楼主: c1pher_小愚
[插件集成] 百度人脸识别插件更新
发表于 2022-11-29 17:42:25 | 显示全部楼层
我的版本是
Home Assistant 2022.10.0
Supervisor 2022.11.2
前端版本: 20221005.0 - latest
 楼主| 发表于 2022-11-30 01:28:11 | 显示全部楼层
我问你的是日志
 楼主| 发表于 2022-11-30 01:30:21 | 显示全部楼层
你configuration.yaml文件在哪个目录里?
发表于 2022-11-30 10:24:10 | 显示全部楼层
configuration.yaml文件在这个位置:
 楼主| 发表于 2022-11-30 16:41:11 | 显示全部楼层
把配置里的中文的注释去了看看,我有点没有头绪了
slwl 手机认证
发表于 2022-12-4 09:35:01 | 显示全部楼层
Logger: homeassistant.components.sensor
Source: custom_components/face_detect/sensor.py:289
Integration: 传感器 (documentation, issues)
First occurred: 09:27:10 (3 occurrences)
Last logged: 09:27:12
face_detect: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 446, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 702, in async_device_update
    await task
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/face_detect/sensor.py", line 132, in update
    self._data.update()
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 192, in wrapper
    result = method(*args, **kwargs)
  File "/config/custom_components/face_detect/sensor.py", line 289, in update
    if (res1["result"] is  None):
KeyError: 'result'
slwl 手机认证
发表于 2022-12-4 09:36:12 | 显示全部楼层
没有实体,日志错误如上
slwl 手机认证
发表于 2022-12-8 12:08:52 | 显示全部楼层
百度接口是不是变了。免费限额了
 楼主| 发表于 2022-12-8 17:21:41 | 显示全部楼层
slwl 发表于 2022-12-8 12:08
百度接口是不是变了。免费限额了
一直都是免费的
slwl 手机认证
发表于 2022-12-9 20:01:01 | 显示全部楼层
还是没成功,提示
homeassistant Unable to install package pillow==9.2.0
GMT+8, 2026-1-17 08:31 , Processed in 0.591576 second(s), 8 queries , MemCached On.
