楼主: louis_lee
[经验分享] Deprecated
发表于 2023-3-21 09:58:47 | 显示全部楼层
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.electricity_charge_balance_7000122099. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.last_electricity_usage_7000122099. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_usage_7000122099. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_charge_7000122099. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.electricity_charge_balance_5012805881. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.last_electricity_usage_5012805881. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_usage_5012805881. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_charge_5012805881. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.electricity_charge_balance_7038020760. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.last_electricity_usage_7038020760. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_usage_7038020760. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_charge_7038020760. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.electricity_charge_balance_6688528296. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.last_electricity_usage_6688528296. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_usage_6688528296. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/sensor.yearly_electricity_charge_6688528296. response[502]: b'502: Bad Gateway'
2023-03-21 08:40:41  [INFO    ] ---- state-refresh task run successfully!
数据不能写入到api怎么破,我是hassos
[color=var(--primary-text-color)]Home Assistant 2023.3.3Supervisor 2023.03.1Operating System 9.0前端版本: 20230309.0 - latest
 楼主| 发表于 2023-3-21 10:55:10 | 显示全部楼层
foxmouse 发表于 2023-3-21 09:58
2023-03-21 08:40:41   ---- Homeassistant REST API invoke, POST on http://supervisor/core/api/states/ ...
hassio的容器间通讯问题,你需要看看ingress是否工作正常。不行就换docker方式安装,不走hassio ingress。
发表于 2023-3-21 14:54:39 | 显示全部楼层
louis_lee 发表于 2023-3-21 10:55
hassio的容器间通讯问题,你需要看看ingress是否工作正常。不行就换docker方式安装,不走hassio ingress ...
说错了大佬,我是hassos,不是hassio。。。有解决方案吗?
 楼主| 发表于 2023-3-21 14:56:03 | 显示全部楼层
Supervisor 2023.03. ...
重启OS试试。
发表于 2023-3-23 10:09:22 | 显示全部楼层
重启了,等我再断电重启试试
 楼主| 发表于 2023-3-23 10:13:30 | 显示全部楼层
foxmouse 发表于 2023-3-23 10:09
重启了,等我再断电重启试试
其他加载项能正常使用嘛?比如node-red?
发表于 2023-3-27 11:38:01 | 显示全部楼层
实体显示未知?
发表于 2023-3-30 09:50:38 | 显示全部楼层
该实体 (“sensor.electricity_charge_balance_XXXXXXXXXXXX”) 没有 unique ID,因此无法由 UI 管理其设置。请参阅 文档 以详细了解。请问这个怎么解?
发表于 2023-3-30 10:13:38 | 显示全部楼层
楼主 我添加了3个户号 unique_id 只能生成第一电表的
template 1:
  - trigger:
      - platform: event
        event_type: "state_changed"
        event_data:
          entity_id: sensor.electricity_charge_balanc
 楼主| 发表于 2023-3-30 10:19:15 | 显示全部楼层
template 1:
  - trigger:
看你贴的这个配置,不太对啊,没贴全吧
GMT+8, 2025-12-17 22:20 , Processed in 0.053936 second(s), 8 queries , MemCached On.
