楼主: louis_lee
[经验分享] Deprecated
发表于 2023-6-28 11:14:48 | 显示全部楼层
2023-06-28 09:54:54  [INFO    ] ---- Webdriver initialized.
2023-06-28 09:55:05  [INFO    ] ---- Login successfully on https://www.95598.cn/osgweb/login
2023-06-28 09:55:08  [INFO    ] ---- get all user id: ['123', '456']
2023-06-28 09:55:13  [INFO    ] ---- Get electricity charge balance for 123 successfully, balance is 338.53 CNY.
2023-06-28 09:59:13  [ERROR   ] ---- state-refresh task failed, reason is Message: no such element: Unable to locate element: {"method":"xpath","selector":"//ul[@class='el-scrollbar__view el-select-dropdown__list']/li[2]"}
  (Session info: headless chrome=90.0.4430.212)
大佬帮忙看看这个报错,我两个户号,123户号的balance其实是456户号的上月电费,
发表于 2023-6-29 15:46:41 | 显示全部楼层
支持一下,大大不弄个dockhub吗,盗版的都有了
 楼主| 发表于 2023-6-29 16:57:32 | 显示全部楼层
有的,git仓库发布后,会自动同步生产镜像并上传至同ID dockerhub下。
发表于 2023-6-30 14:37:48 | 显示全部楼层
必须要再赞一个
发表于 2023-7-6 16:09:31 | 显示全部楼层
<2023-07-06 15:54:02  [INFO    ] ---- Webdriver initialized.
#Traceback (most recent call last):
1  File "/app/data_fetcher.py", line 30, in fetch
2023-07-06 15:58:55  [ERROR   ] ---- Webdriver quit abnormly, reason: Login failed, maybe caused by 1.incorrect phone_number and password, please double check. or 2. network, please mnodify LOGIN_EXPECTED_TIME in const.py and rebuild.. 2 retry times left.
    return self._fetch()
2  File "/app/data_fetcher.py", line 47, in _fetch
    self._login(driver)
3  File "/app/data_fetcher.py", line 115, in _login
�    raise Exception("Login failed, maybe caused by 1.incorrect phone_number and password, please double check. or 2. network, please mnodify LOGIN_EXPECTED_TIME in const.py and rebuild.")
�Exception: Login failed, maybe caused by 1.incorrect phone_number and password, please double check. or 2. network, please mnodify LOGIN_EXPECTED_TIME in const.py and rebuild.
大佬救命 一直报这个错误
 楼主| 发表于 2023-7-6 16:32:32 | 显示全部楼层
请按照1楼的Q&A部分试试
发表于 2023-7-6 16:47:46 | 显示全部楼层
addons安装的,交作业!
发表于 2023-7-6 17:06:20 | 显示全部楼层
louis_lee 发表于 2023-7-6 16:32
请按照1楼的Q&A部分试试
LOGIN_URL = "https://www.95598.cn/osgweb/login"
ELECTRIC_USAGE_URL = "https://www.95598.cn/osgweb/electricityCharge"
BALANCE_URL = "https://www.95598.cn/osgweb/userAcc"
SUPERVISOR_URL = "http://supervisor/core"
API_PATH = "/api/states/"
BALANCE_SENSOR_NAME = "sensor.electricity_charge_balance"
DAILY_USAGE_SENSOR_NAME = "sensor.last_electricity_usage"
YEARLY_USAGE_SENSOR_NAME = "sensor.yearly_electricity_usage"
YEARLY_CHARGE_SENESOR_NAME = "sensor.yearly_electricity_charge"
BALANCE_UNIT = "CNY"
USAGE_UNIT = "kWh"
JOB_INTERVAL_HOURS = 12  # Please DO NOT make it too frequently.
DRIVER_IMPLICITY_WAIT_TIME = 240
RETRY_TIMES_LIMIT = 5
LOGIN_EXPECTED_TIME = 30
RETRY_WAIT_TIME_OFFSET_UNIT = 10
  已经改了并且重新build了好几次了 大佬 快崩溃了
发表于 2023-7-6 17:47:40 | 显示全部楼层
请按照1楼的Q&A部分试试
成功了 大佬 感谢
发表于 2023-7-11 10:10:08 | 显示全部楼层
大佬这个帖子内容是没有了吗
GMT+8, 2026-1-16 04:49 , Processed in 1.321316 second(s), 12 queries , MemCached On.
