楼主: 冬瓜HA
冬瓜HAOS:panther-x2刷(支持NPU版)haos16.3.1版正式上线!
发表于 2024-4-6 23:13:43 | 显示全部楼层
大神 能帮我看看 为什么卡在这一步呢
[10:57:40] INFO: Using udev information from host
[10:57:40] INFO: Starting local supervisor watchdog...
23-04-04 10:57:45 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 10:57:45 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-04-04 10:57:46 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi4-64
23-04-04 10:57:46 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
23-04-04 10:57:46 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-04-04 10:57:46 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 10:57:46 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:57:46 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 10:57:51 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 10:57:51 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 10:57:52 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 10:57:52 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:57:52 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:57:52 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 10:57:52 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 10:57:57 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:57:57 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:57:57 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 10:58:02 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:58:02 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2024.03.1'>]
23-04-04 10:58:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
23-04-04 10:58:02 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 10:58:04 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
23-04-04 10:58:04 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2024.03.0'>]
23-04-04 10:58:04 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
23-04-04 10:58:04 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 10:58:06 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
23-04-04 10:58:06 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 10:58:11 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
23-04-04 10:58:11 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 10:58:11 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 10:58:13 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 10:58:13 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-04-04 10:58:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 10:58:13 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-04-04 10:58:15 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-04-04 10:58:15 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
23-04-04 10:58:15 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
23-04-04 10:58:15 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 10:58:17 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
23-04-04 10:58:17 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 10:58:17 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi4-64-homeassistant
23-04-04 10:58:17 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant found.
23-04-04 10:58:17 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
23-04-04 10:58:17 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-04-04 10:58:17 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 10:58:17 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-04-04 10:58:19 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
23-04-04 10:58:19 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 10:58:19 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:20 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:21 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:21 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:22 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:22 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:23 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:23 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:24 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:58:24 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 10:58:24 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 10:58:24 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 10:58:24 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 10:58:24 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 10:58:24 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 10:58:24 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 10:58:24 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:58:24 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-04-04 10:58:24 INFO (MainThread) [__main__] Running Supervisor
23-04-04 10:58:24 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:24 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 10:58:24 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 10:58:24 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 10:58:24 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 10:58:24 INFO (MainThread) [supervisor.core] Start Home Assistant Core
23-04-04 10:58:24 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 10:58:24 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:24 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 10:58:24 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 10:58:24 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1766' coro=<HomeAssistantCore.install() done, defined at /usr/src/supervisor/supervisor/jobs/decorator.py:190> exception=HomeAssistantJobError('Another job is running for job group home_assistant_core')>
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 239, in wrapper
    await obj.acquire(
  File "/usr/src/supervisor/supervisor/jobs/job_group.py", line 58, in acquire
    raise JobGroupExecutionLimitExceeded(
supervisor.exceptions.JobGroupExecutionLimitExceeded: Another job is running for job group home_assistant_core
The above exception was the direct cause of the following exception:
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 244, in wrapper
    raise self.on_condition(str(err)) from err
supervisor.exceptions.HomeAssistantJobError: Another job is running for job group home_assistant_core
23-04-04 10:58:24 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 10:58:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 10:58:25 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:58:25 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 10:58:25 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:25 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:25 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:58:25 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 10:58:26 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:26 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:27 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:27 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:28 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:28 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:29 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:58:29 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 10:58:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 10:58:29 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:29 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
[10:59:48] INFO: Using udev information from host
[10:59:48] INFO: Starting local supervisor watchdog...
23-04-04 10:59:53 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 10:59:53 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi4-64
23-04-04 10:59:53 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
23-04-04 10:59:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 10:59:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:59:54 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 10:59:59 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 10:59:59 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 10:59:59 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 10:59:59 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:59:59 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:59:59 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 10:59:59 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 11:00:04 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 11:00:04 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 11:00:04 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 11:00:09 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:00:09 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
23-04-04 11:00:09 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 11:00:09 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-04-04 11:00:11 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
23-04-04 11:00:11 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
23-04-04 11:00:11 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 11:00:11 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-04-04 11:00:14 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
23-04-04 11:00:14 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 11:00:19 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 11:00:19 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 11:00:19 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
23-04-04 11:00:20 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 11:00:21 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 11:00:21 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
23-04-04 11:00:21 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 11:00:21 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
23-04-04 11:00:23 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
23-04-04 11:00:23 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 11:00:23 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
23-04-04 11:00:23 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 11:00:23 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 11:00:23 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 11:00:24 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 11:00:24 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 11:00:25 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 11:00:25 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 11:00:27 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 11:00:27 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 11:00:28 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:28 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 11:00:28 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 11:00:28 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 11:00:28 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 11:00:28 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 11:00:28 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 11:00:29 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 11:00:29 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 11:00:29 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 11:00:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 11:00:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 11:00:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 11:00:29 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 11:00:29 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-04-04 11:00:29 INFO (MainThread) [__main__] Running Supervisor
23-04-04 11:00:29 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 11:00:29 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 11:00:29 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 11:00:29 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 11:00:29 INFO (MainThread) [supervisor.core] Start Home Assistant Core
23-04-04 11:00:29 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 11:00:30 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 11:00:30 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 11:00:30 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 11:00:30 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 11:00:30 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 11:00:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 11:00:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 11:00:32 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 11:00:32 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 11:00:32 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 11:00:32 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 11:00:35 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:00:35 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:00:35 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 11:00:40 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 11:00:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 11:00:45 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 11:00:45 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 11:00:45 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 11:00:46 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 11:00:46 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-04-04 11:00:51 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
23-04-04 11:00:51 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-04-04 11:01:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:01:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:01:45 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:01:45 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 11:02:19 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 11:02:20 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 11:02:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-04-06 14:30:15 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-04-06 14:30:17 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.4.1
24-04-06 14:30:17 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2024.4.1.
24-04-06 14:30:40 INFO (MainThread) [supervisor.host.control] Initialize host reboot using logind
24-04-06 14:30:40 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
24-04-06 14:30:40 INFO (MainThread) [supervisor.addons.manager] Phase 'application' stopping 0 add-ons
24-04-06 14:30:40 INFO (MainThread) [supervisor.addons.manager] Phase 'services' stopping 0 add-ons
24-04-06 14:30:40 INFO (MainThread) [supervisor.addons.manager] Phase 'system' stopping 0 add-ons
24-04-06 14:30:40 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' stopping 0 add-ons
24-04-06 14:30:40 INFO (MainThread) [supervisor.plugins.cli] Stopping cli plugin
24-04-06 14:30:40 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_cli application
24-04-06 14:30:46 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-04-06 14:30:46 INFO (MainThread) [supervisor.plugins.dns] Stopping CoreDNS plugin
24-04-06 14:30:46 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_dns application
24-04-06 14:30:54 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
24-04-06 14:30:54 INFO (MainThread) [supervisor.plugins.audio] Stopping Audio plugin
24-04-06 14:30:54 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_audio application
24-04-06 14:31:01 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-04-06 14:31:01 INFO (MainThread) [supervisor.plugins.multicast] Stopping Multicast plugin
24-04-06 14:31:01 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_multicast application
24-04-06 14:31:07 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
s6-rc: info: service legacy-services: stopping
[14:31:09] INFO: Watchdog restart after closing
24-04-06 14:31:09 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
24-04-06 14:31:09 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
24-04-06 14:31:09 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
24-04-06 14:31:10 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
24-04-06 14:31:10 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
24-04-06 14:31:10 INFO (MainThread) [supervisor.core] Supervisor is down - 0
24-04-06 14:31:10 INFO (MainThread) [__main__] Closing Supervisor
s6-svwait: fatal: timed out
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[14:32:19] INFO: Using udev information from host
[14:32:19] INFO: Starting local supervisor watchdog...
24-04-06 14:32:25 INFO (MainThread) [__main__] Initializing Supervisor setup
24-04-06 14:32:25 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi4-64
24-04-06 14:32:25 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
24-04-06 14:32:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-04-06 14:32:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-04-06 14:32:25 INFO (MainThread) [__main__] Setting up Supervisor
24-04-06 14:32:28 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-04-06 14:32:28 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-04-06 14:32:28 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-04-06 14:32:28 INFO (MainThread) [supervisor.host.services] Updating service information
24-04-06 14:32:28 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-04-06 14:32:28 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-04-06 14:32:32 INFO (MainThread) [supervisor.host.network] Updating local network information
24-04-06 14:32:32 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-04-06 22:32:35 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-04-06 22:32:35 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-04-06 22:32:37 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
24-04-06 22:32:37 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-04-06 22:32:40 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
24-04-06 22:32:40 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
24-04-06 22:32:41 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-04-06 22:32:47 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
24-04-06 22:32:47 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-04-06 22:32:47 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-04-06 22:32:47 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-04-06 22:32:54 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-04-06 22:32:54 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-04-06 22:32:54 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
24-04-06 22:32:54 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-04-06 22:32:59 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
24-04-06 22:32:59 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-04-06 22:33:00 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
24-04-06 22:33:00 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-04-06 22:33:00 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-04-06 22:33:01 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
24-04-06 22:33:01 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-04-06 22:33:01 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
24-04-06 22:33:01 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-04-06 22:33:01 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
24-04-06 22:33:15 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
  stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Failure when receiving data from the peer
24-04-06 22:33:15 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
24-04-06 22:33:15 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
24-04-06 22:33:15 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
24-04-06 22:35:44 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
  stderr: 'Cloning into '/data/addons/git/5c53de3b'...
POST git-upload-pack (175 bytes)
error: RPC failed; curl 28 Failed to connect to github.com port 443 after 130756 ms: Couldn't connect to server
fatal: expected flush after ref listing
24-04-06 22:35:44 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
24-04-06 22:35:44 INFO (MainThread) [supervisor.store] Loading add-ons from store: 26 all - 26 new - 0 remove
24-04-06 22:35:44 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-04-06 22:35:44 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-04-06 22:35:44 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-04-06 22:35:44 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-04-06 22:35:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-04-06 22:35:44 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-04-06 22:35:44 INFO (MainThread) [__main__] Running Supervisor
24-04-06 22:35:44 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-04-06 22:35:44 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
24-04-06 22:35:45 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
24-04-06 22:35:46 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.03.1
24-04-06 22:35:46 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2024.03.1.
 楼主| 发表于 2024-4-7 15:36:20 | 显示全部楼层
断电重启,继续
发表于 2024-4-11 16:26:43 | 显示全部楼层
冬瓜HA 发表于 2024-4-7 15:36
断电重启,继续
我的N1也可卡这了,试了两天,重刷了两次,重启了七八次还是过不去
 楼主| 发表于 2024-4-11 16:42:21 | 显示全部楼层
wd2wd 发表于 2024-4-11 16:26
24-04-06 22:35:46 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.03.1 ...
联系我,我来看看
发表于 2024-4-11 19:32:05 | 显示全部楼层
要一直长按复位下载完成,还是发现了设备就可以
发表于 2024-4-17 18:42:44 | 显示全部楼层
感谢大佬分享
 楼主| 发表于 2024-4-18 12:03:18 | 显示全部楼层
冬瓜HAOS:panther-x2刷(含盲刷)更新至12.2
发表于 2024-4-18 13:53:31 | 显示全部楼层
盲刷大概多久啊,半个小时了好像都没关机啊
 楼主| 发表于 2024-4-18 14:32:40 | 显示全部楼层
你刷的是我今天上传的吗?如果不是,刷我的最新版本,然后一般5分钟左右,还有尽量白天刷,初始化比较快
发表于 2024-4-18 15:05:51 | 显示全部楼层
就是中午下载的最新版本,刷机和网络有关系吗?
GMT+8, 2025-12-31 20:14 , Processed in 0.254854 second(s), 13 queries , MemCached On.
