楼主: louis_lee
[经验分享] Deprecated
发表于 2023-3-30 10:36:55 | 显示全部楼层
louis_lee 发表于 2023-3-30 10:19
看你贴的这个配置,不太对啊,没贴全吧
老大 下面这个是全配置文件,我发现只有第一个户号的带entity的显示数据 第二个户号的就不显示了显示unknow
template:
  - trigger:
      - platform: event
        event_type: "state_changed"
        event_data:
          entity_id: sensor.electricity_charge_balance_12002814788
      - name: electricity_charge_balance_12002814788
        unique_id: electricity_charge_balance_12002814788_entity
        state: "{{ states('sensor.electricity_charge_balance_12002814788') }}"
        state_class: measurement
        unit_of_measurement: "CNY"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.last_electricity_usage_12002814788
      - name: last_electricity_usage_12002814788_entity
        unique_id: last_electricity_usage_12002814788_entity
        state: "{{ states('sensor.last_electricity_usage_12002814788) }}"
        unit_of_measurement: "KWH"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_usage_12002814788
      - name: yearly_electricity_usage_12002814788_entity
        unique_id: yearly_electricity_usage_12002814788_entity
        state: "{{ states('sensor.yearly_electricity_usage_12002814788') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_charge_12002814788
      - name: yearly_electricity_charge_12002814788_entity
        unique_id: yearly_electricity_charge_12002814788_entity
        state: "{{ states('sensor.yearly_electricity_charge_12002814788') }}"
#电费-车位
#template 1:
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.electricity_charge_balance_12003101098
      - name: electricity_charge_balance_12003101098_entity
        unique_id: electricity_charge_balance_12003101098_entity
        state: "{{ states('sensor.electricity_charge_balance_12003101098') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.last_electricity_usage_12003101098
      - name: last_electricity_usage_12003101098_entity
        unique_id: last_electricity_usage_12003101098_entity
        state: "{{ states('sensor.last_electricity_usage_12003101098') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_usage_12003101098
      - name: yearly_electricity_usage_12003101098_entity
        unique_id: yearly_electricity_usage_12003101098_entity
        state: "{{ states('sensor.yearly_electricity_usage_12003101098') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_charge_12003101098
      - name: yearly_electricity_charge_12003101098_entity
        unique_id: yearly_electricity_charge_12003101098_entity
        state: "{{ states('sensor.yearly_electricity_charge_12003101098') }}"
#电费-静海
#template 2:
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.electricity_charge_balance_12001649156
      - name: electricity_charge_balance_1200164915673_entity
        unique_id: electricity_charge_balance_12001649156_entity
        state: "{{ states('sensor.electricity_charge_balance_12001649156') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.last_electricity_usage_12001649156
      - name: last_electricity_usage_12001649156_entity
        unique_id: last_electricity_usage_12001649156_entity
        state: "{{ states('sensor.last_electricity_usage_12001649156') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_usage_12001649156
      - name: yearly_electricity_usage_12001649156_entity
        unique_id: yearly_electricity_usage_12001649156_entity
        state: "{{ states('sensor.yearly_electricity_usage_12001649156') }}"
  - trigger:
      - platform: event
        event_data:
          entity_id: sensor.yearly_electricity_charge_12001649156
      - name: yearly_electricity_charge_12001649156_entity
        unique_id: yearly_electricity_charge_12001649156_entity
        state: "{{ states('sensor.yearly_electricity_charge_12001649156') }}"
 楼主| 发表于 2023-3-30 13:37:07 | 显示全部楼层
dinglifeng 发表于 2023-3-30 10:36
老大 下面这个是全配置文件,我发现只有第一个户号的带entity的显示数据 第二个户号的就不显示了显示unkn ...
有那么几种可能哈
1 配置中的用电账户配置错误
2 先启动的加载项,然后再添加的配置文件
如果是2的话,可以等待下次数据更新时(明天),数据会同步。
发表于 2023-3-30 13:50:08 | 显示全部楼层
louis_lee 发表于 2023-3-23 10:13
其他加载项能正常使用嘛?比如node-red?
谢谢大佬关心,我把树莓派断电重启后就正常了。之前怎么重启都不行
发表于 2023-3-31 08:29:01 | 显示全部楼层
louis_lee 发表于 2023-3-30 13:37
有那么几种可能哈
1 配置中的用电账户配置错误
老大 奇怪的是 不带entity后缀的 sensor 可以显示余额的 那是不是就能证明账户配置没问题? 我觉得应该是template 生成的实体取不到值……您帮我看看我写的配置文件有没有问题?
 楼主| 发表于 2023-3-31 09:12:03 | 显示全部楼层
dinglifeng 发表于 2023-3-31 08:29
老大 奇怪的是 不带entity后缀的 sensor 可以显示余额的 那是不是就能证明账户配置没问题? 我觉得应该是 ...
取不到指的原因,是因为这个配置是在原值变化的时候才能取到值
zzr 手机认证
发表于 2023-4-8 10:25:07 | 显示全部楼层
没毛病,就是实现这个真的需要再装个容器吗。。。。
 楼主| 发表于 2023-4-8 10:46:33 | 显示全部楼层
已经在1L说明了,主要是依赖兼容问题
有好的解决方案嘛?
发表于 2023-4-8 22:06:04 | 显示全部楼层
楼主请指教,我这里怎么显示找不到sgcc_electricity
发表于 2023-5-20 19:42:24 来自手机 | 显示全部楼层
N1 上 用docker 部署的  运行有出现故障
  File "/app/data_fetcher.py", line 23, in __init__,
    self._chromium_version = self._get_chromium_version(),
  File "/app/data_fetcher.py", line 261, in _get_chromium_version,
    result = str(subprocess.check_output(["chromium", "--product-version"])),
  File "/usr/local/lib/python3.8/subprocess.py", line 415, in check_output,
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,,
  File "/usr/local/lib/python3.8/subprocess.py", line 516, in run,
    raise CalledProcessError(retcode, process.args,,
subprocess.CalledProcessError: Command '['chromium', '--product-version']' died with <Signals.SIGSEGV: 11>.,
2023-05-20 19:28:11  [INFO    ] ---- Service start!,
Traceback (most recent call last):,
  File "./main.py", line 80, in <module>,
    main(),
  File "./main.py", line 17, in main,
    fetcher = DataFetcher(args["phone_number"], args["password"]),
2023-05-20 19:28:20  [INFO    ] ---- Service start!,
    main(),
2023-05-20 19:28:30  [INFO    ] ---- Service start!,
    main(),
2023-05-20 19:31:50  [INFO    ] ---- Service start!,
    main(),
2023-05-20 19:31:57  [INFO    ] ---- Service start!,
    main(),
2023-05-20 19:32:05  [INFO    ] ---- Service start!,
    main(),
2023-05-20 19:32:13  [INFO    ] ---- Service start!,
大佬 这是啥问题
发表于 2023-5-29 18:01:36 | 显示全部楼层
谢谢分享
GMT+8, 2026-1-16 04:49 , Processed in 1.295931 second(s), 11 queries , MemCached On.
