楼主: lidicn
[插件集成] 斐讯K3官Root【更新】【设备追踪】【device tracker】插件
发表于 2018-11-30 05:48:02 | 显示全部楼层
正好是这个固件,试试试试,谢谢楼主
发表于 2018-12-16 15:17:52 | 显示全部楼层
学习!!!
发表于 2018-12-18 00:51:49 | 显示全部楼层
谢谢喽,好好学习.
发表于 2018-12-23 01:45:28 | 显示全部楼层
好东西,支持一下
发表于 2018-12-23 06:44:59 来自手机 | 显示全部楼层
看一下,希望有dc1的控制
发表于 2018-12-31 00:07:56 | 显示全部楼层
楼主,我现在的路由器系统是官改1.9,Home Assistant是0.84.6 ,用了你的插件后,运行不起来,有报错帮分析下,谢谢!
Error setting up platform phicomm_k3
  File "/opt/lib/python3.7/site-packages/homeassistant/components/device_tracker/__init__.py", line 176, in async_setup_platform
    platform.get_scanner, hass, {DOMAIN: p_config})
  File "/thread.py", line 57, in run
  File "/tmp/share/sda1/root/.homeassistant/custom_components/device_tracker/phicomm_k3.py", line 56, in get_scanner
    scanner = PhicommDeviceScanner(config[DOMAIN])
  File "/tmp/share/sda1/root/.homeassistant/custom_components/device_tracker/phicomm_k3.py", line 100, in __init__
    data = self.connection.get_result()
  File "/tmp/share/sda1/root/.homeassistant/custom_components/device_tracker/phicomm_k3.py", line 172, in get_result
    from pexpect import pxssh, exceptions
  File "/tmp/share/sda1/root/.homeassistant/deps/lib/python3.7/site-packages/pexpect/__init__.py", line 75, in <module>
    from .pty_spawn import spawn, spawnu
  File "/tmp/share/sda1/root/.homeassistant/deps/lib/python3.7/site-packages/pexpect/pty_spawn.py", line 15, in <module>
    from .spawnbase import SpawnBase
  File "/tmp/share/sda1/root/.homeassistant/deps/lib/python3.7/site-packages/pexpect/spawnbase.py", line 218
    def expect(self, pattern, timeout=-1, searchwindowsize=-1, async=False):
SyntaxError: invalid syntax
发表于 2019-1-1 17:10:37 | 显示全部楼层
想通过device_tracker追踪家庭设备,我的路由器也是K3  用的固件是官root-tb,V21.6.8.46_root,homeassistant中的插件包括配置以及.py文件,运行没有报错, __pycache__也已经生成,但是找不到known_devices.yaml文件,自己创建了这个文件之后重新运行homeassistant,也没有数据产生,有没有大神协助解决一下的。
发表于 2019-1-1 21:56:16 | 显示全部楼层
看看tracker是怎么写的
发表于 2019-1-2 13:00:12 | 显示全部楼层
rabbitgg 发表于 2019-1-1 21:56
看看tracker是怎么写的
就是用的这个帖子上附件中的
发表于 2019-1-2 13:17:26 | 显示全部楼层
这个厉害了
GMT+8, 2025-12-17 22:18 , Processed in 0.056074 second(s), 11 queries , MemCached On.
