楼主: neroxps
hassio 启动详解及群晖运行方法
 火.. [复制链接]
发表于 2018-3-28 10:56:39 | 显示全部楼层
发表于 2018-4-4 10:40:42 | 显示全部楼层
用群晖做不错
发表于 2018-4-4 15:59:20 来自手机 | 显示全部楼层
还是hassio 好用,我先安装的ha,折腾死人了,安装个插件老麻烦了,用了io后好轻松
发表于 2018-4-5 08:00:09 | 显示全部楼层
楼主 我的商店找不着了,这边一堆错误,不知道咋办
18-04-04 23:29:51 WARNING (MainThread) [hassio.api.proxy] Unauthorized websocket access!
18-04-04 23:29:51 INFO (MainThread) [hassio.homeassistant] Detect a running Home-Assistant instance
18-04-04 23:29:52 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request running
18-04-04 23:29:52 WARNING (MainThread) [hassio.api.proxy] Unknown Home-Assistant API access!
18-04-04 23:29:56 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle: <TimerHandle WebSocketResponse._send_heartbeat>
  File "uvloop/cbhandles.pyx", line 201, in uvloop.loop.TimerHandle._run
  File "/usr/lib/python3.6/site-packages/aiohttp/web_ws.py", line 83, in _send_heartbeat
    self._writer.ping()
  File "/usr/lib/python3.6/site-packages/aiohttp/http_websocket.py", line 602, in ping
    return self._send_frame(message, WSMsgType.PING)
  File "/usr/lib/python3.6/site-packages/aiohttp/http_websocket.py", line 582, in _send_frame
    self.transport.write(header + message)
  File "uvloop/handles/stream.pyx", line 636, in uvloop.loop.UVStream.write
  File "uvloop/handles/handle.pyx", line 165, in uvloop.loop.UVHandle._ensure_alive
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e4c030>; the handler is closed
18-04-04 23:30:01 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
    self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e4c1e8>; the handler is closed
18-04-04 23:39:52 WARNING (MainThread) [hassio.api.proxy] Unknown Home-Assistant API access!
18-04-04 23:49:53 WARNING (MainThread) [hassio.api.proxy] Unknown Home-Assistant API access!
发表于 2018-4-5 08:20:24 | 显示全部楼层
用上述命令失败
~ ifconfig hassio down
ifconfig: ioctl 0x8914 failed: Operation not permitted
发表于 2018-4-10 22:41:56 | 显示全部楼层
老大,群晖执行第一条命令后supervisor运行了,但是ha日志出现如下log:
2018/04/10 22:40:18 [error] 24#24: *10 open() "/usr/share/www/api/websocket" failed (2: No
such file or directory), client: ::ffff:192.168.1.43, server: , request: "GET /api/websoc
ket?latest HTTP/1.1", host: "192.168.1.231:8123"
而且HA的镜像只有13M。
求解,谢谢!
发表于 2018-4-15 20:01:47 | 显示全部楼层
支持 学习了
发表于 2018-5-1 11:41:27 | 显示全部楼层
当HASS.IO版本更新时,docker里面就不断重启
 楼主| 发表于 2018-5-3 16:27:20 | 显示全部楼层
此问题已在 2018年5月3日 更新解决。
活跃会员教程狂人
发表于 2018-5-4 14:11:11 | 显示全部楼层
大佬更新了教程,我在mac 下的Docker用您原来的命令安装hassio,homeassistant 容器启动后状态界面提示未连接到网络,不知道是不是也是因为网络问题。。。
所有过往,皆为序章。
GMT+8, 2026-1-9 07:43 , Processed in 0.257866 second(s), 12 queries , MemCached On.
