楼主: wuxin0912
[技术探讨] 我在新版本上适配xiaomi_cloud成功(查找、定位小米手机)
cmsj 手机认证
发表于 2022-8-16 15:03:04 | 显示全部楼层
这些服务在哪?
 楼主| 发表于 2022-8-17 20:10:14 | 显示全部楼层
cmsj 发表于 2022-8-16 15:03
这些服务在哪?
服务在开发者工具里面,服务名见:https://github.com/fineemb/xiaomi-cloud
发表于 2022-9-2 17:27:21 | 显示全部楼层
集成中点击“选项”,不定期弹出错误,显示“无法加载配置向导: Unexpected UTF-8 BOM (decode using utf-8-sig): line 1 column 1 (char 0)”  忽视这个提示后再重新点击“选项”后才正常弹出配置选项。
此错误导致实体有时失效,望进一步修复  Hass core 20220606
 楼主| 发表于 2022-9-3 15:47:55 | 显示全部楼层
hbxgzhc2 发表于 2022-9-2 17:27
集成中点击“选项”,不定期弹出错误,显示“无法加载配置向导: Unexpected UTF-8 BOM (decode using utf-8 ...
你好,我之前写这个的时候系统版本是比你这个旧,现在我已经更新到2022.8.6,依旧没有出现这个问题
发表于 2022-9-4 15:33:09 | 显示全部楼层
此错误来自自定义集成。
Logger: homeassistant
Source: custom_components/xiaomi_cloud/device_tracker.py:98
Integration: Xiaomi Cloud (documentation, issues)
First occurred: 14:46:40 (2 occurrences)
Last logged: 15:18:55
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 151, in _handle_refresh_interval
    await self._async_refresh(log_failures=True, scheduled=True)
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
    self.async_update_listeners()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 110, in async_update_listeners
    update_callback()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 532, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 570, in _async_write_ha_state
    state = self._stringify_state(available)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 538, in _stringify_state
    if (state := self.state) is None:
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/config_entry.py", line 247, in state
    if self.latitude is not None and self.longitude is not None:
  File "/config/custom_components/xiaomi_cloud/device_tracker.py", line 98, in latitude
    return self.coordinator.data[self._vin]["device_lat"]
TypeError: 'bool' object is not subscriptable
版本2022.8.6  docker 安装 core
WIFI电表,ZigBee电表 单相 三相
发表于 2022-9-6 11:58:13 | 显示全部楼层
请问位置偏移怎么解决呢。。
发表于 2022-9-6 18:21:33 | 显示全部楼层
wuxin0912 发表于 2022-9-3 15:47
你好,我之前写这个的时候系统版本是比你这个旧,现在我已经更新到2022.8.6,依旧没有出现这个问题 ...
发表于 2022-9-6 18:24:01 | 显示全部楼层
可确实出现了这问题,楼主看看有修复可能吗?supervisor-2022.05.3 core-2022.6.6
版本supervisor-2022.05.3 core-2022.6.6
发表于 2022-9-7 10:05:40 | 显示全部楼层
感谢大佬
发表于 2022-9-7 11:18:23 | 显示全部楼层
GMT+8, 2026-1-14 09:33 , Processed in 1.791107 second(s), 14 queries , MemCached On.
