楼主: XCray
[经验分享] 【折腾笔记】魔百盒M401A安装OpenWRT跑HA,目的是让NAS休息
发表于 2022-8-2 11:27:29 | 显示全部楼层
在那?有链接吗?
发表于 2022-8-2 12:06:21 | 显示全部楼层
root@arm-64:~/2# dmesg |tail -f
[  761.857867] IPv6: ADDRCONF(NETDEV_CHANGE): veth1f518de: link becomes ready
[  761.857988] hassio: port 7(veth1f518de) entered blocking state
[  761.857994] hassio: port 7(veth1f518de) entered forwarding state
[  762.222591] overlayfs: disabling nfs_export due to index=off
[  762.295497] overlayfs: disabling nfs_export due to index=off
[  762.358100] overlayfs: disabling nfs_export due to index=off
[37878.523743] systemd-xdg-autostart-generator[34544]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
[43227.095741] btusb: unknown parameter 'rtk_btusb' ignored
[43227.096145] usbcore: registered new interface driver btusb
[43310.586977] usbcore: deregistering interface driver btusb
XCray 发表于 2022-8-2 11:07
你先modprobe btusb rtk_btusb一下?
没什么用
发表于 2022-8-2 12:49:59 | 显示全部楼层
小白不会玩了,等大佬们吧
root@arm-64:~# sudo dmesg |egrep -i bluetooth
[  131.376654] Bluetooth: Core ver 2.22
[  131.376662] Bluetooth: Starting self testing
[  131.399606] Bluetooth: ECDH test passed in 22393 usecs
[  131.407250] Bluetooth: SMP test passed in 7393 usecs
[  131.407277] Bluetooth: Finished self testing
[  131.407585] Bluetooth: HCI device and connection manager initialized
[  131.407606] Bluetooth: HCI socket layer initialized
[  131.407615] Bluetooth: L2CAP socket layer initialized
[  131.407641] Bluetooth: SCO socket layer initialized
发表于 2022-8-2 13:17:03 来自手机 | 显示全部楼层
蓝牙这玩意还得看/lib/firmware(可能拼错了),n1刷的那个ophub自带的firmware蓝牙出问题,换了另外的就好了
发表于 2022-8-2 13:25:25 | 显示全部楼层
小白不会玩了,等大佬们吧
发表于 2022-8-2 13:29:49 | 显示全部楼层
whowhowho 发表于 2022-8-2 13:17
蓝牙这玩意还得看/lib/firmware(可能拼错了),n1刷的那个ophub自带的firmware蓝牙出问题,换了另外的就好了 ...
已经把驱动复制进去了,没什么用呢,make也报错。
发表于 2022-8-2 13:46:26 | 显示全部楼层
已经把驱动复制进去了,没什么用呢,make也报错。重启以后dmesg | egrep -i blue输出是空的,好像开机没有加载这玩意儿
发表于 2022-8-3 04:48:58 | 显示全部楼层
XCray 发表于 2022-7-30 22:36
就在那个群文档里,顺着ophub的readme、点e900v22c就能看到。ophub的仓库里也有,工具、安卓镜像都有 ...
惊了,我的盒子,直接armbian-install就成功了,m401a
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-8-3 07:01:51 来自手机 | 显示全部楼层
羡慕!看来你拿到的是“标准版”。
我是折腾了一遛够才找到emmc顺利启动的装法。
对了,你用的哪个镜像?有没有拆机拍照呢?
发表于 2022-8-3 07:11:16 | 显示全部楼层
XCray 发表于 2022-8-3 07:01
羡慕!看来你拿到的是“标准版”。
就用的ophub的armbian镜像,选择e900v22c的dtb,拆机的话晚上可以拍个照
GMT+8, 2025-12-16 05:17 , Processed in 1.229709 second(s), 11 queries , MemCached On.
