楼主: c1pher_小愚
[插件集成] 百度人脸识别插件更新
发表于 2023-2-28 11:57:00 | 显示全部楼层
学习了,谢谢分享
发表于 2023-2-28 12:07:21 | 显示全部楼层
HA Docker 最新版出错
检查Yaml提示
Platform error sensor.baidu_face - Requirements for baidu_face not found: 【'pillow==9.2.0'】.
日志提示
Unable to install package pillow==9.2.0: ERROR: Cannot install pillow==9.2.0 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/to ... ependency-conflicts
发表于 2023-2-28 12:29:08 | 显示全部楼层
修改mainfest
"requirements": ["baidu-aip==2.2.18.0","pillow>=9.2.0"]
检查Yaml不报错了
但是日志提示
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 293, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/baidu_face/sensor.py", line 108, in setup_platform
    add_devices([FaceSensor(name, camera_entity_id, port, token, baidu_client, group_list, options, tmp_path, DEFAULT_REQUEST_TYPE, local_file)])
UnboundLocalError: local variable 'DEFAULT_REQUEST_TYPE' referenced before assignment
hyq
发表于 2023-3-20 17:18:32 | 显示全部楼层
搞不定!实体什么都有,也没报错。查看百度人脸识别没有调用记录!不知道是哪里出了问题!
发表于 2023-4-18 13:52:13 | 显示全部楼层
25989406 发表于 2022-11-23 17:55
可以准确判断是你家里的谁出现在了摄像头里
具体怎么用看你想象喽
把隔壁老王抓出来
GMT+8, 2026-1-17 08:33 , Processed in 0.702327 second(s), 9 queries , MemCached On.
