发表于 2022-8-28 07:43:03
显示全部楼层
盒子跟你的有一点区别,用的是Armbian_22.08.0_Aml_s905l3a_jammy_5.15.62_server_2022.08.26镜像和你上传的meson-g12a-u201 46KB的dtb,安卓是刷的广东的包。ttl信息如下:
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000 OC:F;RCY:0;EMMC:0;READ:0;0.0;
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008267
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 130709
BL2 Built : 14:02:05, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz
Board ID = 8
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 8
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0
00000000
emmc switch 0 ok
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
LPDDR4 probe
LPDDR4_PHY_V_0_1_22-Built : 15:59:30, May 25 2020. g12a gb6bfa83 - gongwei.chen@droid11-sz
ddr clk to 1176MHz
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of read delay center optimization
Check phy result
INFO : End of write delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 00000027 00000026 00000026 00000026 00000027 00000027 00000028 00000026 00000025 00000025 00000027 00000028 00000025 00000025 00000026 00000025 00000027 00000025 00000026 00000026 00000025 00000026 00000026 00000025 00000027 00000027 00000025 00000027 00000025 00000025 00000025 00000025 dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004
dram_vref_reg_value 0x 0000005f
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 477
result report
boot times 0Enable ddr reg access
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000da600, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
[Image: g12a_v1.1.3394-7d43064d5 2020-05-07 15:37:06 gongwei.chen@droid11-sz]
OPS=0x70
ring efuse init
28 0c 70 00 01 1c 1c 00 00 03 35 35 39 41 48 50
[0.014271 Inits done]
secure task start!
high task start!
low task start!
boot bl31
NOTICE: BL31: v1.3(release):5d6723eeb
NOTICE: BL31: Built : 15:05:59, Mar 17 2020
NOTICE: BL31: G12A normal boot!
NOTICE: BL31: BL33 decompress pass
ERROR: Error initializing runtime service opteed_fast
U-Boot 2015.01 (Oct 14 2021 - 11:11:44)
DRAM: 2 GiB
Relocation Offset is: 76e3c000
mmu cfg end: 0x80000000
spi_post_bind(spifc): req_seq = 0
register usb cfg[0][1] = 0000000077f38ff8
NAND: get_sys_clk_rate_mtd() 292, clock setting 200!
bus cycle0: 6,timing: 7
NAND device id: 0 ff ff ff ff ff
No NAND device found!!!
nand init failed: -6
MMC: aml_priv->desc_buf = 0x0000000073e2ca70
aml_priv->desc_buf = 0x0000000073e2edb0
SDIO Port B: 0, SDIO Port C: 1
co-phase 0x2, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800
co-phase 0x2, tx-dly 0, clock 40000000
[set_emmc_calc_fixed_adj][875]find fixed adj_delay=20
init_part() 297: PART_TYPE_AML
[mmc_init] mmc init success
Amlogic multi-dtb tool
GZIP format, decompress...
Multi dtb detected
Multi dtb tool version: v2 .
Support 3 dtbs.
aml_dt soc: g12a platform: u212 variant: 2g
dtb 0 soc: g12a plat: u212 vari: 1g
dtb 1 soc: g12a plat: u212 vari: 2g
dtb 2 soc: sm1 plat: ac213 vari: 2g
Find match dtb: 1
start dts,buffer=0000000073e31620,dt_addr=0000000073e31620
get_partition_from_dts() 92: ret 0
Single dtb detected
parts: 21
00: logo 0000000000800000 1
01: recovery 0000000001800000 1
02: misc 0000000000800000 1
03: dtbo 0000000000800000 1
04: cri_data 0000000000800000 2
05: param 0000000001000000 2
06: boot 0000000001000000 1
set has_boot_slot = 0
07: rsv 0000000001000000 1
08: metadata 0000000001000000 1
09: vbmeta 0000000000200000 1
10: tee 0000000002000000 1
11: vendor 0000000014000000 1
12: skmac 0000000000400000 1
13: odm 0000000001000000 1
14: system 0000000050000000 1
15: product 0000000008000000 1
16: ctc 0000000010000000 1
17: skparam 0000000001000000 2
18: skbackup 0000000030000000 2
19: cache 0000000040000000 2
20: data ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!!
crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!!
crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!!
mmc env offset: 0x47400000
In: serial
Out: serial
Err: serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-3476: calc cfa31a1e, store cfa31a1e
dtb_read()-3691: total valid 2
update_old_dtb()-3672: do nothing
Multi dtb detected
Support 3 dtbs.
Find match dtb: 1
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
vpu: driver version: v20190313
vpu: detect chip type: 8
vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz)
vpu: clk_level in dts: 7
vpu: vpu_power_on
vpu: set_vpu_clk
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: set_vpu_clk finish
vpu: vpu_module_init_config
vpp: vpp_init
vpp: vpp osd2 matrix rgb2yuv..............
hdr_func 4, hdr_process_select 0x1
cvbs: cpuid:0x28
cvbs: find performance_pal config
cvbs: find performance_ntsc config
aml_config_dtb 633
aml_config_dtb 663
co_phase = <0x00000003>
caps2 = "MMC_CAP2_HS200"
f_max = <0x02faf080>
status = "disabled"
status = "okay"
Net: dwmac.ff3f0000amlkey_init() enter!
amlkey_init() 71: already init!
wipe_data=successful
wipe_cache=successful
upgrade_step=2
reboot_mode:::: cold_boot
ext4logoLoadCmd=ext4load mmc 1 {logoPart} ${logoLoadAddr} ${ext4LogoPath}
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
Err imgread(L815):Fail in load logo cmd
logo part bootup
[OSD]load fb addr from dts:/meson-fb
[OSD]set initrd_high: 0x7f800000
[OSD]fb_addr for logo: 0x7f800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x7f800000 width=5760, height=2160
Err imgread(L574) ogo header err.
There is no valid bmp file at the given address
[OSD]osd_hw.free_dst_data: 0,1919,0,1079
[OSD]osd1_update_disp_freescale_enable
cvbs: outputmode[1080p60hz] is invalid
vpp: vpp_matrix_update: 2
set hdmitx VIC = 16
aml_audio_init
config HPLL = 5940000 frac_rate = 0
HPLL: 0x3b3a04f7
HPLL: 0x1b3a04f7
HPLLv1: 0xdb3a04f7
config HPLL done
j = 6 vid_clk_div = 1
hdmitx: set enc for VIC: 16
hdmitx phy setting done
rx version is 1.4 or below div=10
hdmtix: set audio
hdmi_tx_set: save mode: 1080p60hz, attr: 444,8bit, hdmichecksum: <NULL>
Saving Environment to aml-storage...
Writing to MMC(1)... done
hdr_packet
vpp: hdr_policy = 1
vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0
[KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet
[KM]Error:f[keymanage_dts_get_key_device]L105:cmei key name is not exist
[KM]Error:f[_get_km_ops_by_name]L240:key cmei not know device 4
[KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[cmei]
[KM]Error:f[key_manage_query_size]L511:Fail in query key exist
[KM]Error:f[keymanage_dts_get_key_device]L105:authkey key name is not exist
[KM]Error:f[_get_km_ops_by_name]L240:key authkey not know device 4
[KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[authkey]
[KM]Error:f[keymanage_dts_get_key_device]L105 emkey key name is not exist
[KM]Error:f[_get_km_ops_by_name]L240:key oemkey not know device 4
[KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[oemkey]
[KM]Error:f[keymanage_dts_get_key_device]L105:region_code key name is not exist
[KM]Error:f[_get_km_ops_by_name]L240:key region_code not know device 4
[KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[region_code]
boot_select kernel[0,3) recovery[3,10) factory[10,*)
boot_select current count=0 value=1
boot_select count=0
boot_select=kernel
Command: bcb uboot-command
Start read misc partition datas!
BCB hasn't any datas,exit!
Hit Enter or space or Ctrl+C key to stop autoboot -- : 0
card out
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 3000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... init_part() 282: PART_TYPE_DOS
1 Storage Device(s) found
reading s905_autoscript
1654 bytes read in 32 ms (49.8 KiB/s)
## Executing script at 01020000
start amlogic old u-boot
## Error: "bootfromsd" not defined
card out
** Bad device mmc 0 **
reading boot_android
** Unable to read file boot_android **
card out
reading u-boot.ext
704408 bytes read in 90 ms (7.5 MiB/s)
## Starting application at 0x01000000 ...
<debug_uart>
U-Boot 2022.04-00910-gea5583b90f-dirty (Apr 22 2022 - 23:37:44 +0800) e900v22c
Model: Skyworth E900V22C Multimedia Box
SoC: Amlogic Meson G12A (Unknown) Revision 28:c (70:2)
DRAM: 2 GiB
Core: 375 devices, 20 uclasses, devicetree: separate
MMC: sd@ffe05000: 0, mmc@ffe07000: 1
Loading Environment from nowhere... OK
In: serial@3000
Out: serial@3000
Err: serial@3000
Net: eth0: ethernet@ff3f0000
Hit any key to stop autoboot: 0
Card did not respond to voltage select! : -110
switch to partitions #0, OK
mmc1(part 0) is current device
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
MMC Device 2 not found
no mmc device at slot 2
starting USB...
Bus usb@ff500000: Register 3000140 NbrPorts 3
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 2.0
Type: Removable Hard Disk
Capacity: 14784.0 MB = 14.4 GB (30277632 x 512)
... is now current device
Scanning usb 0:1...
Found U-Boot script /boot.scr
1123 bytes read in 1 ms (1.1 MiB/s)
## Executing script at 08000000
Start AMLOGIC mainline U-boot
352 bytes read in 2 ms (171.9 KiB/s)
## Error: "mac" not defined
## Error: "eth_mac" not defined
ethaddr=a6:5f:ed:61:ec:43
25264640 bytes read in 863 ms (27.9 MiB/s)
8198938 bytes read in 271 ms (28.9 MiB/s)
46057 bytes read in 10 ms (4.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 13000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 8198874 Bytes = 7.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 08008000
Booting using the fdt blob at 0x8008000
Loading Ramdisk to 3f82e000, end 3ffffada ... OK
Loading Device Tree to 000000003f81f000, end 000000003f82d3e8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.62-flippy-76+o (root@univm25) (Ubuntu clang version 14.0.0-1ubuntu1, Ubuntu LLD 14.0.0) #168 SMP PREEMPT Sun Aug 21 22:25:51 CST 2022
[ 0.000000] Machine model: Amlogic Meson G12A U200 Development Board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000070000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff]
[ 0.000000] node 0: [mem 0x0000000005000000-0x00000000072fffff]
[ 0.000000] node 0: [mem 0x0000000007300000-0x000000000fffffff]
[ 0.000000] node 0: [mem 0x0000000010000000-0x00000000101fffff]
[ 0.000000] node 0: [mem 0x0000000010200000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 19 pages/cpu s37720 r8192 d31912 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=UUID=d1a9ef44-c9f4-43f3-893d-d3557c00f8bb rootflags=data=writeback rw rootfstype=ext4 console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 mac=a6:5f:ed:61:ec:43
[ 0.000000] Unknown kernel command line parameters "cgroup_enable=memory cgroup_memory=1 mac=a6:5f:ed:61:ec:43", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack ff, heap alloc ff, heap free ff
[ 0.000000] Memory: 1726956K/2097152K available (15168K kernel code, 2720K rwdata, 4688K rodata, 1984K init, 887K bss, 108052K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000233] Console: colour dummy device 80x25
[ 0.000646] printk: console [tty0] enabled
[ 0.000703] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.000727] pid_max: default: 32768 minimum: 301
[ 0.000919] LSM: Security Framework initializing
[ 0.001022] SELinux: Initializing.
[ 0.001280] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001307] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.003436] rcu: Hierarchical SRCU implementation.
[ 0.004787] EFI services will not be available.
[ 0.005117] smp: Bringing up secondary CPUs ...
[ 0.005749] Detected VIPT I-cache on CPU1
[ 0.005812] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.006449] Detected VIPT I-cache on CPU2
[ 0.006482] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.007152] Detected VIPT I-cache on CPU3
[ 0.007180] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.007248] smp: Brought up 1 node, 4 CPUs
[ 0.007313] SMP: Total of 4 processors activated.
[ 0.007325] CPU features: detected: 32-bit EL0 Support
[ 0.007335] CPU features: detected: 32-bit EL1 Support
[ 0.007348] CPU features: detected: CRC32 instructions
[ 0.008142] CPU: All CPU(s) started at EL2
[ 0.008172] alternatives: patching kernel code
[ 0.009931] devtmpfs: initialized
[ 0.021622] Registered cp15_barrier emulation handler
[ 0.021664] Registered setend emulation handler
[ 0.021807] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.021837] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.028374] prandom: seed boundary self test passed
[ 0.029567] prandom: 100 self tests passed
[ 0.052542] prandom32: self test passed (less than 6 bits correlated)
[ 0.052599] pinctrl core: initialized pinctrl subsystem
[ 0.053304] DMI not present or invalid.
[ 0.053797] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.055827] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.056026] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.056213] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.056292] audit: initializing netlink subsys (disabled)
[ 0.056464] audit: type=2000 audit(0.053:1): state=initialized audit_enabled=0 res=1
[ 0.057732] thermal_sys: Registered thermal governor 'step_wise'
[ 0.058136] cpuidle: using governor ladder
[ 0.058317] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.058432] ASID allocator initialised with 65536 entries
[ 0.058579] Serial: AMBA PL011 UART driver
[ 0.081962] platform ff900000.vpu: Fixing up cyclic dependency with ff600000.hdmi-tx
[ 0.090322] platform cvbs-connector: Fixing up cyclic dependency with ff900000.vpu
[ 0.091318] platform hdmi-connector: Fixing up cyclic dependency with ff600000.hdmi-tx
[ 0.103307] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.103345] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.103359] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.103374] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.508386] cryptd: max_cpu_qlen set to 1000
[ 1.512015] "cryptomgr_test" (90) uses obsolete ecb(arc4) skcipher
[ 1.523363] alg: No test for 842 (842-generic)
[ 1.523510] alg: No test for 842 (842-scomp)
[ 1.613447] DRBG: Continuing without Jitter RNG
[ 1.696532] raid6: neonx8 gen() 2224 MB/s
[ 1.753292] raid6: neonx8 xor() 1602 MB/s
[ 1.810052] raid6: neonx4 gen() 2208 MB/s
[ 1.866814] raid6: neonx4 xor() 1538 MB/s
[ 1.923581] raid6: neonx2 gen() 2030 MB/s
[ 1.980340] raid6: neonx2 xor() 1434 MB/s
[ 2.037109] raid6: neonx1 gen() 1663 MB/s
[ 2.093857] raid6: neonx1 xor() 1177 MB/s
[ 2.150616] raid6: int64x8 gen() 1506 MB/s
[ 2.207372] raid6: int64x8 xor() 801 MB/s
[ 2.264135] raid6: int64x4 gen() 1606 MB/s
[ 2.320898] raid6: int64x4 xor() 824 MB/s
[ 2.377673] raid6: int64x2 gen() 1386 MB/s
[ 2.434419] raid6: int64x2 xor() 740 MB/s
[ 2.491170] raid6: int64x1 gen() 1167 MB/s
[ 2.547942] raid6: int64x1 xor() 583 MB/s
[ 2.547954] raid6: using algorithm neonx8 gen() 2224 MB/s
[ 2.547966] raid6: .... xor() 1602 MB/s, rmw enabled
[ 2.547977] raid6: using neon recovery algorithm
[ 2.548122] fbcon: Taking over console
[ 2.548153] ACPI: Interpreter disabled.
[ 2.549666] VDDAO_3V3: supplied by 12V
[ 2.550088] iommu: Default domain type: Translated
[ 2.550102] iommu: DMA domain TLB invalidation policy: strict mode
[ 2.550481] vgaarb: loaded
[ 2.550968] SCSI subsystem initialized
[ 2.551188] usbcore: registered new interface driver usbfs
[ 2.551236] usbcore: registered new interface driver hub
[ 2.551313] usbcore: registered new device driver usb
[ 2.551765] mc: Linux media interface: v0.10
[ 2.551809] videodev: Linux video capture interface: v2.00
[ 2.552070] EDAC MC: Ver: 3.0.0
[ 2.553140] Advanced Linux Sound Architecture Driver Initialized.
[ 2.554093] clocksource: Switched to clocksource arch_sys_counter
[ 2.554389] VFS: Disk quotas dquot_6.6.0
[ 2.554460] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.554596] FS-Cache: Loaded
[ 2.555134] pnp: PnP ACPI: disabled
[ 2.562374] NET: Registered PF_INET protocol family
[ 2.562573] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.563781] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 2.563825] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 2.563854] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 2.564035] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 2.564288] TCP: Hash tables configured (established 16384 bind 16384)
[ 2.564514] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 2.564610] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 2.564666] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 2.564856] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 2.564891] NET: Registered PF_XDP protocol family
[ 2.564912] PCI: CLS 0 bytes, default 64
[ 2.565231] Trying to unpack rootfs image as initramfs...
[ 2.574776] kvm [1]: IPA Size Limit: 40 bits
[ 2.575598] kvm [1]: vgic interrupt IRQ9
[ 2.575752] kvm [1]: Hyp mode initialized successfully
[ 3.117962] Freeing initrd memory: 8004K
[ 3.324129] Initialise system trusted keyrings
[ 3.324331] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 3.331471] zbud: loaded
[ 3.333615] fuse: init (API version 7.34)
[ 3.334148] SGI XFS with ACLs, security attributes, quota, no debug enabled
[ 3.374011] NET: Registered PF_ALG protocol family
[ 3.424616] xor: measuring software checksum speed
[ 3.429441] 8regs : 2051 MB/sec
[ 3.432844] 32regs : 2909 MB/sec
[ 3.437436] arm64_neon : 2154 MB/sec
[ 3.437449] xor: using function: 32regs (2909 MB/sec)
[ 3.437465] Key type asymmetric registered
[ 3.437476] Asymmetric key parser 'x509' registered
[ 3.437561] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 3.437690] io scheduler mq-deadline registered
[ 3.437704] io scheduler kyber registered
[ 3.437859] io scheduler bfq registered
[ 3.467178] soc soc0: Amlogic Meson G12A (Unknown) Revision 28:c (70:2) Detected
[ 3.468792] VDDCPU: supplied by 12V
[ 3.470278] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[ 3.472269] Serial: AMBA driver
[ 3.472684] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 22, base_baud = 1500000) is a meson_uart
[ 4.487916] printk: console [ttyAML0] enabled
[ 4.492779] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 30, base_baud = 1500000) is a meson_uart
[ 4.511305] brd: module loaded
[ 4.515406] loop: module loaded
[ 4.523082] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.524002] ehci-pci: EHCI PCI platform driver
[ 4.528443] ehci-platform: EHCI generic platform driver
[ 4.534132] usbcore: registered new interface driver cdc_wdm
[ 4.539250] usbcore: registered new interface driver usb-storage
[ 4.545601] mousedev: PS/2 mouse device common for all mice
[ 4.551637] SPI driver rmi4_spi has no spi_device_id for syna,rmi4-spi
[ 4.557840] meson-vrtc ff8000a8.rtc: registered as rtc0
[ 4.562309] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[ 4.570757] i2c_dev: i2c /dev entries driver
[ 4.578373] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present!
[ 4.582513] Registered IR keymap rc-cec
[ 4.586041] rc rc0: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0
[ 4.594712] input: meson_g12a_ao_cec as /devices/platform/soc/ff800000.bus/ff800280.cec/rc/rc0/input0
[ 4.610600] sdhci: Secure Digital Host Controller Interface driver
[ 4.612150] sdhci: Copyright(c) Pierre Ossman
[ 4.615471] Synopsys Designware Multimedia Card Interface Driver
[ 4.622126] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.622310] meson-gx-mmc ffe05000.sd: Got CD GPIO
[ 4.628413] meson-sm: secure-monitor enabled
[ 4.637169] hid: raw HID events driver (C) Jiri Kosina
[ 4.641100] usbcore: registered new interface driver usbhid
[ 4.646522] usbhid: USB HID core driver
[ 4.654055] Initializing XFRM netlink socket
[ 4.654966] NET: Registered PF_INET6 protocol family
[ 4.660088] gpio irq setup: hwirq: 0x3B irqfirst: 0x35 irqlast: 0x3C pin[47]
[ 4.666720] genirq: Setting trigger mode 3 for irq 37 failed (meson_gpio_irq_set_type+0x0/0x140)
[ 4.687160] Segment Routing with IPv6
[ 4.687198] RPL Segment Routing with IPv6
[ 4.689225] In-situ OAM (IOAM) with IPv6
[ 4.693187] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.701437] bpfilter: Loaded bpfilter_umh pid 297
[ 4.703618] NET: Registered PF_PACKET protocol family
[ 4.708641] NET: Registered PF_KEY protocol family
[ 4.713468] 8021q: 802.1Q VLAN Support v1.8
[ 4.717790] registered taskstats version 1
[ 4.721544] Loading compiled-in X.509 certificates
[ 4.728014] zswap: loaded using pool zstd/zbud
[ 4.731095] Key type ._fscrypt registered
[ 4.734636] Key type .fscrypt registered
[ 4.738515] Key type fscrypt-provisioning registered
[ 4.744123] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 4.771523] VCC_3V3: supplied by VDDAO_3V3
[ 4.772027] VCC_5V: supplied by 12V
[ 4.773599] VDDAO_1V8: supplied by VDDAO_3V3
[ 4.869915] meson-drm ff900000.vpu: Queued 3 outputs on vpu
[ 4.897496] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 4.902380] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 4.911106] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops 0xffffffc00a2d51b8)
[ 4.917805] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
