楼主: 冬瓜HA
填坑:魔百盒CM311-1a、M401a、unt403a刷冬瓜HAOS指南(已停更)
发表于 2024-6-22 08:47:48 | 显示全部楼层
向冬瓜大佬求救啊,  群晖VMW虚拟机安装的 冬瓜os  稳定, 一直没拍快照,现在崩了, 能分析一二不?
提示:
You are in rescue mode, After logging in, type " journalctl -xb" to viewsustem logs,sustemctl reboot"to rebootsustemctl default' or "exitto boot into default mode .
ress Enter for maintenance(or press Control-D to continue):Reloading system manager confiqurationStarting default .target
然后 journalctl -xb  日志是  :JUY20]0]-2.100:41:1homeass1stant400:41:15T0MeasS1S1a712200:41:15JLY00:41:15homeassistantu00:41:15222homeassistant2700:41:1522homeassistant00:41:154)00:41:15u0Me62200:41:15 homeassistant400:41:151stantu2200:41:15homeassistantu?00 :41:15homeassistant00:41:15homeassistant00:41:1522UaMess81s1anT00:41:15homeassistant00:41:15uV2200:41:15homeassistant00:41:15hoMeass00:41:15L0Mea号5R00:41:15homeasSistant00:41:15istanthoMeass2200:41:15homeassistantU700:41:15homeassistant4)00:41:1522homeassistant00:41:15JuY22homeaSistanT00:41:15homeassistant47200:41:15homeassistantu700:41:1522homeassistant00:41:15U22homeassistant00:41:1522UYhomeassistant00:41:15 homeassistantJuN22Ju72200:41:15 homeassistant
6.6.16-haos (darcued11-compiled-haos10)(x86 64A71einux vers1onCommand line :BO0T IMAGE=(hd0,gpt2)/bzImage root=PARTUUID=8d3dKerneBI0S-provided physical RAM map :Kerne]BI0S-e820:0X0000000000000000-0x00000000000号IKernelMeMBI0S-e820 :kerne l:[MeM0x0000000000100000BI0S-e820 :KernelMeM01c0T0T0T0T0T0T0T0T0T01-10TBIOSkernel:-e820:01C00000000000H00MeMBI0S-e820 :kerne l:0x0000000000R0b000MemBI0S-e820:Kernel:MeMkerne l:BI0S-e820 :MeMBI0S-e820 :Kernel:MeMBI0S-e820 :Kernel:MerBIOSkerne l:-e820:[MeMBI0S-e820 :KernelMeMBIOSkernel:-e820 MeM.01C0T0101010T010BIOSKernel:-e820 :[MerBI0S-e820:MeMBIOS-e820:0C0000000KernelMeMBI0S-e820:[MeMkerne l:0c0101010101010107h0100BI0S-e820:KernelMeM0x000000007feec000-BI0S-e820 mem 0x000000007270000-0x000000007Pkernel:Kernel:BI0S-e820:Imem 0x00000000ffc00000-0x00000000ffffffff1NXxecute Disable)protection: activeKerne:kerne lAPIC: Static calls initializedefi: EFI U2.? bu EDK IIKerneefi:TPMFinalLog=0x?fbd7000 SMBI0S=0x7f923000 ACPI=0x7fb7e000Kerne:efi: Remove mem133:MMI0 range=[0xffc00000-0xffffffff](4MB)kernel:e820:remove 【mem xffc00000-0xffffffffl reseruedKernelSMBI0S 2.8 presentkerne lDMI:0EMU Standard PC(i440FX+PIIX,1996),BI0S 0.0.0 02/06kernel:Hupervisor detected:KUMKernekum-clock: Using msrs 4b564d01 and 4b564d00kernel:kernel:kum-clock: using sched offset of 125265167145563 cucleskernel:clocksource:kum-clock:mask:0xffffffffffffffff max cucles:0tscetected 3408.000 MHz rocessore820:update 【mem 0x00000000-0x00000fffl usable
lsabé-0xc00000000007号是是是usableAL1010101010101010H0A0P000000000日0-卡个usable000000000Bobfff1ACPI NUusableJ00000000S0号华ACPI NU00000PSPA00000007f011±ffIusable90000002P09bfPP1reserVe0000?fBeefftusable0000?f9eefffreserUetype 200000000taee100000?fb6efff1reserue1010101007Ph7ePPAACPTdaACPI NU00000072hfe是x000000007feebfff1usable0x00000000ZPP6fPPPIreserUEACPI NUreseruereserved三三>
homeassistant kernel:
22 00:41:15 homeassistant
Jun
Jun
00:41:15 homeassistant kernel:
Jun 22 00:41:15 homeassistant kernel:
standard input lines 1-36
发表于 2024-6-22 09:26:56 | 显示全部楼层
rmyyzf 发表于 2024-6-21 15:57
CM311-1a是个好的选择!!
好滴 这就去买
发表于 2024-6-22 10:00:20 | 显示全部楼层
CM311-1a是个好的选择!!
这款盒子 Ch和Yst 版本有区别吗 ,小黄鱼看了一会 发现有人标yst
 楼主| 发表于 2024-6-22 10:35:59 | 显示全部楼层
相对来说,YST(易 视腾)常见一些,CH(长虹),差不多的。
发表于 2024-6-22 14:20:30 | 显示全部楼层
好滴 那应该买哪款设备呢?
我的需求:
1、刷机好刷,不想折腾。
2、功耗最好低点
楼上有人和我说 CM311-1a 这款,但是刚刚看您另外帖子下面有黑豹X2(PantherX2),论坛里面说这款黑豹最适合hass,内存运存都比魔百盒大,想请大佬指点下
 楼主| 发表于 2024-6-22 14:46:15 | 显示全部楼层
taoli 发表于 2024-6-22 14:20
好滴 那应该买哪款设备呢?
我的需求:
1、刷机好刷,不想折腾。
看你如何想,rk3566是未来首选。这些功耗都不高。
二手机和新机,自己看着选。我也推出一个新机型,rk3566方案的,也可以了解一下。
发表于 2024-6-24 09:07:09 | 显示全部楼层
二手机和新机,自己看着选。我也推出一个新机型,rk356 ...
RK3566这是那个机型,你这还没有上链接吗?弄个好看点的盒子机型,4+32起步   芯片用最新得RK3566,估计会很好用。2+16有点低配了。
发表于 2024-6-24 16:59:38 | 显示全部楼层
longfei12k 发表于 2024-6-24 09:07
RK3566这是那个机型,你这还没有上链接吗?弄个好看点的盒子机型,4+32起步   芯片用最新得RK3566,估计会 ...
大佬 同问
发表于 2024-6-24 18:55:28 | 显示全部楼层
大佬,CM311-1a CH,这个版本可以用不
发表于 2024-6-24 20:10:30 | 显示全部楼层
非常感情 unt403a  2+16gb 刷好了!非常感谢!有个问题。matter(beta)服务不能启动是什么原因!蓝牙模块呢 有时候会有问题!重启可以解决!
GMT+8, 2026-1-20 08:46 , Processed in 0.059601 second(s), 13 queries , MemCached On.
