楼主: wuxin0912
[技术探讨] 我在新版本上适配xiaomi_cloud成功(查找、定位小米手机)
发表于 2022-9-15 08:52:51 | 显示全部楼层
就是安装集成的时候,显示了位置,然后find服务也可以返回实时位置,几分钟之后,位置就一直不更新了
就是安装集成的时候,显示了位置,然后find服务也可以返回实时位置,几分钟之后,位置就一直不更新了,到现在都一直是几天前的位置。测试多次都是这样
Logger: homeassistant.core
Source: custom_components/xiaomi_cloud/device_tracker.py:98
Integration: Xiaomi Cloud (documentation, issues)
First occurred: 2022年9月13日 18:28:34 (113 occurrences)
Last logged: 2022年9月14日 11:06:18
    Error executing service: <ServiceCall xiaomi_cloud.find (c:01GCWSCVTKG0X7KSQE0SNP037J)>
    Error executing service: <ServiceCall xiaomi_cloud.find (c:01GCWSCW3CEJRZ5M7KSJ66CW2K)>
    Error executing service: <ServiceCall xiaomi_cloud.find (c:01GCWSCZKZ9QYQKGAJEKQATESS)>
    Error executing service: <ServiceCall xiaomi_cloud.find (c:01GCWSCZXX3AVVV6ZNVME6G2P4)>
    Error executing service: <ServiceCall xiaomi_cloud.find (c:01GCWZBW9BH6JQWNGMQSC9D4NF)>
  File "/usr/src/homeassistant/homeassistant/core.py", line 1722, in catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1741, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/config/custom_components/xiaomi_cloud/__init__.py", line 85, in services
    await coordinator._send_command({'service': 'find', 'data': {'imei': imei}})
  File "/config/custom_components/xiaomi_cloud/__init__.py", line 330, in _send_command
    await self.async_refresh()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 168, in async_refresh
    await self._async_refresh(log_failures=True)
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 270, in _async_refresh
    update_callback()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 533, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 571, in _async_write_ha_state
    state = self._stringify_state(available)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 539, in _stringify_state
    if (state := self.state) is None:
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/config_entry.py", line 247, in state
    if self.latitude is not None and self.longitude is not None:
  File "/config/custom_components/xiaomi_cloud/device_tracker.py", line 98, in latitude
    return self.coordinator.data[self._vin]["device_lat"]
IndexError: list index out of range
Emin 手机认证
发表于 2022-11-17 17:46:37 | 显示全部楼层
Emin 手机认证
发表于 2022-12-12 15:40:45 | 显示全部楼层
终于找到借助小米云服务定位小米手机能用的插件了,再次感谢
Emin 手机认证
发表于 2022-12-12 22:30:20 | 显示全部楼层
也出现了IndexError: list index out of range错误。定位也没有更新
发表于 2022-12-25 21:04:14 | 显示全部楼层
学习学习
发表于 2023-8-20 10:05:59 | 显示全部楼层
只有登录的时候有更新 之后就没有了 用 xiaomi_cloud.find 也不更新
发表于 2023-8-21 15:35:36 | 显示全部楼层
连小米云都可以自己搭建,厉害了。。
发表于 2023-8-21 15:36:40 | 显示全部楼层
可以把小米的云同步,存储路径改为自己家里的nas上嘛?随时随地通过小米云同步到nas,怎么整呀,请教
发表于 2023-10-16 11:02:23 | 显示全部楼层
集成安装也配置好了,但没有任何实体。是咋回事呢....
发表于 2024-2-5 09:29:56 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-12-16 19:53 , Processed in 0.537374 second(s), 10 queries , MemCached On.
