楼主: XCray
[修仙教程] 【大功告成】23年7月更:M401A/CM311-1a盒子Armbian安装极其简单
发表于 2022-12-31 16:54:28 来自手机 | 显示全部楼层
我拆了蓝牙接了个CC2530。测试rx和tx串口收发正常。但homeassistant中的zigbee2mqtt连接不上cc2530。不知道什么原因
发表于 2023-1-25 18:42:57 | 显示全部楼层
楼主,帮忙看下这是什么原因,一直重复再跑这个代码
容器里也比别人少运行了一个home-assitant
Jan 25 18:32:31 homeassistant hassio_supervisor[1412]: 23-01-25 18:32:31 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2022.07.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.07.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-audio&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
Jan 25 18:32:31 homeassistant hassio_supervisor[1412]: 23-01-25 18:32:31 WARNING (MainThread) [supervisor.plugins.audio] Error on installing Audio plugin, retrying in 30sec
Jan 25 18:32:34 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:38407 - 29994 "NS IN . udp 17 false 512" NOERROR - 0 7.602467177s
Jan 25 18:32:34 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:32:34 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:56758 - 13747 "NS IN . udp 17 false 512" NOERROR - 0 6.101832995s
Jan 25 18:32:37 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:60535 - 37224 "NS IN . udp 17 false 512" NOERROR - 0 6.1368613s
Jan 25 18:32:37 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:32:37 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:45672 - 9148 "NS IN . udp 17 false 512" NOERROR - 0 7.637670175s
Jan 25 18:32:40 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:42855 - 5346 "NS IN . udp 17 false 512" NOERROR - 0 6.179297679s
Jan 25 18:32:40 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:32:40 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:49206 - 63790 "NS IN . udp 17 false 512" NOERROR - 0 7.679981747s
Jan 25 18:32:40 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:32:43 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:39887 - 64280 "NS IN . udp 17 false 512" NOERROR - 0 6.214520009s
Jan 25 18:32:43 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:32:43 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:40074 - 11422 "NS IN . udp 17 false 512" NOERROR - 0 7.715847145s
Jan 25 18:32:43 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:32:46 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:60909 - 57247 "NS IN . udp 17 false 512" NOERROR - 0 7.756842838s
Jan 25 18:32:46 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:32:46 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:32864 - 6767 "NS IN . udp 17 false 512" NOERROR - 0 6.25665947s
Jan 25 18:32:49 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:38726 - 54924 "NS IN . udp 17 false 512" NOERROR - 0 7.795398218s
Jan 25 18:32:49 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:32:49 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:54672 - 46615 "NS IN . udp 17 false 512" NOERROR - 0 6.295388858s
Jan 25 18:32:49 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:32:52 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:36804 - 25507 "NS IN . udp 17 false 512" NOERROR - 0 7.830963232s
Jan 25 18:32:52 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:32:52 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:39301 - 40842 "NS IN . udp 17 false 512" NOERROR - 0 6.330295507s
Jan 25 18:32:52 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
^Z
[2]+  Stopped                 journalctl -f
root@homeassistant:~# journalctl -f
-- Journal begins at Wed 2023-01-25 16:22:58 CST. --
Jan 25 18:34:23 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:55786 - 58429 "NS IN . udp 17 false 512" NOERROR - 0 7.487866684s
Jan 25 18:34:23 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:26 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:43089 - 22270 "NS IN . udp 17 false 512" NOERROR - 0 6.025551835s
Jan 25 18:34:26 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:26 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:58884 - 63098 "NS IN . udp 17 false 512" NOERROR - 0 7.526368144s
Jan 25 18:34:29 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:35757 - 65328 "NS IN . udp 17 false 512" NOERROR - 0 6.064337927s
Jan 25 18:34:29 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:29 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:47993 - 53896 "NS IN . udp 17 false 512" NOERROR - 0 7.565262187s
Jan 25 18:34:29 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:34:32 homeassistant hassio_supervisor[1412]: 23-01-25 18:34:32 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2022.07.0.
Jan 25 18:34:32 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:51523 - 25020 "NS IN . udp 17 false 512" NOERROR - 0 7.6067132619999995s
Jan 25 18:34:32 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:32 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:53423 - 38993 "NS IN . udp 17 false 512" NOERROR - 0 6.106458758s
Jan 25 18:34:32 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:34:35 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:56357 - 53630 "NS IN . udp 17 false 512" NOERROR - 0 7.642480689s
Jan 25 18:34:35 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:35 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:44221 - 24625 "NS IN . udp 17 false 512" NOERROR - 0 6.141804568s
Jan 25 18:34:38 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:47517 - 39705 "NS IN . udp 17 false 512" NOERROR - 0 7.680660524s
Jan 25 18:34:38 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jan 25 18:34:38 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:52172 - 45302 "NS IN . udp 17 false 512" NOERROR - 0 6.180018078s
Jan 25 18:34:38 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:34:41 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:37720 - 53337 "NS IN . udp 17 false 512" NOERROR - 0 6.218557628s
Jan 25 18:34:41 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:34:41 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:44099 - 31647 "NS IN . udp 17 false 512" NOERROR - 0 7.719682981s
Jan 25 18:34:44 homeassistant dockerd[1412]: time="2023-01-25T18:34:44.836780436+08:00" level=warning msg="Error getting v2 registry: Get \"https://ghcr.io/v2/\": dial tcp 20.205.243.164:443: connect: no route to host"
Jan 25 18:34:44 homeassistant dockerd[1412]: time="2023-01-25T18:34:44.836978810+08:00" level=info msg="Attempting next endpoint for pull after error: Get \"https://ghcr.io/v2/\": dial tcp 20.205.243.164:443: connect: no route to host"
Jan 25 18:34:44 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:48954 - 53326 "NS IN . udp 17 false 512" NOERROR - 0 7.758379813s
Jan 25 18:34:44 homeassistant hassio_dns[1412]: [INFO] 127.0.0.1:53389 - 61446 "NS IN . udp 17 false 512" NOERROR - 0 6.257905133s
Jan 25 18:34:44 homeassistant hassio_dns[1412]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.1.1.1:853: connect: no route to host
Jan 25 18:34:44 homeassistant dockerd[1412]: time="2023-01-25T18:34:44.841726919+08:00" level=error msg="Handler for POST /v1.41/images/create returned error: Get \"https://ghcr.io/v2/\": dial tcp 20.205.243.164:443: connect: no route to host"
Jan 25 18:34:44 homeassistant hassio_supervisor[1412]: 23-01-25 18:34:44 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2022.07.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.07.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-audio&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp 20.205.243.164:443: connect: no route to host")
发表于 2023-1-28 20:51:21 | 显示全部楼层
学习了,感谢分享~赞一个!
发表于 2023-2-1 20:42:25 | 显示全部楼层
请问,安装了5.15.88-happy-new-year这个版本的armbian,HA安装了之后提示cgroup版本高了,查看了一下版本信息是V2的,需要调整到V1版本,麻烦问下,这个怎么弄?
看了下ha的官方说明,目前只支持cgroup v1版本。不知道咋办呢。。。。 还请大神指导一下
发表于 2023-2-4 10:33:47 | 显示全部楼层
厉害厉害!谢谢分享楼主辛苦了
发表于 2023-2-10 00:37:29 | 显示全部楼层
11、写入emmc:armbian-install(最好先编辑一下),选305(第6步编辑的)
305不是cm311吗
发表于 2023-2-10 13:17:20 | 显示全部楼层
感谢!!!!!!!!!!!
发表于 2023-2-12 00:04:39 | 显示全部楼层
zql6666 发表于 2022-12-6 18:37
写入EMMC指令运行后出现这个错误是为什么啊[ ERROR ] Failed to mount BOOTFS partition
老哥 解决了吗 如何解决的
发表于 2023-2-12 13:14:31 | 显示全部楼层
a8150167 发表于 2022-12-31 16:54
我拆了蓝牙接了个CC2530。测试rx和tx串口收发正常。但homeassistant中的zigbee2mqtt连接不上cc2530。不知道 ...
666,等你研究,2652有戏不
发表于 2023-2-19 11:12:39 | 显示全部楼层
iamhyde 发表于 2023-2-12 13:14
666,等你研究,2652有戏不
2652p早就内置成功了
GMT+8, 2026-1-10 13:51 , Processed in 1.642693 second(s), 10 queries , MemCached On.
