- 积分
- 933
- 金钱
- 821
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 933
- 金钱
- 821
- HASS币
- 0
发表于 2024-6-25 15:36:35
显示全部楼层
[07:32:50] INFO: Using udev information from host
[07:32:50] INFO: Starting local supervisor watchdog...
2024-06-25 07:32:54.304 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-06-25 07:32:54.463 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: odroid-c4
2024-06-25 07:32:54.479 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.fastgh.com/home-assistant/aarch64-hassio-supervisor with version 2024.05.1
2024-06-25 07:32:54.479 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-06-25 07:32:54.687 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-06-25 07:32:54.694 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-25 07:32:54.696 INFO (MainThread) [__main__] Setting up Supervisor
2024-06-25 07:32:54.992 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-06-25 07:32:55.150 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-06-25 07:32:55.154 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-06-25 07:32:55.155 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-06-25 07:32:55.157 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-06-25 07:32:55.159 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-06-25 07:32:55.161 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-06-25 07:32:55.163 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-06-25 07:32:55.166 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-06-25 07:32:55.168 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-06-25 07:32:55.171 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-06-25 07:32:55.746 INFO (MainThread) [supervisor.host.services] Updating service information
2024-06-25 07:32:55.762 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-06-25 07:32:55.769 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2024-06-25 07:32:56.002 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-06-25 07:32:56.179 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-06-25 15:32:56.954 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-06-25 15:32:56.956 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/cm311-release-cn.json
2024-06-25 15:32:57.018 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.05.0
2024-06-25 15:32:57.030 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_cli application
2024-06-25 15:33:00.381 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
2024-06-25 15:33:00.419 INFO (SyncWorker_0) [supervisor.docker.manager] Removing image ghcr.io/home-assistant/aarch64-hassio-cli with latest
2024-06-25 15:33:00.427 INFO (SyncWorker_0) [supervisor.docker.manager] Removing image ghcr.io/home-assistant/aarch64-hassio-cli with 2024.05.0
2024-06-25 15:33:00.448 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.fastgh.com/home-assistant/aarch64-hassio-cli with tag 2024.05.0.
2024-06-25 15:33:07.277 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2024-06-25 15:33:08.086 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.fastgh.com/home-assistant/aarch64-hassio-cli with version 2024.05.0 - 172.30.32.5
2024-06-25 15:33:08.151 INFO (MainThread) [supervisor.docker.interface] Found ghcr.fastgh.com/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2024.04.0'>]
2024-06-25 15:33:08.176 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0
2024-06-25 15:33:08.218 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-06-25 15:33:09.063 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.fastgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
2024-06-25 15:33:09.067 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-06-25 15:33:09.126 INFO (MainThread) [supervisor.docker.interface] Found ghcr.fastgh.com/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
2024-06-25 15:33:09.153 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
2024-06-25 15:33:09.188 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2024-06-25 15:33:10.381 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.fastgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
2024-06-25 15:33:10.429 INFO (MainThread) [supervisor.docker.interface] Found ghcr.fastgh.com/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
2024-06-25 15:33:10.461 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-06-25 15:33:10.506 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2024-06-25 15:33:11.527 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.fastgh.com/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
2024-06-25 15:33:11.604 INFO (MainThread) [supervisor.docker.interface] Found ghcr.fastgh.com/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
2024-06-25 15:33:11.631 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2024-06-25 15:33:11.671 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-06-25 15:33:12.210 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.fastgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
2024-06-25 15:33:12.217 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2024-06-25 15:33:12.258 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant
2024-06-25 15:33:12.259 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant found.
2024-06-25 15:33:12.289 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant with version landingpage
2024-06-25 15:33:12.290 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
2024-06-25 15:33:12.300 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2024-06-25 15:33:12.381 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-06-25 15:33:13.003 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant with version landingpage
2024-06-25 15:33:13.090 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.3.1 / BootSlot A
2024-06-25 15:33:13.102 INFO (MainThread) [supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-esphome-addons repository
2024-06-25 15:33:13.106 INFO (MainThread) [supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-git-addons repository
2024-06-25 15:33:13.113 INFO (MainThread) [supervisor.store.git] Cloning add-on https://gitcode.com/waxgourd/ha-core-addons repository
2024-06-25 15:33:16.342 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
2024-06-25 15:33:16.486 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2024-06-25 15:33:16.593 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2024-06-25 15:33:16.594 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2024-06-25 15:33:16.595 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-06-25 15:33:16.596 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-06-25 15:33:16.597 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-06-25 15:33:16.598 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-06-25 15:33:16.600 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-06-25 15:33:16.601 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-06-25 15:33:16.603 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-25 15:33:16.604 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-06-25 15:33:16.605 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-06-25 15:33:16.606 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-25 15:33:16.607 INFO (MainThread) [__main__] Running Supervisor
2024-06-25 15:33:16.639 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
2024-06-25 15:33:16.684 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.wghaos.com/apparmor_stable.txt
2024-06-25 15:33:16.696 ERROR (MainThread) [supervisor.supervisor] Can't fetch AppArmor profile https://version.wghaos.com/apparmor_stable.txt: Cannot connect to host version.wghaos.com:443 ssl:default [Name has no usable address]
2024-06-25 15:33:16.696 CRITICAL (MainThread) [supervisor.supervisor] Abort update because of an issue with AppArmor: Can't fetch AppArmor profile https://version.wghaos.com/apparmor_stable.txt: Cannot connect to host version.wghaos.com:443 ssl:default [Name has no usable address]
2024-06-25 15:33:16.697 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
2024-06-25 15:33:16.697 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-06-25 15:33:16.735 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2024-06-25 15:33:16.736 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2024-06-25 15:33:16.751 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2024-06-25 15:33:16.751 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2024-06-25 15:33:16.761 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-06-25 15:33:16.766 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-06-25 15:33:16.770 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2024-06-25 15:33:16.773 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant:landingpage to ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant:2024.6.4
2024-06-25 15:33:16.775 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.fastgh.com/home-assistant/odroid-c4-homeassistant with tag 2024.6.4.
2024-06-25 15:33:16.776 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-06-25 15:33:16.785 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-06-25 15:33:16.786 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-06-25 15:33:16.833 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
2024-06-25 15:33:16.853 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-06-25 15:33:16.854 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-06-25 15:33:16.855 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-06-25 15:33:16.856 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-06-25 15:33:16.874 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
2024-06-25 15:33:16.875 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-06-25 15:33:16.876 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-06-25 15:33:16.877 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-06-25 15:33:16.880 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-06-25 15:33:16.889 INFO (MainThread) [supervisor.host.services] Updating service information
2024-06-25 15:33:16.918 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-06-25 15:33:16.921 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
2024-06-25 15:33:16.922 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-06-25 15:33:16.937 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
2024-06-25 15:33:16.938 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-06-25 15:33:16.939 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-06-25 15:33:16.940 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-06-25 15:33:16.941 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-06-25 15:33:16.941 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-06-25 15:33:17.509 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-06-25 15:33:17.549 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-06-25 15:33:18.997 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-25 15:33:18.998 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
这是啥原因 , 教程没看仔细 没看见等20分钟在关机拔U盘。 |
