楼主: muxiachuixue
[技术探讨] 干货:ChatGPT接入Siri,让HomePod/CarPlay智能化
 楼主| 发表于 2023-7-14 23:37:54 | 显示全部楼层
shadowdoggie 发表于 2023-7-14 13:11
按照流程找到的p-b,ha出现下面的错误日志,有大佬遇到过吗
Logger: custom_components.poe_chat
Source: c ...
配置集成的时候出现的?看看有没有其他日志
发表于 2023-7-18 10:24:13 | 显示全部楼层
这个是过期吗?
 楼主| 发表于 2023-7-18 14:49:30 | 显示全部楼层
gosrak 发表于 2023-7-18 10:24
这个是过期吗?
这个没关系,可以升级一下1.0.5版本,这个版本应该解决了过一段时间就无响应的bug了
发表于 2023-7-20 09:58:20 | 显示全部楼层
这个对于最新版的ha 7月的新版支持是不是没有那么好
3万
发表于 2023-7-20 21:53:09 | 显示全部楼层
现在试了一下1.0.5版本,目前测试基本正常了。
发表于 2023-7-20 23:28:57 | 显示全部楼层
Source: c ...
一样的报错。之前能用,突然之间就开始报这个错
删掉集成重新添加提示的错误日志如下:
电脑用浏览器访问poe.com正常,感觉是被封了?
Server returned a status code of 403 while downloading https://poe.com. Retrying (6/10)...
Server returned a status code of 403 while downloading https://poe.com. Retrying (7/10)...
Server returned a status code of 403 while downloading https://poe.com. Retrying (8/10)...
Server returned a status code of 403 while downloading https://poe.com. Retrying (9/10)...
Server returned a status code of 403 while downloading https://poe.com. Retrying (10/10).
Error handling request
  File "/config/custom_components/poe_chat/__init__.py", line 220, in init
    self.setup_connection()
  File "/config/custom_components/poe_chat/poe.py", line 177, in setup_connection
    self.next_data = self.get_next_data(overwrite_vars=True)
  File "/config/custom_components/poe_chat/poe.py", line 219, in get_next_data
    r = request_with_retries(self.session.get, self.home_url)
  File "/config/custom_components/poe_chat/poe.py", line 80, in request_with_retries
    raise RuntimeError(f"Failed to download {url} too many times.")
RuntimeError: Failed to download https://poe.com too many times.
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 181, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 297, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 393, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/config/custom_components/poe_chat/config_flow.py", line 36, in async_step_user
    if acc := await get_client_from_config(self.hass, user_input, renew=True):
  File "/config/custom_components/poe_chat/__init__.py", line 105, in get_client_from_config
    await client.async_init()
  File "/config/custom_components/poe_chat/__init__.py", line 216, in async_init
    return await self.hass.async_add_executor_job(partial(self.init))
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/poe_chat/__init__.py", line 227, in init
    exc, self.session.cookies, self.get_websocket_url(), self.channel, self.gql_headers, self.bot_names,
  File "/config/custom_components/poe_chat/poe.py", line 336, in get_websocket_url
    query = f'?min_seq={channel["minSeq"]}&channel={channel["channel"]}&hash={channel["channelHash"]}'
TypeError: 'NoneType' object is not subscriptable
 楼主| 发表于 2023-7-21 23:05:10 | 显示全部楼层
删掉集成重新添加提示的错误日志如下:
电脑用浏览器访问p ...
昨天有段时间Poe的接口有点问题,今天又好了,如果后面还这样,我再考虑修改一下poe-api的代码
 楼主| 发表于 2023-7-21 23:08:37 | 显示全部楼层
v1.0.6新增了不发消息就可以重连websocket的功能。在新版的快捷指令(v1.2)里面,我将重连websocket放在了Siri欢迎语之前,这样在用户提出第一句问题后,就不需要等待websocket重连了,响应速度更快,体验更好。另外将轮询时间改成了0.1秒,句子与句子之间的等待时间更短
发表于 2023-7-22 12:01:40 | 显示全部楼层
muxiachuixue 发表于 2023-7-21 23:05
昨天有段时间Poe的接口有点问题,今天又好了,如果后面还这样,我再考虑修改一下poe-api的代码 ...
我这里试还是不行。和鸡场的IP地区有关吗?我的是美丽国的更新:
确实是代理问题。不能细讲的问题留个MARK,给其他人个排查思路
3万
发表于 2023-7-22 12:34:28 | 显示全部楼层
muxiachuixue 发表于 2023-7-21 23:08
v1.0.6新增了不发消息就可以重连websocket的功能。在新版的快捷指令(v1.2)里面,我将重连websocket放在 ...
刚刚测试了一下最新版,效果挺好的。
GMT+8, 2026-1-15 20:04 , Processed in 1.082343 second(s), 9 queries , MemCached On.
