楼主: muxiachuixue
[技术探讨] 干货:ChatGPT接入Siri,让HomePod/CarPlay智能化
发表于 2023-7-12 01:20:56 | 显示全部楼层
换了新的快捷指令,现在显示这样的
 楼主| 发表于 2023-7-12 10:03:59 | 显示全部楼层
gosrak 发表于 2023-7-12 01:20
换了新的快捷指令,现在显示这样的
要把poe chat集成也更新到1.0.4版本,然后重启HA
 楼主| 发表于 2023-7-12 10:05:49 | 显示全部楼层
dscao 发表于 2023-7-11 23:40
暂时不知是不是代理出问题了,这个还是网络连接不上。修改配置保存有点慢,但能成功。
但小主机对官方接 ...
换一个bot看看,或者换成美国的ip,我这边一切都正常。对了,昨天晚上poe官方出问题了,你可以今天再试试
发表于 2023-7-12 10:48:09 | 显示全部楼层
昨晚HACS那里也更新不了,看到集成升级到1.03了更新不了。。。
3万
发表于 2023-7-12 11:43:09 | 显示全部楼层
muxiachuixue 发表于 2023-7-12 10:05
换一个bot看看,或者换成美国的ip,我这边一切都正常。对了,昨天晚上poe官方出问题了,你可以今天再试试 ...
换成Sage机器人就正常了,chinchilla就是不行。
但问了三次后又提示超时了,难道是频率限制了?
AttributeError: 'PoeClient' object has no attribute 'suggestion_callbacks'
File "/config/custom_components/poe_chat/poe.py", line 479, in on_message
2023-07-12 11:43:55.930 ERROR (Thread-34 (ws_run_thread)) [websocket] error from callback <bound method Client.on_message of <custom_components.poe_chat.PoeClient object at 0x7f71f4870bd0>>: SOCKSHTTPSConnectionPool(host='poe.com', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1002)')))
2023-07-12 11:43:55.936 ERROR (Thread-33 (ws_run_thread)) [websocket] error from callback <bound method Client.on_message of <custom_components.poe_chat.PoeClient object at 0x7f71f4870bd0>>: SOCKSHTTPSConnectionPool(host='poe.com', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1002)')))
2023-07-12 11:43:55.952 ERROR (Thread-37 (ws_run_thread)) [websocket] error from callback <bound method Client.on_message of <custom_components.poe_chat.PoeClient object at 0x7f71f4870bd0>>: SOCKSHTTPSConnectionPool(host='poe.com', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1002)')))
登录poe网页发现后来问的当时没提交成功,但是刷新后提交是成功了也有结果返回了。可能反馈太慢了一点,导致siri在超时时间内没收到消息。
发表于 2023-7-12 11:50:06 | 显示全部楼层
我等可以了也换个BOT试试,我最近试的是Claude
 楼主| 发表于 2023-7-12 12:25:37 | 显示全部楼层
可以去github上直接重新下载的
 楼主| 发表于 2023-7-12 12:26:49 | 显示全部楼层
更新到v1.0.4试试
发表于 2023-7-12 21:17:27 | 显示全部楼层
都更新到最新了,换了bot用sage的,显示这个
 楼主| 发表于 2023-7-12 21:57:52 | 显示全部楼层
没有写入权限,你node-red是在HA里面安装的么?进HA的docker环境,然后执行
chmod -R 777 /config/www/poe_chat
GMT+8, 2026-1-15 19:43 , Processed in 0.597922 second(s), 10 queries , MemCached On.
