-cli with version 2024.09.0
2024-12-21 01:47:33.453 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-dns with version 2024.12.0
2024-12-21 01:47:33.487 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-12-21 01:47:33.514 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
2024-12-21 01:47:33.559 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-12-21 01:47:33.603 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2024-12-21 01:47:33.649 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2024-12-21 01:47:33.658 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/odroid-c4-homeassistant with version 2024.12.5
2024-12-21 01:47:33.806 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.0 / BootSlot B
2024-12-21 01:47:34.877 ERROR (SyncWorker_0) [supervisor.utils.yaml] Can't read YAML file /data/addons/git/b9a594eb/esphome-dev/config.yaml - while scanning a simple key
  in "/data/addons/git/b9a594eb/esphome-dev/config.yaml", line 39, column 1
could not find expected ':'
  in "/data/addons/git/b9a594eb/esphome-dev/config.yaml", line 40, column 1
2024-12-21 01:47:34.878 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/b9a594eb/esphome-dev/config.yaml from repository b9a594eb
2024-12-21 01:47:34.902 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
2024-12-21 01:47:34.904 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d6faf732 repository
2024-12-21 01:47:34.908 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-12-21 01:47:34.915 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7eca76cc repository
2024-12-21 01:47:34.922 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
2024-12-21 01:47:36.215 ERROR (SyncWorker_0) [supervisor.utils.yaml] Can't read YAML file /data/addons/git/b9a594eb/esphome-dev/config.yaml - while scanning a simple key
2024-12-21 01:47:36.216 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/b9a594eb/esphome-dev/config.yaml from repository b9a594eb
2024-12-21 01:47:36.254 INFO (MainThread) [supervisor.store] Loading add-ons from store: 131 all - 131 new - 0 remove
2024-12-21 01:47:36.528 INFO (MainThread) [supervisor.addons.manager] Found 6 installed add-ons
2024-12-21 01:47:36.710 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 12.3.2
2024-12-21 01:47:36.720 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/wghaos/addons-get-hacs with version 1.3.1
2024-12-21 01:47:36.723 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.4.1
2024-12-21 01:47:36.725 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/ssh/aarch64 with version 19.0.0
2024-12-21 01:47:36.729 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2024-12-21 01:47:36.738 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/node-red/aarch64 with version 18.1.1
2024-12-21 01:47:36.992 INFO (MainThread) [supervisor.backups.manager] Found 2 backup files
2024-12-21 01:47:37.007 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2024-12-21 01:47:37.008 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-12-21 01:47:37.008 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-12-21 01:47:37.009 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-21 01:47:37.010 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2024-12-21 01:47:37.010 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-21 01:47:37.011 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2024-12-21 01:47:37.012 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-21 01:47:37.012 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-21 01:47:37.014 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 01:47:37.015 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-12-21 01:47:37.016 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-21 01:47:37.016 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 01:47:37.019 INFO (MainThread) [__main__] Running Supervisor
2024-12-21 01:47:37.067 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as good
2024-12-21 01:47:37.104 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-12-21 01:47:37.106 INFO (MainThread) [supervisor.core] Supervisor reboot detected
2024-12-21 01:47:37.109 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-12-21 01:47:37.113 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-12-21 01:47:37.114 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-12-21 01:47:37.117 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-21 01:47:37.117 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-12-21 01:47:37.118 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-21 01:47:37.119 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-12-21 01:47:37.119 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-12-21 01:47:37.120 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-12-21 01:47:37.121 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-12-21 01:47:37.121 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-12-21 01:47:37.147 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-12-21 01:47:37.167 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-21 01:47:37.183 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-12-21 01:47:37.195 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-21 01:47:37.196 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-12-21 01:47:37.198 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-12-21 01:47:37.201 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-21 01:47:37.201 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-12-21 01:47:37.223 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-21 01:47:37.247 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-21 01:47:37.854 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-21 01:47:37.878 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-12-21 01:47:38.041 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 01:47:38.043 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-12-21 01:47:38.043 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-21 01:50:42.248 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-21 01:52:53.324 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
 楼主| 发表于 2024-12-21 10:42:11 | 显示全部楼层
hassio-supervisor
[18:14:48] INFO: Using udev information from host
[18:14:48] INFO: Starting local supervisor watchdog...
2024-12-20 18:14:56.796 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-12-20 18:14:57.090 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentry
2024-12-21 02:14:57.113 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: odroid-c4
2024-12-21 02:14:57.131 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor r.hassbus.com/home-assistant/aarch64-hassio-supervisor with version 2024.12.0
2024-12-21 02:14:57.132 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-12-21 02:14:57.385 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-12-21 02:14:57.396 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 02:14:57.399 INFO (MainThread) [__main__] Setting up Supervisor
2024-12-21 02:14:57.674 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-12-21 02:14:57.845 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-12-21 02:14:57.849 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-12-21 02:14:57.851 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-12-21 02:14:57.853 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-12-21 02:14:57.856 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-12-21 02:14:57.857 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-12-21 02:14:57.862 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-12-21 02:14:57.863 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-12-21 02:14:57.867 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-12-21 02:14:57.870 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-12-21 02:14:58.677 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-21 02:14:58.699 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-21 02:14:59.111 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-21 02:14:59.554 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-12-21 02:14:59.646 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-12-21 02:14:59.649 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.12.0&arch=
2024-12-21 02:14:59.724 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-cli with version 2024.09.0
2024-12-21 02:14:59.799 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-dns with version 2024.12.0
2024-12-21 02:14:59.836 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-12-21 02:14:59.859 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
2024-12-21 02:14:59.899 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-12-21 02:14:59.948 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2024-12-21 02:15:00.997 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2024-12-21 02:15:00.005 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/home-assistant/odroid-c4-homeassistant with version 2024.12.5
2024-12-21 02:15:00.157 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.0 / BootSlot B
2024-12-21 02:15:02.034 ERROR (SyncWorker_0) [supervisor.utils.yaml] Can't read YAML file /data/addons/git/b9a594eb/esphome-dev/config.yaml - while scanning a simple key
2024-12-21 02:15:02.035 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/b9a594eb/esphome-dev/config.yaml from repository b9a594eb
2024-12-21 02:15:02.073 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d6faf732 repository
2024-12-21 02:15:02.077 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
2024-12-21 02:15:02.084 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7eca76cc repository
2024-12-21 02:15:02.094 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-12-21 02:15:02.107 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
2024-12-21 02:15:03.790 ERROR (SyncWorker_5) [supervisor.utils.yaml] Can't read YAML file /data/addons/git/b9a594eb/esphome-dev/config.yaml - while scanning a simple key
2024-12-21 02:15:03.791 WARNING (SyncWorker_5) [supervisor.store.data] Can't read /data/addons/git/b9a594eb/esphome-dev/config.yaml from repository b9a594eb
2024-12-21 02:15:03.823 INFO (MainThread) [supervisor.store] Loading add-ons from store: 131 all - 131 new - 0 remove
2024-12-21 02:15:04.085 INFO (MainThread) [supervisor.addons.manager] Found 6 installed add-ons
2024-12-21 02:15:04.249 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.4.1
2024-12-21 02:15:04.286 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 12.3.2
2024-12-21 02:15:04.291 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2024-12-21 02:15:04.294 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/ssh/aarch64 with version 19.0.0
2024-12-21 02:15:04.296 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/wghaos/addons-get-hacs with version 1.3.1
2024-12-21 02:15:04.299 INFO (MainThread) [supervisor.docker.interface] Attaching to r.hassbus.com/hassio-addons/node-red/aarch64 with version 18.1.1
2024-12-21 02:15:04.554 INFO (MainThread) [supervisor.backups.manager] Found 2 backup files
2024-12-21 02:15:04.568 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2024-12-21 02:15:04.569 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-12-21 02:15:04.569 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-12-21 02:15:04.570 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-21 02:15:04.571 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2024-12-21 02:15:04.571 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-21 02:15:04.572 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2024-12-21 02:15:04.573 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-21 02:15:04.575 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-21 02:15:04.576 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 02:15:04.577 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-12-21 02:15:04.578 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-12-21 02:15:04.579 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 02:15:04.580 INFO (MainThread) [__main__] Running Supervisor
2024-12-21 02:15:04.624 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as good
2024-12-21 02:15:04.661 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-12-21 02:15:04.663 INFO (MainThread) [supervisor.core] Supervisor reboot detected
2024-12-21 02:15:04.666 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-12-21 02:15:04.670 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-12-21 02:15:04.671 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-12-21 02:15:04.675 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-21 02:15:04.675 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-12-21 02:15:04.676 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-21 02:15:04.677 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-12-21 02:15:04.677 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-12-21 02:15:04.678 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-12-21 02:15:04.678 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-12-21 02:15:04.679 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-12-21 02:15:04.705 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-12-21 02:15:04.725 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-21 02:15:04.742 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-12-21 02:15:04.752 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-21 02:15:04.753 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-12-21 02:15:04.754 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-12-21 02:15:04.757 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-21 02:15:04.758 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-12-21 02:15:04.780 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-21 02:15:04.805 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-21 02:15:05.337 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-21 02:15:05.365 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-12-21 02:15:05.539 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-21 02:15:05.540 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-12-21 02:15:05.541 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-21 02:18:09.627 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-21 02:20:20.699 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
2024-12-21 02:22:31.774 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(, 'Connection to o427061.ingest.sentry.io timed out. (connect timeout=None)')': /api/5370612/envelope/
发表于 2024-12-21 11:43:26 | 显示全部楼层
日志提示你的配置yaml文件格式有错误,应该是突然关机掉电或其他集成造成的。
你屏蔽配置中的错误(这个错误导致集成未完全加载,可能阻断了启动流程)
yaml的错误大概是在一个:(冒号)后面,这里缺失了数据(应该有一个值,但是没有,造成解析错误)
 楼主| 发表于 2024-12-21 12:19:22 | 显示全部楼层
你屏蔽配置中的错误(这个错 ...
这个怎么屏蔽,能不能还原上一步更新,因为我完全还没绑定过任何东西
发表于 2024-12-21 14:22:54 | 显示全部楼层
日志提示在这里
这个是容器内的路径
从7681进入的话,路径在
/mnt/data/supervisor/addons目录下
你起不来是因为你安装了esphome的addons。还是开发版本。
开发版本容易有问题,如果不是能处理系统异常的人,尽量不要用
 楼主| 发表于 2024-12-21 15:48:46 | 显示全部楼层
达文西 发表于 2024-12-21 14:22
日志提示在这里
这个是容器内的路径
您的建议是重新刷冬瓜的通刷版本对吧,还是说我简单的通过几个命令把出错的删除?
 楼主| 发表于 2024-12-21 16:02:19 | 显示全部楼层
就是有没有简易一点的命令,几行代码或者下载一个更新把系统替换掉
 楼主| 发表于 2024-12-21 16:38:40 | 显示全部楼层
bilibili,有个教程是直接重置,但是需要输入ssh密码,输入之后提示是网络错误。进去之后只需要删除掉文件夹就能重置成新的还没登陆的,暂时还不行,登录不上
发表于 2024-12-21 17:18:18 | 显示全部楼层
kellan 发表于 2024-12-21 16:38
bilibili,有个教程是直接重置,但是需要输入ssh密码,输入之后提示是网络错误。进去之后只需要删除掉文件 ...
7681端口是web管理界面
进去后是专门的hassos-cli
需要login进入标准linux系统操作
GMT+8, 2025-12-29 14:48 , Processed in 0.710386 second(s), 6 queries , MemCached On.
